Question about VAX Appliances Vax X5 Bagless Upright Cyclonic Vacuum
Loss of suction
No sucking very well through the brushes, no suction at all throught pipe, dismantled everything and cleaned it out, nothing there. 7yrs old machine, whats wrong
Loss of suction on my Ergorapido
thats odd
check if the piping is clear from the dust collection
down to the bottom brush
it does have some sort of dust collection
if it has a filter of any sort check its condition
check the pick up hole in the brush housing
maybe a seal is leaking
Sep 04, 2016 | Vacuums
Dc54 is a floor model and not sucking well, have cleaned everything, am I missing something?
DYSON DC54 Cinetic with No Loss Suction Technology ...
? 3:06
www.youtube.com/watch?v=uATJ_CWbpoo
Aug 25, 2013 - Uploaded by Bing Lee DYSON DC54 Cinetic with No Loss Suction Technology ... Watch this video to see more details on the only Vacuum in the world that will ... but unlike Dyson, this machine could also pick upwater and was also a floor washer.
Oct 04, 2015 | Vacuums
My Hoover UH70040W Wind tunnell mach cyclonic has stopped sucking up debris. At the brushes you feel no suction and when you disconnect the tube on the side it has some suction but not much at all. The...
Well if the vac motor is good then its either a clog or a leak ,if you say no clog then it has to be a leak. Make it blow out and see where the air is coming out or try and find it while it is running with a piece of typing paper loosly around the hose and piping. Seals at the connection areas go bad so check them as well.
Mar 31, 2011 | Hoover UH70040W Bagless Upright Cyclonic...
My fuller brush household canister vacuum doesn't have as much suction as usual. I've changed the bag and cleaned filter. Any other ideas?
. Test the suction without the pipes to confirm that the motor is sucking strongly, then check that there are no blockages in the pipes and fittings.
Jan 29, 2011 | Fuller Brush FBPTCAN Bagged Canister...
Very little suction when vacumming
Hi There,
I think I know exactly what the problem is with your Dyson. I'd be happy to try and walk you through it, but just want to make sure that you still need help, or if you've already fixed the problem.
Apr 05, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
My Oreck XL has quit sucking. The brush turns but
Same problem here with XL9100. Bag would not expand implying no suction. Motor ran and brushes turned. Easy disassembly using common tools found that a plastic bag had been sucked up and caused a blockage prior to the impeller. Cleaned up, reassembled, and everything worked fine after that.
Nov 05, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Not sucking makeing a clogged noise
Bagless vacuums don't usually get clogged as easily as standard bag styles do. However, if you can disconnect the top half from the brush head section you should see a "neck" where the two meet, check there for a clog. Also check your filters, this is where loss of suction happens most. Dirty filters = Low Suction. I hope this helps
Jan 19, 2009 | Fantom Vacums Fantom Wildcat 2100 Upright...
Loss of suction when using upright. Suction remains for samll tools
I checked all the pipes and seals. There is a flexible pipe which you can see underneath that connects the front rotating brush assembly to the vacuum system. This pipe can crack and loss of suction occurs when using it upright. The pipe can be repaired temporarily with strong fabric sticky backed tape (e.g. carpet seal tape). A new pipe can be fitted with a few tools.
Jul 26, 2008 | Vacuums
Vaccum has no suction
Here is what we did to fix the problem of our vacuum having no suction.
We unscrewed the three screws on the back and took the hose off of the vacuum.  Then we took the hose outside and put the water hose through the vacuum hose and turned on the water.  After about 30 second the water pushed through a dust bunny the size of a fist and a marker.  Basically, the vacuum did not have suction because the hose was clogged with dust, etc.  After reassembling the vacuum, it worked just fine.
May 11, 2008 | Kenmore 34923 / 34925 Progressive Bagged...
VAX Appliances Vax X5 Bagless Upright Cyclonic Vacuum Logo
23 people viewed this question
Top VAX Appliances Vacuums Experts
Jerry Kramer
Jerry Kramer
Think Crucial
Think Crucial
Are you a VAX Appliances Vacuum Expert? Answer questions, earn points and help others
