Question about Samsung DMR77LHS Tall Tub Dishwasher
I have an error code LE can i fix this myself
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
Apr 03, 2016 | LG Washing Machines
Fix LE error for LG washer
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective
Oct 07, 2014 | LG WT5070CW 4.7 Cu. Ft. Ultra Large...
Have a top loading Kenmore elite high efficiency washer model 796.2927, 2 years old this thanksgiving is showing erroe code LE? what do i do to fix?
On most Kenmore front load washers the LE error indicates a LOCKED MOTOR ERROR. This can be caused by:
  1. Loose motor harness connection.
  2. Failed HALL SENSOR.
  3. Failed STATOR.
  4. Failed ROTOR (cracked magnet).
Nov 06, 2012 | Washing Machines
LE in display
Hello,http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Thanks
May 30, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LE error code
Ther should be a booklet located in your machine, that will explain each error code. It is usually located in the bottom panel or up in the console.
Jan 14, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LE Error code
SOUNDS LIKE LOCKED ENGINE. SEVERAL DIFFERENT THINGS CAN CAUSE THIS ERROR CODE TO BE DISPLAYED.
1ST, USING THE WRONG SOAP WILL CAUSE THIS PROBLEM - USE HE SOAP ONLY!!! - IF YOU HAVE BEEN USING THE WRONG SOAP, BEFORE CALLING FOR SERVICE I WOULD ADVISE YOU TO RUN A FEW SHORT CYCLES WITH HOT WATER ONLY - THIS SHOULD HELP IN REMOVING ANY SOAP RESIDUE FROM THE SOAP SENSOR AND BOOT AREA.
2ND, THE CONTROL BOARD MAY BE DEFECTIVE - YOU NEED TO CHECK VOLTAGE OUTPUTS TO VERIFY.
3RD, BE SURE TO CHECK THE WIRING HARNESS - IT HAS BEEN KNOWN THAT WIRES SOMETIMES BECOME FRAYED AND LOOSE RESISTANCE.
4TH, THE SOAP SUDS SENSOR MAY BE FAULTY AND NEEDS TO BE REPLACED.
Regards
ami-man
Dec 04, 2009 | LG WM1812C Front Load Washer
Error LE
The "IE" code indicates a water inlet problem. If the correct water level is not reached in eight minutes, this code is generated. Check the water inlet valve. Unplug the machine, turn off the water, and remove the water supply hoses. Check the small metal screens inside the openings on the water inlet valve. Make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter.Check for continuity. A lack of continuity means a bad solenoid and the water inlet valve assy will have to be replaced. I'll attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Nov 17, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Samsung DMR77LHS Tall Tub Dishwasher Logo
27 people viewed this question
Top Samsung Dishwashers Experts
vince
Dale Copeland
Dale Copeland
Di Nagy
Di Nagy
Level 1 Expert
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
