I want to reboot my computer because there was virus got into my PC, but there was no reboot CD attach to it.And now I cannot use my computer because its so slow. Can anyone help me fix this problem?
I assume you mean like a factory reset? Most Dells have a recovery partition, press the appropriate key when starting your computer (when the text goes across the black screen), it's usually F12. This should take you into 'recovery mode'. Then follow the prompts.
WARNING: IF DONE CORRECTLY THIS WILL ERASE ALL DATA FROM YOUR COMPUTER AND BE LIKE IT WAS WHEN YOU FIRST BROUGHT IT!
ENSURE BACKUPS FIRST!!
Heres what you do, first TURN-ON your computer then PRESS F8 then run SAFE MODE, if the windows comes up click START then RUN, type MSCONFIG at RUN then wait the configuration comes out then select STARTUP TOOLBAR to disable all unnecessary Program that are running everytime your start normally "WINDOWS SYSTEM"... Good Luck!
