Question about Rowenta Commercial Garment Steamer - White
My rowenta 1S7850 leaks under water container
2 Suggested Answers
bigguy810
  • 448 Answers
SOURCE: My Rowenta 1s7850 will produce
you have a blockage its not getting the water when you first turn it on its using the water that got by you will have to dig deeper in to it you can ether try disassembling your self or send it out for repair this is common after they sit in the closed position the hose gets hard and wont open
hope this helps you
bob
Posted on May 14, 2011
Rowenta superpress DG 050 leaks water while steaming all over garment. Do I need to Descale the unit?
I've had the same problem with two Rowenta irons. When set to a lower temperature, the iron has a bad habit of leaking water when the steam option is on. I have to either turn up the temperature setting or shut off the steam option.
Feb 28, 2015 | Rowenta Irons
IT LEAKS WATER OUT OF THE BACK AND BOTTOM
There might be a crack or the water sealed container isnt sealed correctly so you can either take apart your iron and calk it with water proof sealant or you can buy a new one before you get electricuted
Jan 02, 2010 | Rowenta Professional DX8800 Iron
I have a rowenta iron that leaks a lot of water
Here's a solution . . . Do NOT buy ROWENTA! I've had 3 Rowenta irons. All of them have eventually began to dump water out of the base. . . heck, the Titanic didn't leak as much as a Rowenta iron!
Dec 31, 2009 | Rowenta Perfect Iron
Water leaks
poly seal{white} perished where comes from tank to element plate
Nov 17, 2009 | Irons
My Rowenta iron is leaking down by the cord. can
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Oct 16, 2009 | Rowenta Professional DE880 Iron
When I first begin to iron, water comes out in wide streaks on the garment Sometimes the water will leak out the bottom of the iron, not from the plastic container, but out a crack in the metal part on the...
It sounds like the iron that I had about 8 years ago. I would return it before the warranty runs out and get your money back. I would recommend a phillips G4430. you will love it
Sep 09, 2009 | Rowenta Irons
Rowenta model 1700W. Water leaks out front of iron
heatman101
Mar 23, 2009 | Rowenta DZ1700 Iron
Iron leaks water from the back end of the base
This problem is the way that rowenta seals the water tank. If the iron is disassembled and the seal is properly put on it will not leak,, however this seal is a silicone based product and not just an off the shelf gasket. I have sealed and repaired some using a high temp silicone
Sep 26, 2008 | Rowenta Power Duo Iron
Rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Jul 22, 2008 | Rowenta Commercial Garment Steamer - White
Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Jul 14, 2008 | Rowenta Perfect Iron
Rowenta Commercial Garment Steamer - White Logo
43 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
