Question about Dishwashers
Bosch classixx disshwasher stops and check water appears
SOURCE: check water
very possibly you have a faulty water flow switch. If a certain flowrate is not detected within a certain time, that light would come on
Posted on Mar 27, 2008
SOURCE: check water indicator remains illuminated
caused by anti flood device. machine had water in base caused by minute leak on input hose dribbling down into machine.
Posted on Apr 22, 2008
  • 457 Answers
SOURCE: Bosch Classixx Dishwasher stck in one program
the module must be changed. let me know what happens. im a old bosch tech
Posted on Feb 26, 2010
  • 167 Answers
SOURCE: bosch classixx dishwasher saying check water also
Bosch dishwashers have a food filter to catch food particles. You have to clean it occasionally, or it plugs up and stops water flow. This could be your problem. (Most other makers use a little grinding blade to finely chop the particles so they can be sent down the drain.)
Posted on Oct 04, 2010
SOURCE: Bosch Classixx Dishwasher -check water light keeps coming on
thanks i empied my dish wisher old water then it word again thanks Neil Spink
Posted on Apr 27, 2011
Why my bosch classixx keeps stopping every 5 minutes
The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 13, 2014 | Bosch Classixx WVF 2402 Front Load...
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx dishwasher wont drain
Ive had this happen on mine too. remove the filters in the bottom. squirt washing up liquid into the space-- liberally dont be shy!
Boil pans of water, boil the kettle. pour water into the space where the filters normally are. Fill the base of the dishwasher completely. Next close the door and repeatedly use the Reset feature. Eventually the pump will clear and kick back into life. Its a build up of fats, and sludge that causes the pump to appear to seize--the washing up liquid and boiling water see to that.
Feb 05, 2012 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx dishwasher saying check water also not washing or spining
Oct 04, 2010 | Bosch 24 in. SGS43C12 Classixx...
Apr 14, 2010 | Bosch 24 in. SGS43C12 Classixx...
My classixx has stopped spinning and draining water.I have already checked the pump.Its clear.
If it is not draining the water, then either the pump is faulty, or there is a blockage in the outlet hose from the pump, or possibly a blockage in the hose from the drum to the pump.
Mar 24, 2010 | Bosch Classixx WVF 240S Front Load Washer...
My bosch classixx 1200, my washing machine leaks when not in use, to solve the problem i have had to have a valve fitted to the pipe that feeds water into the machine and keep switching the valve down to...
Remove top and check that they are your fill vaulves. Your hoses should be connected to them if so.If they are leaking on inside of machine when off then they need replacing.
Mar 15, 2010 | Bosch Classixx WFC 2465 Front Load Washer
Bosch classixx 1200 It take in water then stop. I can drain it but it will not spin.
It looks like there could be a problem with a belt, maybe it sliped off, or maybe it broke, i would look that first
Nov 04, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
Dec 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Dishwashers Logo
11 people viewed this question
Top Dishwashers Experts
