Question about Water Heaters
Bath tub water doesn't stay hot
I live in an apartment complex that's about 20 years old, but recently upgraded a lot of the units. The water in my bath tub/shower does not stay hot longer than 10 minutes. The maintance staff has been out here no less than 7 times. They've tired everything from turning up the hot water from the shower facuet, to changing the heating elements, to changing the filter in the facuet as well. The last time the maintance man was here he told me if changing the filter/cartridge didn't work he didn't know what else to do. It was suggested that the next time this happens, I was to get out of the tub to see if I still had hot water elsewhere....and I do. In fact, the water coming out of the sink was hotter than it ever was in the shower. What is my next step? I'm very tired of taking cold showers. (P.S. I do not know what type of hot water heater I have installed in my apartment....sorry)
  • 332 Answers
It is because the tub has a temp control valve in it so if you were to put more cold with the hot it will last longer but still won't be all the way hot,, now a days people are suing the manifacture because they are getting burned form the hot water so they put these saftey temp controls in place of the old style 2 or 3 handle faucets,, there fo no more real hot water nothing you can do outside of change to the othere type of faucet 2 or 3 handle tub shower diverter,, that why the water is hot in the sink but not the tub.....
Posted on Jun 23, 2009
Richmond water heater
The water inlet to the heater must be plugged.
May 16, 2017 | Water Heaters
I've got the Bosch AE 9.5 tankless water heater.
1) Cheapest and most reliable solution: Install tank-type electric water heater from local box store for $250. Get store coupons, offer 10% off store price. Repairs are made same day with generic off-the-shelf parts.
http://waterheatertimer.org/pdf/How-to-install-electric-water-heater.pdf
2) Install grundfo water pressure boosting pump.
http://www.ronhazelton.com/projects/how_to_increase_water_pressure_in_your_home
http://waterheatertimer.org/How-to-solder-pipes.html
3) Remove areators and low flow shower heads, Maintain unit as shown in product manual: Delime tankless unit yearly, Clean water filter monthly.
4) Call city and report low pressure and report issue as fire hazard, move to different apartment. Call apartment complex and ask why they didn't read flow requirements for tankless before installing tankless.
5) Call Bosch 866-330-2729 and complain that nobody read the flow requirement or tested local water flow before installing tankless.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 30, 2012 | Water Heaters
Last week after I filled the bath tub with water, it was rust colored. This happened one time only, then it was fine. I neglected to change my whole-house water filter for about 8 months (well water). ...
It sounds as if the thermocouple has failed and allowed the tank to contract, releasing
the rust from inside. I would recommend replacing the entire unit before it breaks as most
units are only warranted for about 6 to 9 years. Hope this helps.
Feb 21, 2011 | Water Heaters
Tried to take a bath last night and black sediment came out after almost filling tub. I drained some water out of the hot water tank this am. Some more sediment came out and then ran clear. Both elements...
If the heater is that old and you have not changed the anode rod over the years then the chemicals in your water are eating at the tank metal and it will soon fail. A twenty year old tank is so inefficient compared to the new ones that it would pay you to replace it now anyway.
In short YES to your question.
Feb 06, 2011 | Rheem Water Heaters
Our 20 yr old water heater periodically gives much less hot water while taking a shower. I realize this is saying there's much less hot water in the tank that's actually as hot as I want it! Would this...
Hello, Your 20 year old water heater is nearing the end of it's useful life. Most water heaters last only 20 years before they start to leak. The reason most likely it has intermittent heat spurts is most likely due to two things, 1. The unit has a lot of rust in the water (you don't normally notice it during a shower) If you were to bleed off the rust by attaching a hose or bucket to the bottom of the heater's water outlet, and /or the over pressure tube located off of the top of the unit that has a copper pipe on it pointing toward the ground, that you would see a lot of rust come out of it. You could do this and get a bit more life out of it and better heat to boot, unless it decides to leak.
2. The water heater has a bad electric heating element (if it's electric that is). Replacing it may solve the problem but most likely the heater still isn't going to last too much longer anyways, so that would be a judgement call on your side.
You would in all likely-hood be better off replacing the entire water heater now while it is in a controlled environment before it leaks at some unfortunate time causing water damage and other damage at the same time when you are not around to control it.
Good Luck! Rich L.
Jan 02, 2011 | Water Heaters
Tankless on demand water heater.
Tankless water heaters normally take a little longer than a regular heater to provide hot water because they have to start and get warmed up. I'm guessing the heater uses a pilot light and that the short amount of hot water when you turn on the tap is hot because when the water is sitting still in the heater the heat from the pilot light is enough to get it hot. The tub faucet will get hot a lot faster than the shower because it lets a lot more water through and empties out the pipes faster than the shower. You could probably speed things up by letting the tub faucet run on completely hot for like 10-15 seconds and then turning on the shower.
Oct 24, 2009 | RTO Takagi Jr. TK-JR-N Tankless Water...
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water heater-american standard brand
I assume you are talking about an electric water heater. The normal life span of an electric water heater is up to 11 years. Before you replace it, try turning off the unit, turning off the water supply, and draining the tank of any built up rust and sediment. Refill the tank, and turn the power back on and see how it performs. If it is still acting up, look at a replacement. On a positive note, the new water heater should pay for itself in pretty short order due to better insulation saving energy (and replacing with a higher efficiency unit may qualify for a tax credit).
Mar 16, 2009 | American Standard Water Heaters
Tankless water heater pilot light will not stay on
It is most likely the water valve stuck open, telling the controls to heat water, that it thinks is flowing through it, but without actual flow it overheats. Depending on how comfortable you are with taking it apart yourself, you could open the valve to see if it just needs cleaned out, or if you have a ruptured diaphragm or some other cause.
Jan 25, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Water Heaters Logo
774 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
