Question about GE EasyCam Webcam
Usb video capture windows 7 64 bit - GE EasyCam Webcam
Tip
For better video quality with EasyCap USB video capture card:
1. Install FFDShow codecs to Your Windows: http://adf.ly/1310198/ffdshow-codecs
2. Use gold plated cables and adapters - s-video is normally a little bit better than composite
3. Check that all contacts between devices, cables and adapters are tight enough
4. Do not use any extension USB cable - put EasyCap/EzCAP straight to the computer's USB port
5. Switch off all other programs during capturing
6. Capture with max resolution 720x576px PAL, 720x480px NTSC.
7. You must have a powerful computer - check that CPU Usage is under 50% during
capturing and if it goes over, so buy more RAM and/or better processor and/or
better graphic card and/or faster hard drive.
on Mar 13, 2014 | DekCell EasyCap USB 20 Video Capture...
Logithec attack3 devices not detected
Disconnect the divice uninstall the driver restart the laptop and then reinstall the driver again restart the laptop then connect the device it works.
Apr 03, 2014 | Video Game Consoles & Games
I have an usb 2800D capture device that worked well on a 32 bit basis windows vista. When I changed notebook to one on a 64 bit basis windows 7, I looke for a compatible driver to my device. I found it...
the drivers might not be installed correctly for this device you might have to uninstall video capture device restart your computer then reinstall it also
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver
hope this helps you
Aug 20, 2011 | KWorld Xpert DVD Maker USB 2.0...
Usb emp audio device cannot start code 10 error message appears in device manager. also usb device does not show up for a device when I launch video studio
Hi lynnembryant,
Your problem seems to be related to the driver your capture card uses. I would recommend updating them.
Here are the links:
For Windows XP, Vista and 7 32 bits : http://sabrent.com/drivers2/USB-AVCPT-32bit-XP-Vista-Win7.zip
For Windows Vista and 7 64 bits : http://sabrent.com/drivers2/USB-AVCPT-64bit-Vista-Win7.zip
You seem to need another driver as well for the audio, here it is : http://sabrent.com/drivers2/USB-AVCPT-USB-EPM-286x.zip
You might also want to check their support website here : http://sabrent.com/support/.
Cheers!
Mar 01, 2011 | Sabrent USB-AVCPT Video Capture
Does Sabrent USB-AVCPT video capture interface have Linux support?
This unit is only supported by the company for Windows 2000, XP, Vista amd Win7 (32- or 64-bit).
I hope this helps.
Sep 20, 2010 | Sabrent USB-AVCPT Video Capture
Easycap i can't intall thediviceEasycap capture model no..DC60
I have checked these files and they appear clean to me.. please exercise caution and scan them yourself.
32 bit driver
http://jartim.wippiespace.com/Programs/STK1160Drivers.zip
UNOFFICIAL 64 bit driver
http://jarmot.wippiespace.com/Drivers%20for%20Vista%2064bit.zip
64 bit Vista and Windows 7 driver
http://www.sabrent.com/drivers/USB-AVCPTSetup_For_Win7.zip
Aug 05, 2010 | DekCell EasyCap USB 20 Video Capture...
Upgrading to Windows XPx64
The answer is no because your motherboard still only supports 32 bit drivers. Read On.
Here's what you need to use Windows XP Professional x64 Edition
Important: Windows XP Professional x64 Edition cannot be successfully installed on x86 (32-bit) systems or 64-bit Intel Itanium–based systems. 32-bit device drivers are not supported on Windows XP Professional x64 Edition.
• Computer with a supported processor: AMD Athlon 64, AMD Opteron, Intel Xeon with Intel EM64T support, Intel Pentium 4 with Intel EM64T support
• 256 megabytes (MB) of RAM or higher recommended
• 1.5 gigabytes (GB) of available hard-disk space (additional space may be required if installing over a network)
• CD-ROM or DVD drive
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• Keyboard, Microsoft Mouse, Microsoft IntelliMouse, or compatible pointing device
arrow_px_up.gifTop of page Additional items or services required to use certain Windows XP features • 28.8-Kbps modem or fax modem and service provider required for Internet access (service provider may charge a fee)
• Sound requires a sound card and speakers (USB speakers require a computer with USB support) or headphones
• Remote Assistance requires that both parties be running Windows XP and be connected over a network
• Remote Desktop requires a computer running Windows 95 or later and the two computers must be connected over a network
• DVD video playback requires a DVD drive and DVD decoder card or DVD decoder software and 8 MB of video RAM
• Windows Movie Maker video capture feature requires an appropriate digital or analog video capture device and 400-MHz or faster processor for digital video camera capture
May 09, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
GE EasyCam Webcam Logo
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
