Question about Magellan RoadMate 1400 Car GPS Receiver
Magellan 1400 gps does not turn on when connected to car charger. Tried several times but in vain? can you let me know how to fix it?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,001 Answers
Quick Charger 2.0 2port QC2.0+4port USB Charger 5V 9V 12V 60W USB Fast Charger for Mobile Phone Chornic Quick Charger 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
Posted on Dec 24, 2016
    Brigadier General:
  • 4,090 Answers
Well it may not be able to be solved without expense.
Do you have an AC charger? if so try to turn iot on when its been connected to the charger for about 10 mins if it comes on when on AC then you will need to change the internal battery/s other than tjhat the circuit is damaged
some models do not have AC chargers
if this is new or under warranty make a claim ASAP as they go out of models so quickly they have a poor warranty system
Posted on Jun 23, 2009
My magellan Roadmate 5220-LM powers on but will not go past the first screen. I have tried to use the reset button but it still will not work
Hello Liz, You may have two problems. If your unit is several years old, the battery may need to be replaced. First charge the battery overnight. To get the screen unfrozen , you need to remove the screws on the back, open the case, and unplug the white battery connection . Reconnect the battery connection after a few seconds. If this works, it is usually a temporary fix . Either your battery does not hold a charge or your charger connection is poor at best and can not deliver a full charge to the battery. It could be both.
Mar 17, 2014 | Magellan RoadMate 5220-LM GPS Vehicle...
Our gps keeps cutting out when plugged into the car ? If we hold the connection that goes into the gps it will come back on for a little while. The yellow insert in the gps that connects to the power...
assuming you havent tried a home charger
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below (magellan 3000.3050 and the 6000 take about 10-15 seconds to start from the off position)
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
Aug 08, 2010 | Magellan Maestro 4040 GPS Receiver
Can you overcharge a gps battery with a home charger if the system is not turned on?
no it doesn't overcharge, in fact leaving it on the charger all the time extends battery life
May 20, 2010 | Magellan RoadMate 1400 Car GPS Receiver
My Roadmate 1400 froze up while trying to update software, First I got the "couldn't load source file" message, and now I just keep getting the same error message on the screen "application...
my sure the battery is fully charged or plugged in and charging, then run the update again...if that fails, let me know.
magellan will repair or replace any of their gps that are rendered inoperable because of one one their updates.
bill
Jan 29, 2010 | Magellan RoadMate 1400 Car GPS Receiver
My magellan roadmate 1200 will not turn on
make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..
if you tried charging it with both house charger and car charger and tried to start it like i explain and it still will not start, its most likely a bad power port which is very common with this model and many other magellan models.
Sep 10, 2009 | Magellan RoadMate 1200 GPS Receiver
After recently purchasing my Magellan Roadmate 1400 GPS the cigarette lighter adapter cord no longer charges the unit. I am able to charge it from a regular AC wall socket but it will not start up in my...
look in the tip of the DC charger and see if the fuse has blown. This is usually the case.
Be warned! starting the car with the GPS plugged into DC can blow your SIIRF chip... no more satellites! and an expensive repair. be thankful it was the fuse this time
Jul 06, 2009 | Magellan RoadMate 1400 Car GPS Receiver
My magellan GPS Roadmate 1400 hard reset
there is a little pin hole on the side on the unit. you need a paper clip to reset it
May 27, 2009 | Magellan RoadMate 1400 Car GPS Receiver
Magellan RoadMate 1400 Car GPS Receiver Logo
605 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
