Question about Hotpoint FFA60 Bottom Freezer Refrigerator
Why is my hotpoint freezer leaking onto floor
peyton32034
  • 410 Answers
SOURCE: leaking hotpoint 21.7 cu. ft. csx22bc
You have a plugged defrost drain. On hot point refrigs this is fortunatley a very easy repair you can do yourself. remove bottom basket and lowest shelf, ( for sake of room you may remove all shleving. I usually only remove the bottom 2) you will see a ledge coming up from freezer floor to under a rear cover. there will be ice build up on this ledge. clear all of the ice you see and you will uncover the drain hole. next flush hot tap water into the drain hole until it is clear. I use a turkey baster or large syringe to do this but you can push your finger in and out kind of like a plunger to clear the blockage then pour hot water thru line until if flows freely.
If you have any other questions leave them here and I'll be glad to assist any way I can. thanks Peyton
Posted on Mar 01, 2009
oldTech2332
  • 2341 Answers
SOURCE: Hotpoint CSX22GR side by side
The problem is the defrost drain is clogged, the drain is located on the lower part of the back panel and can be gotten to be removing the drawers and to clear drain push a wire hanger through it till small hole delvolopes then flush w/hot water till completly clear
Posted on Jul 25, 2011
oldTech2332
  • 2341 Answers
SOURCE: Our Hotpoint Ice Diamond fridge/ freezer has
Thier are 2 possible thing causing that leak.
1 ) a blocked defrost drain..this tip i wrote will tell ya how to clear the defrost drain
FREEZER ON THE TOP OR BOTTOM http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
SIDE BY SIDE http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
2) the water inlet valve that distributes water to icemaker and in door dispenser (if equipped) hasa pinhole in it and spraying water onto the floor...to check that gotta pull out ref.from the wall and remove lower rear service plate and inspect the valve for a pinhole
GENE
Posted on Aug 31, 2011
imufo2
  • 3773 Answers
SOURCE: Hello, I have a Hotpoint R134a
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Sep 06, 2011
  • 3 Answers
SOURCE: Freezer ice forming on the
You have a blocked drain.
There is a condensation drain at the back above the pump with a small tube that is meant to deposit water onto the pump for evaporation - the drain gets blocked so the condensation flows out through the front door. Also makes big rivers of ice at the back of your freezer behind the bottom shelf??
Solution - Dismantle the inside of the freezer - take all the plastic trim outof the back of the freezer with a screw driver - don't worry, it's only trim and goes back easily. Eventually you will see the drain collector (flat V shape) and at the point of the V is a small hole, pour warm water in this till it drains to the pump at the back, instead of down onto your floor at the front. You may need to clean the hole too as it gets gunked up.
You can also help by finding the drain tube above the pump at the back and gently inserting a chopstick or similar untill the warm water empties onto your hand !
Takes about an hour all in all and has been fixed for a year now on mine.
Posted on Nov 10, 2011
Water leaking from inside of freezer bottom
Check the defrost of the freezer which you are using right now.For More information please visit Clothes Dryer Element.
Oct 06, 2012 | Hotpoint HSS25GFP Side by Side...
Our Hotpoint Ice Diamond fridge/ freezer has developed a slow leak, or rather, it collects water condensate on its floor in the upper compartment which then oozes out onto the floor. I don't have a...
GENE
Aug 31, 2011 | Hotpoint Refrigerators
GE GTL21KBXABS refrigerator has heavy frost buildup and leaks water onto floor.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 10, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Hotpoint. Water is leaking from behind light bulb
The drain hose in the back of your freezer is frozen shut. The water you see is coming from the defrost cycle. Turn off the refrigerator. Remove the floor from your freezer and remove/thaw all of the ice. Locate the drain in the back of the freezer. It may be behind the back panel. Thaw the drain until water flows freely through it. Reassemble the freezer, and you are back in business.
Oct 22, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint csx22bc 21.7 cu. ft. leaking water on freezer side
Look for obstruction at the drain tray for the freezer. Common to have plastic wrap sucked into that area.Or gunk in the drain line. Blow through line to insure the gunk is not an issue.
Mar 01, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Water leaking
Hi
There are several things to check for: The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. Some fridge's have a humidity switch inside the fridge that should be turned on to prevent sweating on the center bar between the fridge and freezer section. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. A kit to repair a separated heat exchanger line, comes with instructions as well. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Please revert for any clarification.
A Fixya rating would be appreciated if you found this to be helpful.
Thanks
Rylee
Feb 16, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
It leaks water onto the floor.
Where is the water coming from? unless you have a leaking ice maker fitting on the back or somewhere else, the most likely cause would be a stopped up defrost drain. check inside the freezer on the back wall and floor. if you see ice you will need to unstop the drain. (most newer models don't have a removable drain pan)
Nov 08, 2008 | Hotpoint HSS25GFP Side by Side...
Ffa97g/frostfree
remove back panel inside freezer and you will find drain at bottom blocked with ice. melt off with a hairdryer and follow up with hot water till drain flows freely.
you may have a fault with the defrost system or the drain heater
Sep 09, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint FFA60 Bottom Freezer Refrigerator Logo
53 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
