Question about GE WBSR3140DW Top Load Washer
Loose noisy tub
Is it easy to fix---where can I get a manual to know best how to take this thing apart GE WWSE5240GOWW
  • 121 Answers
This page will show how to take it apart http://www.appliance-repair-it.com/GE-front-loader-washer.html
Posted on Sep 07, 2010
Why does my hot tub keep making noise
a problem with the Heat Pump
Jul 03, 2016 | Home
Have a GE WSXH208HWW Spacesaver, Washing Basket is wobbling. What is the problem and can I fix it myself?
2 possible problems. On the outside of the tub front and on the top back are cement counter weights that are bolted to the tub. If they are coming loose, they would cause the tub to go off balance and wobble. If just the stainless inner tub is the one that wobbles, that suggests a bad rear drum bearing. The counter weight problem easy to fix once you get the top and back off and just need re-tightened. The back drum bearing is something even trained techs want to avoid. It requires removing the complete tub/drum assembly from the washer----then splitting the outer tub in half to replace the inner drum and bearing assembly. Cost for parts will be excessive and not worth the repair.
Apr 04, 2015 | GE Washing Machines
Tub is out of balance; how can I fix this?
Ge has stabilizer rubber straps at top of outer tub remove front of washer remove 2 1/4 screws to remove top 5/16 screws hold 4 corners of top rim and 1/4 in scews under top frame replace all broken stabilizers then your problem should be fixed if still loud you may have bad trans
Jan 30, 2013 | GE WHRE5550K Top Load Washer
Very noisy shakes moves
a few things to check is the tub actually rides on some guides make sure one has not broke or come apart... next make sure the tub has not came loose from the shaft area. g.e. has had alot of problems with a nutt they were using fastening these things down. repost with model number and is this a front load or a top load unit... someone will be glad to help you out....
Jan 06, 2011 | General Electric Washing Machines
I have a GE Select Top loading wash machine that is making alot of noise during the spin cycle. 99/2000 model
If it sounds like a jet plane taking off, a grinding noise, it is the bearing. This is pretty difficult to replace. If you do attempt it, you MUST replace the inner tub seal. This is leaking onto the bearing, causing it to go bad.
Jan 18, 2010 | GE WBSR3140DW Top Load Washer
Tub has a wobble in it . front seems loose.
Could be loose bolt @ back of pulley or Drum bearing gone which makes drum very noisy on spin expensive to fix..
Oct 03, 2009 | Whirlpool GHW9100L Front Load Washer
Front panel of washing machine is loose when spinning
I had a Sears repair guy come out, and it turns out that one of the shocks had come loose, causing the tub to be unbalanced and spin without the support it needed to stay still!! When the front panel was opened up, I could see that one of the supports holding it up was not in place, so it was an easy fix! Now it works wonderfully!
Aug 24, 2009 | Kenmore Elite 45986 Front Load Washer
Big nut that holds tub and agitator in place keeps coming loose
Try to put some red thread lock on it. Red is permanent and blue is not permanent. I would use the red if you do not need to take apart again.
Good Luck
Dec 29, 2008 | Washing Machines
Marvin 5460
Returned to home depot. Fan was broken.
Feb 08, 2008 | Marvin Quartz Radiant Heater
GE WBSR3140DW Top Load Washer Logo
338 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
