Question about Refrigerators
Lamona hja 6110 freezing problems - Refrigerators
SOURCE: user manual for lamona dishwasher
Hi my salt level indecator light stays on even when I have filled it with salt! please help anyone
Thanks Rose
Posted on Mar 10, 2011
  • 6277 Answers
SOURCE: Lamona Washing Machine HJA 8514 Half way through a
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 27, 2011
  • 6277 Answers
SOURCE: Lamona hja 1514. When on
First thing to do is to adjust its balance/level by following my pre-typed guidance notes ;-0)
I shouldn't worry about its change in design/build, certainly not for now!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
John C
Posted on Sep 13, 2011
SOURCE: have misplaced manual for lamona
I have scanned my HJA 8704 Manual and put it here
https://docs.google.com/open?id=0By3DbWv5t3T-WHR4OGJMMkZ5Tk0
Posted on May 06, 2012
ercupa190
  • 12223 Answers
SOURCE: lamona hja 8631
please see the video attached and fix it. Merry Christmas.
Posted on Dec 18, 2013
Lamona
www.lamona.co.uk
Jul 03, 2014 | Refrigerators
Lamona hja 8514
You have an internal pump which is not accessible without uninstalling the appliance, however instead of using drain block have you tried a proper appliance cleaner and cleaning the connection under the sink as this is where most smells come from and not the machine themselves
Apr 07, 2014 | Washing Machines
Ice cube dispenser not working
Hi there, did you find the answer to this problem? We have exactly the same issue. We noticed a burnt smell in the freezer, mainly transferring to our hands when we touched packaging. The ice dispenser was working fine but the ice started to taste funny (a bit like burnt plastic) and had black bits in it. We took it out to clean the tray and since putting it back in, it just won't work. We don't know if we have put it back in wrong or if something has blown. We can still hear the motor when we try to press for ice, but nothing comes out. No water is making its way into the ice cube tray to form the ice, but we still have cold running water. I would be so grateful for any help. Thanks
Mar 16, 2014 | Ovens
No temperatures on the oven
Easiest thing to do is to Get your Model Number, log onto www.searspartsdirect.com and order the new knobs... Or go to your local appliance repair center or Appliance parts store and order them and you will be able to get fix it for the future.
Download LAMONA HJA 3300 HJA3300 User Guide English
Mar 03, 2014 | Ovens
Lamona hja8630
How do I remove the integrated door af a lamona hja 8630
Jan 01, 2014 | Dishwashers
Model HJA 3220 removal of internal glass panel
i have the manual if any one needs it... can't upload it here but email me if you want... faisal at citydealestates dot com - no spaces. covers HJA3220 HJA3320 and HJA3212
Feb 18, 2012 | Ovens
Have misplaced manual for lamona washer dryer HJA 8704. How do I find the setting for tumble drying only
Jun 21, 2011 | Dryers
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
