Question about Nokia E51 Cellular Phone
Why using dc - Nokia E51 Cellular Phone
Can AC and DC Power Modules Be Used in the Same Switch?
Fixed Switches Product Series Model AC and DC Power Module Mixing S3700/S5700/S6700 S3700-26C-HI Supported S5710-28C-EI Supported S5710-52C-EI Supported S5700-28C-HI Supported S5700-28C-HI-24S Supported S5700-EI (non-PoE) Supported in V200R005 S5700-SI (non-PoE) Supported in V200R005 S6700 Supported in V200R005 S5710-HI AC and DC power modules cannot be used together, but 350 W and 1150 W AC power modules can be used in one switch. S5720-HI Supported Modular Switches · When a switch does not use a PoE power module:
AC and DC power modules cannot be used together in the same type of power slots. Power modules with different power values cannot be used together either.
· When a switch uses a PoE power module:
Version PoE Power Module System Power Module V200R005C00 and earlier versions AC AC DC power module not supported - V200R006C00 and later versions AC AC DC DC AC DC ·
AC and DC power modules cannot be installed in the slots of the same type (system or PoE) in the same switch, and the power modules of different power values cannot be used in the same switch.
S5720 Switch Thunder link com
Oct 27, 2016 | AC Cars & Trucks
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
Dc voltge use
Dc stands for Direct current its a constant non varying current
the only disadvantage is it will now able to travel over a long distance
http://www.instructables.com/answers/Why-DC-current-is-not-used-in-Homes What Are the Uses of Direct Current eHow Why do we use Alternating Current AC instead of Direct Current DC in power...
Jun 17, 2015 | Miscellaneous
I have a Hasee e130 notebook and it does not recharge the batteries. First I thought it was the battery but the same battery recharges on other notebooks. How can I solve the problem ?
when you charged the battery on the other notebook did you use your notebook's ac-dc power adapter unit. I would try using the other notebook power ac-dc adapter on your notebook or get a voltmeter set on DC voltage 20volt range and test your notebook AC-DC adapter produces the required DC voltage of the Notebook requirements.
Jun 12, 2015 | Computers & Internet
Label parts motherboard
1) AC adapter (Charger) checks to be good?
2) DC Power Jack checks to be good?
(DC_IN.
The jack on the laptop that the AC adapter plugs into)
3) Then the problem is more than likely the Power MOSFET's on the motherboard.
May also include electronic components, that support the P.MOSFET's, too.
Multi-Layer Ceramic Capacitors (MLCC), that are SMD/SMT, just like the Power MOSFET's.
(Surface Mount Device/Surface Mount Technology)
Using the HP Pavilion dv6000, and Pavilion dv9000, series of Notebook PC's for an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
For these laptops the Fairchild Semiconductor Industries - FDS6679 - Power MOSFET is used, and the Alpha & Omega Semiconductor LTD - AO4407 - Power MOSFET, is used.
http://www.mouser.com/Search/Refine.aspx?Keyword=FDS6679
http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/FDS6679AZ/?qs=sGAEpiMZZMshyDBzk1%2fWi1qxDdW%2fXBi2qgMuZEfLVO4%3d
http://www.mouser.com/Search/Refine.aspx?Keyword=AO4407
http://www.mouser.com/ProductDetail/Diodes-Inc/DMP3020LSS-13/?qs=%2fha2pyFadujguNNSgppBRqXbOxXLwzGsZm9SWxz1EqWpzoSJOpHpWA%3d%3d
Where the DC Power Jack is soldered to the motherboard, is the DC - DC circuit on the motherboard.
If the laptop uses a DC Power Harness, the DC to DC circuit is where the DC Power Harness plugs into the motherboard.
[Some models of laptops have a DC Power Jack, that has a small harness of wires coming off of it.
These wires end in a small male plug connector. The male plug connector plugs into the motherboard.
DC Power Harness ]
http://www.youtube.com/watch?v=3NN7UGWYmBY
http://en.wikipedia.org/wiki/MOSFET
http://en.wikipedia.org/wiki/Power_MOSFET
Regards,
joecoolvette
May 16, 2013 | IBM ThinkPad Computers & Internet
I HAVE LOOKED EVERYWHERE FOR A BATTERY FOR MY ADVENT DIGITAL CAMERA (ADV 1182E) BUT NO LUCK. CAN ANYONE TELL ME IF ANOTHER BATTERY CAN BE USED??.
Three years ago a guest on FixYa wrote this:
quote
Here's a list of cameras that use the same battery.
ADVENT:
ADV1172E
BENQ: BENQ:
DC C500, DC E43, DC E53, DC E63+, DC E720 DC C500, DC E43, E53 DC, DC E63 +, DC E720
KONICA MINOLTA: KONICA MINOLTA:
DiMAGE E40, DiMAGE E50 DiMAGE E40, E50 DiMAGE
PREMIER: PREMIER:
DS-4331, DS-4346, DS-5330, DS-5341, DS-6330, SL-6, SL-63 DS-4331, the DS-4346, the DS-5330, the DS-5341, the DS-6330, SL-6, SL-63
ROLLEI: ROLLEI:
Prego DP4200, Prego DP5200, Prego DP6200 Prego DP4200, Prego DP5200, Prego DP6200
End quote
Nov 27, 2010 | Cameras
865 MOTHER BOARD VOLT OUT PU PIN
Hi Dear, well, you can get 1v dc or 1.5v dc from any pc motherboard but I'll never recommend you to do that. You can use Black and Red wire combination to get 5v dc or Black and Yellow wire combination to get 12v dc from motherboard's power supply. 3 LEDs in series can b use for 5v dc input.
Mar 31, 2009 | Intel D865GBF Motherboard
Nokia E51 Cellular Phone Logo
12 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
