Question about Dometic Refrigerators
How to operate Dometic RM3601 on gas?
Refrigerator work on 120v but not on gas. I replaced the igniter, but there is no spark.
    Top Expert:
  • Dometic Master
  • 7,915 Answers
Check if clicking check for cobwebs if no clicking bad board
Posted on May 25, 2016
  • 122 Answers
SOURCE: Dometic RM2562 - No Flame
use a set of needle nose pliers & disconnect the igniter wire the module should start clicking if it does not click check the wires to the board clean them good & reconnect if the module still wont start clicking your board is bad if it does click the igniter adjustment off stick a nickle between the igniter & burner the gap should be the size of the nickle 3/16"
Posted on Jun 07, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Refrigerator not working on gas
There is some reason maybe not explained here. But I will help you if you want. Below is a simple test. The manual I need you to make sure if you have the RM2652 or another model to get the correct manual. That model has digital controls and that is controlled by a control board for switching from AC to DC to Propane. If the board will not switch then we need to look for that problem. Dometic, good refrigerate and great support group. Now here is a link to that model number problem solving PDF. With the manual we can work together to solve this. Thanks, Sea Breeze http://www.dometic.com/FileOrganizer/1-international/Operation%20&%20Installation%20Manuals/Refrigerators%20-%20Caravan%20-%20Motohomes-%20RV/English%20and%20Multilingual/RM2652-RM2852.pdf
Posted on Jun 16, 2009
  • 6 Answers
SOURCE: operates with gas, does not operate with AC.
Check the heater element for power.
Posted on Jul 01, 2009
  • 4793 Answers
SOURCE: Dometic 3 way RV ...the igniter strtrer just keeps
sounds like thermocouple needs replacing..easy job ? if you know what to do....
Posted on Feb 09, 2010
  • 1796 Answers
SOURCE: Dometic RM2652 RV Refrigerator trips GFCI
Hi!!
Right beside the circuit panel, there is a grill, remove the 4 screws to gain access to the transformer/battery charger. You'll see a double power outlet, one cord is from fridge, the other is from the transformer. UNPLUG Transformer cord and reset breaker.
It will take a couple of minutes for the fridge to change to AC if you have it in AUTO. If everything works fine, REPAIR OR REPLACE TRANSFORMER/BATTERY CHARGER.
Don't forget to rate this answer, Good Luck!!!
Posted on Apr 19, 2010
Freezer gets cold frig is hot. I replaced theromister.did no good
If your Dometic refrigerator is a tri-power model (12V, 120V, lp gas), check all modes. It is not uncommon for these units to fail to cool adequately in 12V mode, as that mode is only for KEEPING things cold while on the road.
If the failure exists only in 120V mode, replace the 120V heating element. If the failure exists only in lp gas mode, replace the burner and make sure that the jet is clean.
If the refrigerator does not get cold in ANY mode, verify that the door seal is making good contact all the way around and, if it is, you'll need to replace the coil assembly. (They are available on eBay and Amazon at a fairly reasonable price.)
May 20, 2015 | Dometic RM2652 Refrigerator
Dometic rm2652 re-ignitor
Dear sir/madam,
Turn the refrigerator off and remove the wire
between the electrode and igniter. Now turn the
refrigerator to the gas mode. If no internal
clicking sound is heard the igniter is defective.
It is important to remove the high voltage wire
that goes to the electrode from the igniter when
you are checking the igniter for operation. The
high voltage wire and the electrode can be
shorted to ground causing the igniter reigniter
to think that the flame is lit, resulting in no
spark on gas operation.
thanks
good luck
Sep 14, 2008 | Dometic RM2652 Refrigerator
I have a Dometic RM 2620 fridge, that won't cool. A squirrel got into wiring, I have taken care of wiring but will not work on gas or AC. Spark igniter will no spark either. Any ideas?
Since I don't know what does work I am kind of shooting in the dark.
Does the ac heater get hot ?
The spark ignitor is part of the control board. But won't work?
I assume that you have a user manual but I am including a link to download one.
https://www.dometic.com/f6e8a773-69f5-4624-9b35-54e8801da7af.fodoc
Note that there are three fuses. B (12V control) and C (120V Heater) on the control board and a thermofuse L located on the stack.
If L is good and everything else is good there should be 12VDC on J1 and at Fuse B
Sep 19, 2014 | Dometic RM2620 Refrigerator
98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
Apr 19, 2010 | Dometic RM2652 Refrigerator
My dometic will only work a couple of hours on electric then goe to check mode, is this the board
Problem. Unit controls go to "check"
There is a common problem with, Dometic RM2807 or RM2811 and most later model Dometics with upper controls. The refrigerator's "check light" comes on or the refrigerator just shuts down seemingly for no reason. Another common problem occurs while on 120v. The refrigerator might switch to gas or just shut down even while you have a good 120v supply.
Answer. Dometic RV refrigerators with the push button upper control boards have a problem with the main power boards. The power board components are encased in yellow epoxy, reducing heat transfer. This tends to cause them to run too hot which in turn can often cause the power board to fail completely or cause problems such as listed above. We have found the only effective repair is to replace the power board. We do not use the Dometic replacement as they too can fail. The Dometic replacement also requires you to rewire the board and gas valve. The only board we recommend is the P-711. The P-711 not only will fix these problems but does not require the rewiring. It uses all the standard wiring. See Power Boards
Hope you found this very helpful, best regards!
Jun 15, 2009 | Dometic RM2652 Refrigerator
May 26, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
69 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
