Question about Panasonic Dehumidifiers
Error code h 48
Display shows h48 and does not get start. What is the problem ?
DeLonghi DD70PE Dehumidifier. Why does pump often stop working and F/P shows an error code until reset?
id be inclined to think that for some reason the pump is taking too long to pump tank out (or it thinks it is ) this would cause the fault you describe and the safety control shuts pump off for fear of a problem
Aug 18, 2015 | DeLonghi Dehumidifiers
My humidifier stopped working after possible exposure to saline water.
does it show any kind of error code or something?
if so the problem can be half solved by knowing the error code sir
Aug 04, 2008 | Kenmore 54501 Dehumidifier
I have a Frigidaire LAD504TDL dehumidifier and code 'ES' shows on display. What does this code mean? Unit runs but not much water in tank.
Good Morning Mark, thank you for your post!
I see that your Frigidaire dehumidifier is displaying an error code of "ES" and you would like to the meaning of that error code. The "ES" error code stands for evaporator thermistor error. This could be a possible problem with your control panel, thermistor, or a wiring harness. I would recommend contacting your manufacturer for further assistance with your dehumidifier. Best of luck! -Matt
Jun 08, 2015 | Frigidaire Dehumidifiers
My frigidaire dehumidifier fad704dud does not turn on when plugged in
Good Morning Robert,
I understand your Frigidaire dehumidifier, model# FAD704DUD, does not turn on when it is plugged in. I also see that the display lights up briefly and there are no error codes. Your appliance is designed to operate between 41 degrees F (5 degrees C), and 96 degrees F (35 degrees C). It will not work properly if the temperature is out of this temperature range, or the performance of the unit will fall greatly. The "Compressor" circuit has an automatic 3 minute time delayed start if your dehumidifier is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping. Make sure the tank is fitted correctly otherwise your appliance will not turn on. If you are still having trouble, you can contact your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Frigidaire Dehumidifiers
Displaying "A5"
Do you mean error code AS instead of A5? If so, error code AS commonly refers to a sensor issue. Because it is a smaller appliance, repairs are often more costly than the actual unit replacement. You may want to check and see if your dehumidifier is still under warranty and if so, reach out to the manufacturer to determine the exact warranty coverage.
Dec 21, 2013 | Frigidaire FAD704DUD Dehumidifier
.DeLonghi pac A110 PF error code
Probe fault? Temperature sensing probe may have loose connection or water in the tip.
Apr 17, 2012 | DeLonghi DEC 180 E Dehumidifier
My Whirlpool AD40USL5 Dehumidifier is displaying P1 on the control panel. I am not able to find any information about this in the User Guide that came with my unit. Could you please tell me what this...
Here is a link to the Owners Manual for the model number you listed. However, it does not have a LCD display on the Control Panel, which would show the Error Code P1. This is a Kitchen Aid brand that was manufactured by Whirlpool with the AD40USL5 Model Number. This came directly from Whirlpool's website. Hope it helps you in some way.
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%201187730.pdf
Apr 04, 2011 | Whirlpool AD40USL Dehumidifier
Light flashing basket full of water but basket is empty
I hope it has a bucket, not a basket.
Does it show an error code on the display?
Feb 13, 2011 | LG LHD65EBL Dehumidifier
DeLonghi dehummidifer de500p when i first plug it in comes on
DE500P does not run and shows error code E3. What part do I need to replace and where can I get it?
Mar 24, 2009 | DeLonghi DE500P Dehumidifier
P1 error code
Take out your filter and clean it, if its dirty your machine can frost up due to the lack of air flow and will not work correctly. Once you clean it, it should be fine.
Sep 13, 2008 | Danby DDR2506 Dehumidifier
Dehumidifiers Logo
Top Panasonic Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Panasonic Dehumidifier Expert? Answer questions, earn points and help others
