Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
Should there be a hole in the side of the G3 diaphram?
There is suction, but it doesn't move along the bottom. I took it apart and noticed an opening on the side of the diaphram. Would that be causing my problem?
    Problem Solver:
  • 4 Answers
No, a common place for cracks is near the top next to the plastic ring that holds the diaphram to the tube. this is a common problem with the G3 and G4 diaphrams. other cracks and holes near the center are usually caused by objects that get picked up and stuck or old age.
too much suction and/or use will shorten the life of the diaphram. along with bad water chemistry
Posted on Jul 29, 2009
My g3 is not working, took it to pool store and they replaced diaphram, but still not hopping or moving, suction is good but now movement.
There are a couple things to check with these pool cleaners when they stop moving. Use Pool Pulse to insure proper flow through the cleaner. Clean baskets and filter to ensure that you are not clogged. Check hose sections for leaks by lifting each section above water.
Apr 09, 2011 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac G2 Cleaner not moving around pool. Suction is adequate, filter has been backwashed. Cleaner pulled to pieces and reassembled. Has small crack in diaphram. Unit is 6 months old and has problems the...
any damage to that diaphram will cause the cleaner to not work. If it is only 6 months old then it is under warranty. any pool store should be able to get you a new diaphram at no cost. bring your paperwork with you to show proof of purchase.
Dec 29, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My baracuda is not moving....I took it apart and nothing is caught inside. The filters arer clean. I adjusted suction as well with no results
Is it pulsating? If not then either you don't have enough suction or the diaphragm is bad or clogged. you said it was not clogged so check closely for tears. Very common to have a **** or tear next to or just below the plastic retaining ring that holds the diaphragm on the inner cassette tube. Also check and make sure there are no holes or breaks on the hoses. If this doesn't solve the problem let me know, these cleaners are very straight forward. Good luck!
Sep 17, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Has good suction but wont move
Is there a tile stuck in the condom shaped diaphram when you look into the cleaner from underneath. Could be any kind of rubbish make sure you look deep inside as debris gets stuck right at the top.
This diaphram is removable check also that it does not have a hole in it.
Cheers Bazzard
May 08, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My baracuda G3 stop working is not pulsating and therefore not moving. I checked the suction and the hoses even the diaphram everything looks ok.
If you have suction at the bottom of the cleaner, there has to be a problem with the diaphragm. I would remove it and recheck.
Feb 01, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Barracuda Zodiac G3 is not pulsating. It's got
either some debris is caught in the diaphragm or it's deformed enough to render it inoperable. Unthread the nut just above the handle and pull it apart, then push the white tube downward until it comes out of the bottom of the unit. Inspect the diaphragm to see it there is any debris in it or if it is deformed. Usually the diaphragm has a uniform opening, if the gap is wide, it will not function. The most common problem is that the diaphragm needs replaced. Hope this helps.
Nov 16, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Lots of suction, but G3 won't pulse or move around pool
theres a throat in it. Its damaged or ripped take a close look at it . you can gey at your local pool store
Oct 05, 2009 | Zodiac Baracuda G3 Automatic In Ground...
It pulsates; but pretty much stays in one spot
check your diaphram for a tear near the plastic ring that hold it on the tube
Jul 25, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
G3 is not moving, but has suction? Please advise.
I had the same problem. come to find out there was somehting stuck in the diaphram. (a piece of mulch). Once I removed it, everything worked fine. Take your Barracuda apart and check the diaphram for blockage.
Mar 21, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Baracuda G3 zodiac Clings to bottom or sides moving slowly
here is a link to the Technical Support at Baracuda. this should be able to solve your problems. initially sounds like maybe too much suction.
Feb 25, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
415 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
