Question about Fujitsu Computers & Internet
Windows 7 activator - Fujitsu Computers & Internet
How do I activate windows 7?
Like this Sandra
To check your Windows activation status, do the following: Open System by clicking the Start button , clicking Control Panel, clicking System and Maintenance, and then clicking System.
Under Windows activation, you can view your activation status. You can also change your product key by clicking Change product key.
http://windows.microsoft.com/en-ca/windows/activate-windows#1TC=windows-7
http://windows.microsoft.com/en-ca/windows/activate-windows#1TC=windows-7 Activate Windows on this computer Windows Help
Mar 26, 2016 | Microsoft Windows 7 Home Premium 64BIT...
Tip
How to Extend Windows 7's expiry date to 120 days.
‘Rearm’ trick on Windows 7 is done using the similar commands and steps withWindows Vista. Follow these steps to reset and extend activation grace period from 30 days to 120 days in Windows 7:
Install Windows 7 without any product activation key.
After installation is completed, use the Windows 7 for 30 days and wait for the remaining days left to activate Windows counting down to 0, or almost zero.
When the activation grace period (or evaluation trial period) is almost expired or ended, log on to Windows 7 desktop, and open a Command Prompt window (i.e. type Cmd in Start Search and hit Enter).
Type any of the following commands into the command prompt, and then hit Enter:
sysprep /generalize
slmgr.vbs –rearm
rundll32 slc.dll,SLReArmWindows
slmgr /rearm
Reboot Windows 7 to enjoy another 30 days of free usage without worrying about activation nor even need to crack Windows 7.
When the activation grace period countdown timer almost running down to 0 again, repeat the ‘rearm’ trick to enjoy another 30 days of Windows 7 for free. User can run the rearm command for maximum of 3 times.
on Mar 08, 2010 | Computers & Internet
Can't get old connection icon back on taskbar
From LifeHacker:
Windows 7: If you miss having a network activity icon that actually indicates if your network is active or not, this handy little hack will swap the static Windows.
The solution is a tiny application called, Network Activity Indicator for Windows 7. Download the application and park your standard Windows 7 network indicator in the hidden portion of your system tray, placing the icon for the Network Activity Indicator in the appropriate place in the system tray. If you'd like step-by-step instructions with pictures on how to do this, check out the via-link below to see the tutorial at The How-To Geek.
Once you've performed the swap, you'll have the old network activity indicator back and its familiar blinking screens. Network Activity Indicator for Windows 7 is freeware, Windows only. Have a little app that makes life easier? Let's hear about it in the comments.
Network Activity Indicator for Windows 7 [via HowToGeek]
source: http://lifehacker.com/5428229/get-the-classic-network-activity-indicator-back-in-windows-7
Sep 04, 2014 | Computers & Internet
Windows 7 activation
You will have to purchase the activation key. If your computer had windows 7 on it then the Key can be found on the case.
May 05, 2014 | Microsoft Windows 7 Ultimate for PC
How to activate windows 7
download windows 7 activator and activate it and you must activate again according to their given time
Dec 29, 2013 | MSI Computers & Internet
Activation Windows 7 Ultemate Key
Go to Control Panel \ System click on change product key then enter Valid product key and click next to activate Windows 7. you can also activate your Windows 7 online.
Jun 15, 2011 | Microsoft Windows 7 Ultimate for PC
I dont now how activate the window 7
Click the Start button (Orb in the lower left hand corner of the screen). RIGHT click on Computer and select Properties from the menu. At the bottom of the window you will see the Windows Activation section and an option to Activate Windows Now. Click on it and the activation dialog screen will appear.
Mar 20, 2011 | Computers & Internet
Computers & Internet Logo
13 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
