Brivis heater code 65. How to reset - Heating & Cooling
2 Suggested Answers
SOURCE: brivis central heating problem code ''busy 40 H1
Hi, i recently had the same problem with mine and found that the inside adapter was unplugged. I plugged it back in and all is working find, so if anyone has the "Busy Hi 40" message on the control box the check the adapter :)
Posted on Dec 21, 2010
Brivis error code 62 hi
Hi Matthew,
It would seem obvious to contact the manufacturer's customer support department. http://brivis.com.au/
Aug 01, 2015 | Heating & Cooling
Brivis central heater code 65 with spanner
Are you having trouble with the code? The heater should have come with one. If you need to, call the manufacturer.
Elisa Jed ' http://www.manwill.net/heating.php
May 10, 2014 | Heating & Cooling
Brivis heater spanner showing with ho1 code 65
It is a flame loss error. Open the unit up Clean both of the flame sensors with either a file or steel wool (with the power off) then turn power back on and reset the screen to do this hold down all 3 buttons for 10 sec. there should be 2 buttons on one side and 1 on the other. hope this helped :)
Brivis heater HX 231-XA error code 58
I just called a technician out for a Code 58 error and it started working fine after he reset the controller. He checked for a blockage in the condensation pipe but it was clear so a bit of a mystery.
Apr 25, 2012 | Heating & Cooling
Hi I have error code 30 H1 on my Brivis heater, The problem is the fan sometime speed up itself
my power went out last night and today the heat was not working just the cooler , l turned off the main to the heater and the main power and reset the unit but is still the same
Mar 23, 2012 | Heating & Cooling
Hi i have a brivis eh 30 unit that comes up with error 65 and 30 the display inside the unit says fan limp, if i reset it from the unit it works for about 1 hr then the same thing can anyone help please
Hi. Here are the error codes for your Brivis Heater. Error Codes 30 - relating to speed sensor, 40 - overheating, 65 - motor lock-out. Usually resetting the unit will resolved the issue. In your case, you already reset the unit and problem came back. This will require immediate attention by Brivis technician.
Jul 12, 2010 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Brivis Heater help
These Brivis guys and girls are a rip-off. They are only out to take your money. Then can easily ask you to do just as mentioned above. And pronto all works in 3 minutes to be precise.
It is just the power supply reset required due to a fult being detected, either caused by a very low setting on the controller less than 16 degs. or a higher than 25 degs. setting causing overheating when the damper outlets are mostly closed.
So, put the power supply to heater off first, reset the heater panel, press the button again to shaow EMS on and then set the heater to the required temp. after turning on to the heating mode. That simple! That is if it is the error 71 HI.
Jun 01, 2008 | Heating & Cooling
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
