Pc security should I allow 'dtmng.exe'
Should online armor allow 'dtmng.exe', or is it harmful ?
Dns failed
dns.exe problems occur when important operating system files become misconfigured, deleted, or damaged. This is a common problem with computers that don't get maintained regularly. Eventually the system becomes overloaded with problems and begins to crash and display errors. You may also notice your system becoming very slow due to high CPU and memory usage.
Resolution
We strongly advise against fixing dns.exe errors manually. Doing so could take several hours, do more harm than good, and end up not even resolving the underlying problem.
The most recommended solution is to use a reliable software application that can quickly diagnose and fix dns.exe errors (and much more). Programs such as Advanced System Cure run a variety of troubleshooting and diagnostic tests on your computer in order to pinpoint and fix almost all known issues. The result is an error free PC that is actually much faster than before. And it is free!
Nov 13, 2013 | Computers & Internet
Error code 209600
f you are attempting to connect your Wii console online using a wireless router and you receive this error :
Ensure you are using a broadband or high speed internet connection such as cable, DSL, or fiber optics. Slower connections, such as dial up, may cause issues with the Wii or may not work properly.
Ensure there is no interfering devices by shutting off microwaves, cordless phones, wireless keyboards, and wireless mice.
Diable your firewall settings, as it may be causing a connection problem.
Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds. Be sure to test both channels to see which works better or faster.
If you are using a Netgear wireless router, disable the SPI firewall setting which is usually found under the WAN Settings of your wireless router.
If you are attempting to connect your Wii console online using the Nintendo Wireless (Wi-Fi) USB Connector and you receive this error :
If your PC is using security features or programs such as a firewall, antivirus, or antispyware, check all settings of these security features or programs to allow a successful connection.
You may try adding the following programs to your firewall list of "Trusted" applications
  • Nintendo Wi-Fi Connector USB (NintendoWFCReg.exe)
  • Setup.exe (when installing the USB Connector)
  • SoftAPInstDrv.bin
  • mdriver.exe
Temporarily disable your router's firewall which may allow the Wii console to connect online to recieve a system update. After, you may turn your firewall back on.
Jul 19, 2011 | Nintendo Wii Console
What is code 209600?
Welcome to Fixya. Wii Error Code 209600. If you are attempting to connect your Wii console online using a wireless router and you receive this error :
*Nintendo Wi-Fi Connector USB (NintendoWFCReg.exe)
*Setup.exe (when installing the USB Connector)
*SoftAPInstDrv.bin
*mdriver.exe
If you have questions please let me know. Thanks for using Fixya.
May 04, 2011 | Nintendo Wii Console
Need to fix error code for wii #32004. It won't let me do an up date. The new games the kids got for x-mas will not play with out the up date PLEASE HELP kids are vary upset.
Disable your firewall settings, as it may be causing a connection problem.
If you are attempting to connect your Wii console online using the Nintendo Wireless (Wi-Fi) USB Connector and you receive this error.
To solve this error :
You may try adding the following programs to your firewall list of "Trusted" applications : Nintendo Wi-Fi Connector USB (NintendoWFCReg.exe), Setup.exe (when installing the USB Connector), SoftAPInstDrv.bin, mdriver.exe.
Hope it will help you.
Dec 27, 2010 | Computers & Internet
Antivirus softwear for sumsung g800
I assume you are looking for a good free anti-virus? If so, you might try AVG free. I love Online Armor for a great firewall, and AVG for anti-virus if you don't have Online Armor paid version so you can use the anti-virus part. As long as I've had both of those, I've never had a virus. I do get trojans in a download sometimes, but they catch it right away.
Hope that answers your question. :) If not, ask again & tell us more info so we can answer better, OK? :) Thanks.
Sep 18, 2010 | Computers & Internet
My OS is XP. It became infected with the internet
Internet Security 2010 manual removal:Kill processes:
IS2010.exe 41.exe winlogon86.exe winupdate86.exe help.gifHELP:
how to kill malicious processes
Delete registry values:
HKEY_CURRENT_USER\Software\IS2010
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "Internet Security 2010"
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run "winupdate86.exe"
help.gifHELP:
how to remove registry entries
Unregister DLLs:
winhelper86.dll
help.gifHELP:
how to unregister malicious DLLs
Delete files:
IS2010.exe 41.exe winhelper86.dll winlogon86.exe winupdate86.exe Internet Security 2010.lnk help.gifHELP:
how to remove harmful files
Delete directories:
C:\s
C:\Program Files\InternetSecurity2010\
Jan 28, 2010 | Microsoft Windows XP Home Edition
When trying to download my new subscription a warning that downloading the exe may damage my computer appears
It is a normal thing to happen, because some .exe file downloaded may harm your PC. Therefore your antivirus software alerts you that you are possibly harming your computer. It will appear if you download any .exe file
Nov 15, 2009 | Norton Internet Security 2005...
AdMINIsTrATor.exe missing
is a malicious malware code created to open security holes in Windows and give third parties control over your compromised computer. After installation Administrator.exe may stay active in the memory and install nasty files in Windows folders. Administrator.exe is a security risk that may harm your system files and computer hardware.
Clean and protect your computer from all varieties of malware threats. Scan and remove Administrator.exe malware and all its related files, clones and aliases.
but Microsoft provides a replacement for the Admin.exe file included with versions 3.2 and 3.2a of Microsoft Mail for PC Networks.
For complete information about obtaining and installing the Admin.exe file, see the following sections: http://support.microsoft.com/kb/107443
Nov 09, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
On startup, i get the message: Isass.exe - Access Denied
Information on lsass.exe - http://www.neuber.com/taskmanager/process/lsass.exe.html
Are you running a firewall (such as zonealarm)? It might be your firewall may be blocking a legit attempt by lsass.exe to run. You may have to add this to your firewall's allowed list. Of course if you are not running a firewall or if your firewall is already set to allow lsass you may have even greater problems.
http://www.google.com/search?hl=en&q=lsass.exe+shuts+down+pc
You may want to post more information to get a better answer on this.
Oct 28, 2008 | Computers & Internet
Which is the good anti Spyware for PC?
Hi - I use "Spybot - Search & Destroy" and very good program & FREE!!
You can download the software from the link below:
Spybot
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 07, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
