Question about Lutron Maestro MS-0PS5M-WH - White - Single Pole or 3-Way - Occupancy Sensor - Auto OFF and Auto ON - For Incandescent, Halogen, ELV, MLV, Fluorescent, CFL, and LED Lights
Automatic light sensor without a ground wire - Lutron Maestro MS-0PS5M-WH - White - Single Pole or 3-Way - Occupancy Sensor - Auto OFF and Auto ON - For Incandescent, Halogen, ELV, MLV, Fluorescent, CFL, and LED Lights
My 1995 dodge caravan trys to start but wont im getting no spark to my spark plugs
Hi mate start at the easiest point which will be to check your EARTH to make sure everything is earthed.
Feb 06, 2015 | Dodge Cars & Trucks
I have a 2000 gmc sonoma and my head lights won't turn on all the bulbs are good fuses are good I checked the grounds seem to be putting off good ground the head light plugs however are is a 2 pin...
Check the power to the light switch.. And also check wire continuity. Are the lights also automatically controlled by ambient light sensor?
Nov 12, 2014 | Cars & Trucks
2003 subaru 2.5 litre automatic wont start
The hum is likley your fuel pump priming the fuel delivery system. I would start looking at the wiring coming from the Throttle Position Sensor. With the key in the ON position, you should be getting a 12vDC (or a little higher) signal to one wire and an excellent ground on another (usually the center if there are 3). If you are missing a good ground or the 12v signal, there lies your problem. Good luck.
May 01, 2014 | 2003 Subaru Baja
Can't find the relay for the electronic level control(elc) for a 1999 cadillac eldorado
1. Locate the automatic level control height sensor under the rear of the vehicle on the rear suspension support. If the back of the car is too low and will not pump up, ground pin B Yellow wire and see if the compressor will come on and the car will raise.
2. If the car does raise when pin B is grounded, check the powers and grounds to the height sensor.
3. If the powers and grounds are OK and the pump does come on and the car raises when pin B is grounded, the height sensor will need to be replaced.
4. If the car is too high and will not come down, ground pin E White wire at the height sensor to see if the car will lower.
5. If the car lowers when the White wire in pin E is grounded, check the powers and grounds to the height sensor.
6. If powers and grounds are OK and the car does lower when pin E is grounded, the height sensor will need to be replaced. Tech Tips: There are two different automatic level control systems for this car; one is without RPO F45 and one is with RPO F45. The system without F45 has an automatic level control height sensor and with F45 the automatic level control compressor is controlled by the continuously variable road sensing suspension module. Tests/Procedures: 1. Using a head lamp as a load, test the ELC height sensor power/grounds.
2. The power feeds are: Orange wire, pin C and a Brown wire, pin D.
3. The ground is pin A, Black wire.
4. Ground the White wire at the height sensor, check that the vent solenoid in the ELC compressor clicks and vents the air from the system. Author: Bill Siegmann
Dec 24, 2012 | 1999 Cadillac Eldorado
Motion sensor light wiring
problem could be sensor, not light, black is power, white is neutral, green is ground, sensor may have a red wire, black wire and a white wire, hook black wire to power from sensor, red to black wire on light,
white wires will connect together, then wire black to power on home, white to white on home and green to ground, if you need help call an electrician and they will wire it for you
Feb 03, 2012 | Home
I have a goodman GMPN120-5 funace, it comes on automatic lights okay, then burns for about 3-6 seconds and snaps off. I have changed the flame sensor. Is there anything else I can do to it, short of...
The flame rod needs a good ground and it's ground is thru the circuit board. Other than resecuring the ground wire on the circuit board, you will be looking at a new board.
Nov 28, 2010 | Goodman Heating & Cooling
There is no spark at the spark plugs and tahoe wont start
First check power to the coil. Pull the connector off and probe the connector terminal from the pink wire with a 12 volt test light. Connect the test light clip to a ground point/bolt on the engine. The test light should come on when the ignition switch is on. If not, suspect the ECM-1 fuse is bad or the ignition switch is bad.
If there is power to the coil, next test the coil. Run a jumper from the battery positive terminal to the pink terminal on the coil itself. Pull the coil wire off the distributor and place the wire close (within 1/4 inch) to a ground point on the engine. Then, briefly touch a jumper from the black/white coil terminal to engine ground. The coil should release a spark. If not, replace the coil.
If the coil is good, suspect the crankshaft position sensor is bad or loose. I'm assuming your engine light is off, but the sensor can fail without setting the engine light. If the engine light is on, see if you can get a scan to see if a crankshaft sensor trouble code is set.
Please let me know if you have any questions.
Nov 03, 2010 | 1997 Chevrolet Tahoe
My check engine light turned on my 2006 mitshbishi montero it gave an p0057error codr..what do I need to do
The 057 code means " bank 2 sensor 2, shorted to ground ".
Check to see if the O2 sensor after the converter has wires rubbing on the frame. Worn insulation with wire shorting to ground?
Bank 2 means the side without the #1 cylinder.
Sensor 2 means the oxygen sensor downstream from the catalytic converter.
Jul 08, 2010 | 2006 Mitsubishi Montero
Headlights go on and off while driving
Could be just a bad ground wire,
Nov 30, 2009 | 2000 Toyota Sienna
Lutron Maestro MS-0PS5M-WH - White - Single Pole or 3-Way - Occupancy Sensor - Auto OFF and Auto ON - For Incandescent, Halogen, ELV, MLV, Fluorescent, CFL, and LED Lights Logo
71 people viewed this question
Top Lutron Home Security Experts
Lawrence Oravetz
Are you a Lutron Home Security Expert? Answer questions, earn points and help others
