Question about Ricoh Office Equipment & Supplies
What is the different between ARDF and SPDF in Ricoh
  • 135 Answers
ARDF is a two pass system meaning it flips the paper to make a two sided original scan.
SPDF is single pass meaning there is a component in the feeder that reads the second side in a single pass, thus speeding the original scan, highly recomended if you do a lot of scans.
Posted on Jun 09, 2014
Testimonial: "well explained thanks"
2 Suggested Answers
  • 24 Answers
SOURCE: Ricoh Aficio 1035 ARDF is not duplexing, why?
Hi All,
try one sided copy through ARDF, and if its work, then check the solenoid which open the bridge for second side of copy.
Posted on Oct 05, 2008
Ricoh ardf 3090 jamming
Check the papers.
Papers are good then clean the pick up rubbers with ethylated alcohol.
Apr 11, 2016 | Ricoh Aficio Office Equipment & Supplies
Ricoh aficio 3035/3045 error sc 672 not able to proceed to service mode also, kindly help me pls.
possible a bad operation panel replace or 672 B
After powering on the machine, the
communication circuit between the
controller and the operation panel is not
opened, or communication with
controller is interrupted after a normal
startup.
Controller stall
Controller board installed incorrectly
Controller board defective
Operation panel connector loose or
defective
690 A GAVD block I2C bus error
An error is detected in the GAVD
communication I2C control register of
the GABIC2.
I2C bus on BICU defective
691 A GAVD FCI block I2C bus error
An error is detected in the FCI
the GABIC2.
692 A CDIC GAVD block I2C bus error
An error is detected in the CDIC
the GABIC2.
700 B ARDF original pick-up malfunction
After the
Sep 21, 2012 | Ricoh Aficio 3045, 3035 Kit
Will only copy documents landscape no matter how you put the documents on the machine
if you are yousing the ARDF keep the document in ARDF ensure that the mater on the document is up side or you are yousing the platen glass keep the document down side on the glass thatsit - thankyou
Dec 14, 2010 | Lanier Office Equipment & Supplies
Why am I getting a black line across the pages when I scan? I did change the cartridge and it's not happening on all documents. Thank you.
you have got a dirt or marking on 2 places 1.mark on the ARDF unit exposer glass
2. on the scanner unit mirrors
check and clean both 1,2
Nov 03, 2010 | Ricoh Aficio 2018D All-In-One Laser...
Aficio 1035 ARDF cannot pick papers most likely when they are over 4 sheets
Clean the takeup roller and feed belt with a damp rad (water). If that doesn't help, you man need to replace the roller, belt, seperator belt and possibly the sep roller torque limiter.
Sep 24, 2009 | Ricoh Aficio 1035 Copier
E6 error On a Ricoh ft4022 copied paper doesn't throughly comes out
It can be some of this because you give us only the firs digit you should press "." for to see the two other digits which can be as follow:
E620 Main board – ARDF communication error
E621 Main board – Sorter communication error
E623 Main board – Paper tray unit communication error
For start you can see do the sorter or the ADF are good connected
It has two cables one is white and other is black see do they are good connected or it can be broken on some place of the cable, special the black because is optical cable.
also see do the paper tray is good entered in the machine if all this up mentioned are good then is a problem with the main board
May 13, 2009 | Ricoh Office Equipment & Supplies
Ricoh MP4000B
hi
a rijas working in dubai
my Gestetner MP 4000B nw its showing waste toner bottil is full please advice me how to solve dis problem
Feb 18, 2009 | Office Equipment & Supplies
Line on page using ARDF
Good news!! This should be an easy fix.
If the line appears only when you are using the doc feeder, and it looks like a straight line that you have drawn with a ruller, then it is on the glass. Not the large glass where the copy lays, but the narrow glass. Make a copy using the ARDF, paying close attention to it's orientation (which side is up and which is down). Then, take the copy you made and lay it next to the narrow **** glass in exactly the same direction as it went through the feeder. Wherever your line is, there is something on the glass in that spot. Take your thumb and rub with a good bit of pressure in this spot. You might not see anything, but trust me, there is something there. It might be as small and transparent as a spot of ink. A flashlight will help. You might also try using rubbing alcohol on a soft cloth to clean it. Hope some of this helps,
Chad
Oct 11, 2008 | Ricoh Aficio 1035 Copier
Call a technician, seems like the original is not making the second scan pass and thus displaying a mis-feed, cut also be a small piece of paper in the feeder bloacking a sensor, bad sensor or worn feed tires. www.mfpsolutions.blogpsot.com
Sep 30, 2008 | Ricoh Aficio 1035 Copier
3,145 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
