Question about LG DLE5955 Dryer
Dryer LG DLE5955w
I have LG DLE5955w ele. dryer and just brought a year ago. The dryer check lint filter light and airflow sensor light is always on during drying circle time. I check the lint filter is clean and the dryer duct vent is also not clogged. Could you tell me what's wrong for the dryer?thank you
  • Anonymous Mar 29, 2014
    I have a Lg DLE2240w dryer. Its only about two years old and it has stop drying and the check filter light comes on. I have cleaned out the filter, and also the duct work. I called the service number and they could not tell me anything on the phone.
  • 3 Answers
Are you missing any socks? if so you need to throughly check the duct chamber in the machine, get it serviced this is a fire hadzard.
Posted on Jun 23, 2009
LG Model DLE5955W will not heat, just had it repaired about 8 months ago. Is this a common problem.
is it a sensor or heatingunit bad.if lint isnt cleaned reg it will burn out faster also.
Oct 29, 2013 | LG DLE5955 Dryer
Dryer model DLE5955W is not heating. When drying the "drying" light flashes and the "cooling" light is on steady. I turned off, turned breaker off and back on. No improvement. Checked lint filter, all...
You have one of 2 problems. There is a power problem at the power cord or the high limit switch has tripped. You will need a qualified LG technician to diagnose your situation.
Good luck
Oct 01, 2010 | LG DLE5955 Dryer
The check filter light keeps coming ob to my lg tromm dryer model dle2514w. I cleaned the lint filter and also cleaned the air duct in theback, what else could this be
Clean the vent all the way to the outside.
The dryer will take 4-5 loads to reset the filter sensor.
Mahe sure the vent is not smashed behind the dryer.
Jan 18, 2010 | LG DLE2514 Electric Dryer
Dle2532 lg dryer, cooling light is always on
I'll take a stab that you use dryer softener sheets. These will deposit a coating on the two metal sensor bars (about 4 inches long, very near the lint filter inside the drum) which prevents the sensor from "seeing" that the clothes are still wet, so the dryer jumps to the cool down portion of the cycle. Clean the metal bars off and it should work again. (note: the bars are not in the cycle if you choose time dry instead of using the automatic cycles)
Apr 11, 2009 | LG DLE2532W Electric Dryer
DRYER NOT PUTTING OUT HEAT
If you can find the wiring diagram inside the rear service panel of the appliance, follow the circuit to identify the overload sensors. There are several internal temperature sensors in the heater circuit that could be open.
Also check that the vent duct, all the way out to the discharge grill outside of the house, is not partially restricting the airflow. Note the same for the lint filter on top as well. Any restriction to airflow will cause poor or no heating problems.
Check for a good discharge of air with everything hooked up, outside where the dryer vent discharges, while the dryer is operating.
Plase feel free to reply your findings, and if you have any additional questions.
Jan 19, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
Lint filter sensor cuts off machine within 5-10 minutes.
It sounds like you might think you are sending this to Siemans? You aren't, Fixya is a self help website, people just like you helping others. Some of us are Experts on various subjects, like dryers.
Dryers need airflow and this lint filter just works out that either the temperature is getting too hot, or there is not enough airflow.
Trouble spots are usually the following;
Exhaust hoses too long.
Sharp bends on hoses.
Birds nests in hoses. Happened to me twice!
Wet lint build up as the hot wet air hits the first bend.
Plastic concertina hoses are really bad for air flow. Use the aluminium ones that are almost smooth.
Or my guess in your case, is vent flaps that are not opening fully or blocked. The whole external assembly with flaps and tube should be changed about every 5 years
Apr 24, 2017 | Siemens WTXD5300US Electric Dryer
LG Dryer DLE5977B is putting out hot air,but clothes not drying. Check filter light is blinking. Nothing in lint filter. Checked entire vent system all the way outside. Nothing is obstructing it. ...
Go to www.repairclinic.com and enter DLE5977B. With luck, you will be presented with a list of common replacement parts and may be able to view a generic LG video showing disassembly. From this information, you may be able to pinpoint the cause of lint backup into your dryer.
Dec 19, 2017 | LG Dryers
Dryer overheat and stoppping too soon
Yes, dryer sheets can cause a build up on the sensors and the lint filter. Clean the metal contact strips off (just inside the door) with alcohol or windex and use a toothbrush and a little soap to scrub the lint filter. With the build up you don't get proper airflow and it won't dry right. Also, stop using dryer sheets or be sure and clean the cotacts and filter about once a month.
Feb 22, 2008 | LG DLE5977 Electric Dryer
My LG dryer will not power up
check the door switch or the actuator for the door switch. hope this helps.
Oct 27, 2007 | LG DLE2514 Electric Dryer
LG Gas Stacking Dryer
Check the vent and make sure it is not plugged with lint. Make sure the vent hose is clear. The light is telling you something blocking the airflow. You might not be able to see it easily.
Jun 18, 2007 | LG DLG2524 Gas Dryer
LG DLE5955 Dryer Logo
1,469 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
