Question about Pasquini Livia 90 Espresso Machine
Why won't pump switch stay on continuously? It clicks off and must be toggled again. Power switch turns on and stays on ok.
Could it be voltage fluctuation or is it most likely a bad switch?
Generator will not stay running
The toggle switch automatically resets all faults when it is turned to the off position. I would turn the toggle switch off, turn off the breaker on the generator and then turn off all the loads in the house except a few lights. Turn the generator breaker back on, then turn the toggle switch back to automatic. If it starts and stays running, you were overloading the generator. Turn on other loads slowly and keep track of what is on so you don't overload it again. If it still does not stay on, you may have a problem with the panel. Let me know what happens.
Nov 20, 2013 | Briggs & Stratton 15,000 Watt Home Standby...
Hi, I have a pentair minimax 250 pool heater and the burners will not stay lit. The pilot stays lit but burners will not kick in. I have it jumpered on the gas valve to heat the pool but I feel very...
first of all dont jumper the gas valve! if the pilot stayson and the burners wont fire there a a few reasons for that. one of your safeties are open.....malfunctioning potentiometer ( tstat control)......or theres a short or voltage drop through the circuit. ur pilot generator should have around 400 dc millivolts. if you follow the path in the circuit and anything drops to the 200dc mark then theres a problem. make sure ur electrical connectors are tight. millivolt models are garbage, as it takes very little to interupt the circuit
Jun 20, 2013 | Heating & Cooling
97 s10 2.2 no power to the fuel pump
most likely its dead but to make sure check the fuel pump fuse or relay some cars has fuses others have relays heck ive seen cars that have booth
Mar 22, 2013 | Cars & Trucks
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
http://www.coppelltvrepair.com/p/895/samsung-pn58a550s1fxza-power-supply-repair-service-for-dead-or-clicking-on-and-off-problem
Dec 22, 2012 | Samsung PN58A550S Plasma TV
Little giant pump stays on with no water no debri till thermal turns it off
http://www.plumbersurplus.com/pdf/03303.pdf
According to above documentation, CIA model has a diaphragm that actuates the switch to turn it off and on. If the vents are plugged with trash it won't work. If the diaphragm has failed it could have water in the switch works. Either way you need to take the switch mechanism apart and clean and inspect it. Hopefully it is just gummed up with gunk from what ever you are pumping and a good cleaning will make it work again. You can also check the switch while you have it apart, should "click" when actuated. Be gentle, this stuff is fragile! Be safe. Remove all power before you start!!!
Oct 13, 2012 | Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V...
How do I get the strobe light on the Mobilite 300 to stay on continuously?
You can't get the strobe light to stay on continuously, the strobe is a very high voltage discharge lamp which can only illuminate briefly.
But the unit does have a built in modelling lamp at far lower power and intensity, used only to set up the lighting rig and to check for shadows and highlights. As long as the unit is connected to mains voltage then you just use the power switch to turn the modelling lamp on.
Oct 07, 2010 | Cameras
Power off issue
Hello octoberburni,
No it is not normal for the amp to stay on when you turn the ignition off. And yes, it will definitely drain your battery if this condition is not corrected.
Use a multimeter set to volts and check between the ground connection (right connector) and remote turn-on connection (center connector) on the amp itself. You should have approximately 12V when the ignition and your head unit is on. And 0V when they are off. If you measure voltage when the ignition and head unit are off, either the incorrect wire is connected to the remote terminal, or the defect is in your head unit. If you measure OK, that is voltage present when ignition and head unit are on, and no voltage when they are off, then the problem is most likely in the amp itself. If you find voltage on the remote wire all the time, check to see that it is coming from the correct output from the head unit. Most aftermarket head units use a blue or a blue/white wire for the remote amp turn-on lead. Many (most) stock OEM receivers do not have a remote amp turn-on lead. But they may have a power antenna lead which will serve the same purpose. In any case, just insure that the correct wire is connected to the amp. It should have voltage when the head unit is on and no voltage when the head unit is off.
In either case, if everything else is still working with the amp, you can simply wire in a manual toggle switch to turn the amp off or on whenever you desire. A SPST (single pole-single throw) toggle switch is what you need. If the problem is in the head unit wire, put the toggle switch inline with the remote wire and mount it somewhere handy on or near the dash. If the problem is not in the remote wire, you'll need to put the toggle inline with the main power wire, the one marked "12V" (left connector) on the amp. In this case, you need to make sure that you have a heavy duty toggle switch, one that will handle more amps than your primary fuse. You may need to look under the hood for the fuse to check it's value.
Hope this helps.
Apr 18, 2009 | Car Audio & Video
SET WON T STAY ON STARTING TURNING OFF ON IT S OWN NOW WON T PL
Check the power supply. This kind of sets usually has switching PS. Check the capacitors, common fail of special low ESR caps. It is easy to see if there is some electrolitic content outside the cap. In case caps are damaged replace them with higher voltage, never use normal caps in this PS.
Hope to help you.
Jan 11, 2009 | Naxa Electronics NX-517 Television
Dishwasher drains continuously
I dismantled and checked various parts of the dishwasher and everything seemed to be working. I noticed with a phase tester that the pressostat never got any voltage. This led me to check the microswitch on the door which turned out to be broken (never making any connection). This is the microswitch that turns off the dishwasher when someone opens the door.
So an unusual problem - two faults at the same time i.e. clogged and overflowing drain and broken door switch!
I ordered and fitted a new door switch and now the machine is working fine again.
Mar 27, 2008 | Dishwashers
Pasquini Livia 90 Espresso Machine Logo
93 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
