Question about Microwave Ovens
Why nikai 518 oven not work
Display on cant reset start
Nikai microwave oven is not hot
The magnetron may have failed but the problem could be failure of the controller
Aug 08, 2016 | Microwave Ovens
Display is blank
If the display is blank, and the oven works, 9 times out of 10 it is a problem with the circuit board that drives the display.
Apr 16, 2014 | GE Advantium 120 Convection/Microwave Oven
How to use nikai nmo 583 digital microwave oven 583
you must read your owner manual or download from www. retrevo.com or www.manualslib.com and follow the steps
God bless you
Nov 14, 2013 | Nikai nmo583 digital microwave oven for...
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Nikai nmo-582 microwave oven
And what is the problem?
Jan 28, 2011 | Microwave Ovens
Hi, my problem is with my GE advantium speedcook microwave oven. When using 'speedcook' feature, the oven starts, then there is sparking inside the circuit board area, followed by a loud POP, and this...
  • Select the "Options" menu and adjust the clock display settings if the display is blank. Set the clock if the oven won't start. The clock must be set for the oven to work properly, as oven programming is dependent on the clock.
  • Close the door tightly if the oven won't start. The oven won't start if the door isn't closed. You can identify from the lights whether the oven failing to start is related to the door or to the power supply. If the control panel is illuminated and interior lights are on when you open the oven door, you can be sure the oven is receiving power and any starting problems are due to the door not being closed tightly.
  • Press and hold the "Clear/Off" button if the oven performs strangely. Be sure to hold it for a few seconds. This will reset the GE Advantium.
    But as you mentioned that there is /was a loud noise this is a indication of the unit make any usual noise (groaning, gurgling, etc.?) or was / is it either louder or quieter than normal?It may be as simple as the top door switch or its mount or it may be a bad magnetron or shorted diode.
    For manual of the oven.please click the link below:--
  • http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40577-1.pdf
  • Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • Aug 12, 2010 | GE Advantium 120 Convection/Microwave Oven
    F3 flashing on display screen..no buttons work!
    I have the same problem. However when I unplug the microwave from the wall outlet, let it sit for 10 seconds, then weird codes appear on the top line. Reset the clock and it shold work just fine.
    zayd4@aol.com
    Apr 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Reset shows on display of my GE space saver microwave oven
    change the board that has the reset on the display board it is bad
    Mar 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Child sign in window of microwave ,cant start it panasonic
    On my NN-L738BA there is a Child Lock feature.
    You set the child lock by pressing the Start button 3 times.
    If the Child Lock is enabled it displays the word :CHILD".
    To disable this feature on my microwave the manual says to
    press the Stop/Reset 3 times.
    Check your manual for the Child Lock.
    Mar 06, 2009 | Panasonic NN-S541 Microwave Oven
    Microwave Ovens Logo
    13 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
