Question about Texas Instruments TI-83 Plus Calculator
How to fix an invalid dim error on an ti 83 calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If this doesn't fix it, please reply to this post and tell us what you're trying to do when you get this error.
Posted on May 11, 2014
3 Suggested Answers
  • 88 Answers
SOURCE: cannot graph invalid dim error
This error show up when you are graphing out of the plot menu. If you are not graphing data points from list menu, you need to turn the plots off. In the y= screen, you will see the words plot 1, plot 2, etc across the top of the screen. If one of the plots is highlighted (black box over the words), you need to turn it off. This can be done by arrowing up and highlighting the box and pressing enter. When you arrow back down, the plot should be off and you will be able to enter an equation in the y= lines and graph.
If you are graphing from the plot menu, this error lets you know that one of the lists you are graphing is longer than the other.
Another way to fix the problem is to reset the calculator by pressing 2nd button then plus sign then 7 then 1 then 2. This will reset the calculator however if you are graphing from lists, your data will be erased. Hope this helps.
Posted on Oct 03, 2009
  • 7993 Answers
SOURCE: On my TI-83 plus calculator when i tr to using the
The solution for the problem is simple. When you use the calculator to create statistical graphs, it is configured to accommodate the specificities of the problem. However that configuration remains set after you terminate the problem. So when you try to use the calculator to do other problems it uses the stored configuration parameters, which may be incompatible with the new problem.
In particular, list of paired-variables must have the same dimensions: There must be the same number of elements in each list.
To make a long story short, you should make it a habit to reset the Ram everytime you want to do a new problem. If for reasons of you own you do not want to reset the Ram, you can prevent this type of errors from occurring. This is how you do it.
  1. Press [2nd][Y=] (STATPLOT)
  2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
  3. Press [2nd][0] (CATALOG)
  4. Press [PGRM] (C) to jump to first command that starts with c.
  5. Use arrow to scroll down to ClrAllLists, select it [ENTER]
  6. Calculator displays Done
  7. Start the new problem
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
Posted on Jan 16, 2010
Ti-83 error message invalid dim
Nov 21, 2013 | Texas Instruments TI-83 Plus Calculator
Invalid dim?
The ERR:INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat
plots. To turn the stat plots off, press {2nd}[stat plot], and then select 4:Plots Off.
Jan 23, 2011 | Texas Instruments TI-83 Plus Calculator
Ti 83 error message invalid dim
If that's not it, please reply to this post stating just what you did to generate this error message.
Oct 01, 2010 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus Calculator: My TI-83 reads "INVALID DIM" when I try to graph a...
May 17, 2010 | Texas Instruments TI-83 Plus Calculator
The graphing function on my ti-83 isn't working. i have reset all the parameters, but i keep getting an "invalid dim" error. ideas?
Hit 2nd then hit mem then scroll to all and click yes. This will master rester everything and restore it to factory settings.
Dec 04, 2009 | Texas Instruments TI-83 Plus Calculator
How do I clear ERR: INVALID DIM
Reset memory to default, the error will disappear.
[2nd][MEM][7][2][2] Defaults set.
Hope it helps
Sep 10, 2009 | Texas Instruments TI-83 Plus Calculator
Error invalid dim
Hope it helps
Sep 06, 2009 | Texas Instruments TI-83 Plus Calculator
INVALID DIM error! help me!
Here is what the manual says
INVALID DIM : The dimension of the argument is incompatible with th current operation. (As dimension of a matrix, a list).
You can tell us more about what your were trying to do, we may able to help. Reset memory to default, the error may disappear.
Hope it helps.
Sep 02, 2009 | Texas Instruments TI-83 Plus Calculator
Calculator
Well it seems that you are graphing stat points and forgot to turn them off. This can be easily fixed by going to 2nd and Stat Plot then make sure all the stat plots are turned off. This should solve your issue.
Sep 03, 2008 | Texas Instruments TI-83 Plus Calculator
Error message
I got the solution from someone else. Here it is:
http://www.lcc.edu/mathsci/calchelp/topic6.htm try this website. Scroll down to step number 5. Works great :-)
Aug 30, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
26 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
