Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
JD 2010 PTO Problem
PTO will not spin as fast as it did before...any one know a possible cause? Also, does the tractor have to be completely split down the middle to work on the PTO?
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
wireguy212
  • 1627 Answers
SOURCE: JD 6400 tractor, PTO light flashes when engaged
The most likely problem is the pto solenoid valve on the rear of the tractor.It could be the speed sensor but you won't know until you get the codes read by the dealer.I have had to replace the b.c.u. for this problem but it is not common.
Posted on Oct 20, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere 2010 utility tractor, lights come on
1) Battery condition and clean cable connections
2) Check the voltage & connections at the solenoid
*Is full battery voltage found at the solenoid?
3) Does the small wire that activates the solenoid from the ignition switch/safety switches have voltage when the key is in the start position
a) voltage yes, but it does not start; suspect solenoid
b) voltage no, inspect and check all safety switches for voltage to and from each switch
c) safety switches do NOT have voltage to them: inspect connections on ignition switch and check for voltage coming into the switch from the battery.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 10, 2009
  • 394 Answers
SOURCE: DTY 4000 tractor dies when engaging pto, new
This is just a suggestion. Try pulling the choke out about one third to one half and then engage the PTO. Sometimes the air idle adjust screw port gets a tiny speck of debris in it. If with the choke partially out and the PTO engages the just grab a screwdriver and turn the air idle mixture screw counter clockwise a hair.
Posted on Apr 30, 2010
Testimonial: "Hit on the head with such a simple solution"
miket756
  • 2702 Answers
SOURCE: engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
Posted on May 02, 2010
JD ltr180 stalls when blades engaged
if it has an electric pto for the blades, it is possible that by engaging that pto, there is not sufficient power left to run the engine
check charge rate , battery condition and pto system
Jun 30, 2016 | Garden
JD 1026R tractor. Why the PTO does not work?
many of this type machine will not engage the PTO if the battery is not full charged or bad
Apr 17, 2016 | Garden
Jd 3020 power shift pto turns all the time. if lever not engaged a heavy load can stop it. otherwise it works ok
The pto brake is either worn out or you have no presure to it when the pto is turned off,most likely the pto brake is worn out.
Nov 03, 2009 | John Deere 3010,3020 Tractor Basic...
JD 6400 tractor, PTO light flashes when engaged but PTO does not work.
Aug 30, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
Battery lite glows when pto is engaged after running for 5min
The charging circuits used on smaller tractors are generally barely adequate for the load presented to them, so it is important that the tractor engine is running fast enough especially when using PTO power. If your tractor has a tachometer on it, JD has an indication of the motor speed you should use when using the PTO. If not, it is generally pretty close to max. It should sound like it is running smoothly although fast, and not with whining or rough sounds from the engine.
Apr 30, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
234 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
