Question about Hoover UltraCare HC6 160E Front Load Washer
Why does my hoover washing machine keep on going to caresse mode
  • 236 Answers
SOURCE: Wont Stop
probably the timer pcb has gone faulty.
Posted on Feb 16, 2008
SOURCE: I need to download hoover washing machine manual HNWL7146-80
You can try going to http://www.managemyhome.com/ and looking up the model # there.
Posted on Mar 15, 2009
  • 77 Answers
SOURCE: washing machine
-the conditioner compartment may be blocked
- the cable with spring that change course of the water may be out,
Posted on May 08, 2009
walesarumi
  • 6993 Answers
SOURCE: Hoover elite 700 washing machine won't spin
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
# A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
# 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
# 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
# 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
# 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
Regards.
Posted on Jan 05, 2012
raza504
  • 3 Answers
SOURCE: hoover 800 f1 Will not wash
join And Earn http://www.neobux.com/?r=ahmedraza504
Posted on Mar 21, 2013
Washing Machine does not start
It could also be your line to the machine is fried at the ends where the electrical hook up is. Look at the connections on the back of the machine. One may be fried
Feb 21, 2014 | Washing Machines
Hoover vhd8142 manual
Hi
I have a hoover vhd8142 washing machine.
It has just started going into timer delay mode just after a wash begins, every time this happens.
Does anybody know why or how to solve the problem/
Thanks
Del
Feb 19, 2012 | Washing Machines
User manuals for: Hoover soft wave model number HSWD 126-80 and Servis washing machine Caress 1000A, model no: M3101A If someone could help that would be great :-)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 22, 2011 | Washing Machines
Manual instruction for servis caress 1200 a
i want to connect a hot water to my caress1000`a`
is it possible?and how our washing machine could control the temperature.(washing machine has a cold water connection)
Aug 31, 2010 | Washing Machines
I have a hoover washing machine vhd9123d and error E02 keeps showing up. Filter seems to be clean etc.
e o2 is a not filling with water error have u checked the lines going into the machine as well as the water valve? please remember to rank how this post helped and write back for futher questions thanks again
rickead1
p.s. u can also goto this site and it will help you diagnos your machine http://service.hoover.co.uk/fault-finder/FaultFinder.aspx?Section=11
have a great day
Aug 17, 2010 | Hoover Washing Machines
Can I get a a circuit diagram for a Servis caress 900 washing Mac
Their is usually a wireing scmetac inside the timer and switch housing of most machines.
Aug 25, 2009 | Washing Machines
Washing machine
Hoover washing machine This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 19, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Washing machine wont go into full spin
was advised could be bushes so replased them works a treat thanks
Feb 07, 2009 | Hoover Washing Machines
Wont Stop
Jan 12, 2008 | Hoover AL120 Front Load Washer
Hoover UltraCare HC6 160E Front Load Washer Logo
12 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
