Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport f21 pump rattling
Already drained the filter in the bottom
SOURCE: Whirlpool Duet Sport Washer will not drain - F-21 error
Perfect! Yes, they aer 1/4" 6pt screws. I didn't have to lift my washer, but the previous tech had put in 1 screw crooked, so that was FUN! I had cut out an opening on an old cracked tote and was able to hold all the water as long as I transferred some to a bunch of tupperware. Make sure you line up the upper mark on the white drain plug before putting back in. The tote was getting overloaded and I didn't notice the alignment marks until after having some water overflow. Just a heads-up if anyone has an emergency and HAS to get the plug back in in a hurry.
I found:
Wife's Victoria's Secret panties
2 dimes
4 pennies
some legos
a metal nut
pencil eraser
wall anchor
some legos
Posted on Jun 30, 2008
Lumpy816
  • 246 Answers
SOURCE: whirlpool duet sport washer trouble codes
F21 is a drain error code. You likely have something stuck in your pump. Remove the lower front panel. (there are 3 #20 torx screws on the bottom of it holding it on) Once you have the panel off, the white object in the front center is your pump.
Remove the #20 torx screw out of there to make life easier. Slide the pump forward slightly so you can raise it. Now, on the front of the pump is a handel that you will need to turn counter clockwise. So after placing something underneath to catch
the water left inside the machine ( a large bowl or bucket), turn the knob slowly counter clockwise. If there is too much water for your container, screw it back clockwise and go empty your container. Repeat until all of the water is out. Once that is done, unscrew it all of the way and slide if forward. You will usually find missing socks, toys, coins and all other kinds of fun objects. While you have the trap out, reach in with your finger to the hole on the right. Try and turn the wheel inside to make sure there isn't anything keeping it from turning (bobby pins, nails,
screws, etc) If there is, you will need to unclamp both hoses on the back of the pump and remove any further forign objects. Now re-assemble the unit but leave the panel off. Run a quick fill and drain to make sure all of your connections are tight and
you don't have any leaks. Put your panel back in and you're ready to go.
Please make sure you post a rating if this solution was helpful.
Posted on Jul 25, 2008
SOURCE: f-21 error, washer not draining
I have had this code three separate times. The first time service man came and cleaned out the filter. This is behind the lower front panel and can be removed by hand. The cartridge style filter is located at the pump in the lower right of the unit. Have something available to catch the draining water as you loosen the filter. The second time I received this code I found a blockage in the drain hose at its bend. The third time no hose blockage, no filter clogging, but the pump impeller was jammed by an elastic strap that had made it through the filter. I removed it through the supply side of the pump seen after filter is removed.
Posted on Aug 13, 2009
SOURCE: Problem with F21 code on whirlpool duet sport
i had the same problem. take the bottom cover off of the front of the washer. on the right you will see a round white screw off cover, it is very tight, it unscrews counter clock-wise. pull this out and see if there is any debris in it. if you look into the hole on the right side there is a hole about 1 inch round, this is the pump opening. you may have to take the gray drain hose off of the back of the pump housing and feel if anything is stuck in there, in my case there was a penny stuck side ways blocking the flow of water. after i took it out the washer has been running great again. this is obviously a design flaw, that something that large could manage to get that far, lucky for me it didn't damage the pump impeller. hope this helps. this should take care of the SD and the F21 error codes.
Posted on Aug 23, 2009
  • 662 Answers
SOURCE: Duet Sport Whirlpool front loading washer is
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
Posted on May 17, 2010
Whirlpool Duet Sport F21, F01, SD
Drain pump may be clogged or need to be replaced may run but not pump blade stripped in pump
Apr 28, 2017 | Whirlpool Duet 3.8 cu. ft. Front Load...
My whirlpool washer duet sport is not draining water out and displays error code f-21
Hi
Thanks for using FixYa. Error F21 indicates long drain, this error occurs when the drain time exceeds 8 minutes. To resolve this check the drain hose and make sure it is not kinked with any foreign particles; also clean the drain pump filter for any clogs. Also check if the pump is running fine. If still the issue is not resolved after all this then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does f21 on washer mean?
Hi, this advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F21” error code.
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the electrical connections to the pump and ensure the pump is running.
  4. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Take care
May 31, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Duet GHW9150P Front Load Washer: Whirlpool Duet Washer - Error F21 (What is this) ...
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. Door locked? Press "end of cycle" for 3 seconds, wait for 2 minutes & try the door. F-21 filter blocked.
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F21 code and leaking from behind washer where hose comes out. Already used shop vac to drain hose, got code again on cleaning cycle.
F21 is a code for Long Drain.check to see if anything is clogging the pump.If you remove the 3 1/4" hex screws from the bottom panel,you can remove the panel.Behind the panel is a large white pump.You can remove the filter and check to see that nothing is clogged inside.
Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our washer has been displaying the codes F21 and
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Nov 24, 2009 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet Sport HT front load washer keeps having F21 Error
remove the lower access panel (3 screws along the bottom of unit) behind htere you will see the pump and an access to clean the pump filter, probably filled with assorted debris. be aware when you unscrew there will be water behind it,
Nov 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Tinabell, I believe the code is the same for sport on the duets. Long drain. Usually I find this to be a clogged filter but sometimes the pump itself is bad. You should be able to find your tech sheet at http://www.servicematters.com/ or on the bottom of your machine. Click on technical reference, accept the terms, then technical library and enter your model number. You should be able to come up with the error codes. Catriver.
Jan 13, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
