Question about Adaptec american megatrends AMIDiag 6.0 Full Version for PC
CD ROM FAILS TO READ A DRIVERS DISK, WINDOWS SHOWS NO PROBLEM, SOME COLD STARTS SHOW A PROBLEM IN BIOS, WHAT CAN I DO?
  • 1 more comment
  • bfiliberto Jun 23, 2009
    even if i reset to default message reappears, i also tried to install a program (fox pro) and the install utility shows a problem and stops
  • Daryn  Horn
    Daryn Horn May 11, 2010
    EXACTLY WHAT ERROR MESSAGE ?
  • Daryn  Horn
    Depending on the exact problems shown in the bios ..... you could go in and re-set the bios to default as far as the drivers are concerned another option would be to go directly to the source and grab your drivers from the manufacturers site.
  • 92 Answers
My advice: replace it for a new DVD-RW, so cheaper now...
Best Regards
Posted on Jun 23, 2009
Im not able to boot from os cd the bios can see rom drive and hard drive but im not able to boot iv'e tried f12 but no joy can you help?
hi there.
If you go to the bios on start up and select cd rom drive as your primary boot and then restart. Your computer will then try to boot first from the cd rom drive and second from the hard drive. If it fails to boot from the disk then this would lead me to believe that either the disk is unreadable by the drive or that the cd rom drive itself is unable to read the disk.
Jun 30, 2011 | Dell Computers & Internet
I have an Evesham Evolution desktop with Windows XP SP2 product recovery disc. I want to reformat the drives and carry out full "clean" install and reload all software. I insert the recovery...
It sound like you have a recovery disk not an install disk. The recovery disk you have just lets you repair windows only. If you insert the disk after windows starts and it runs you can then try to back up what you want and delete what you don't want, then run a windows repair. Its the only option, My other suggestion is to purchase Windows 7 and do a clean install.
May 09, 2011 | Evesham Evolution PC Desktop
I have Acer TM 4150. I has booting problem like when i put on my laptop it gives message to boot from 1- floppy drive 2-HDD 3- Cd Rom also in Cmos it shows no Hard disk or O HDD i restart it again...
Isssue with your Hard Disk... Possibility Data lost, due to power lost, or Bios Battery need to be change... To do So, Press and hold del button while you turn on your Laptop this wil bring you inside you Bios then Check carefuly set date and Time also set autodetect hard drive and set cd-rom first hard disk 0. second then the rest off... press F10 to save your change then restart your laptop then see if it will boot from itself.. if not ...Then put your XP CD on the cd-rom then re-start then press F-12 then chose Cd start to re-install your windows make sure you have your Cd key first then from anoter computer go on the net and download all your drivers for your laptot type down the model off your Laptop then on any browers type exemple; download ACER TM4150 drivers for xp or the one you use.. sample is that.. Good Luck
Oct 01, 2010 | Acer TravelMate 2303LCi Notebook
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
When inserting a disk, the CD ROM spins but does not read the disk nor does it show up in "My Computer". Under Device Manager, it shows up with an exclamation mark. I've uninstalled and re-installed it to...
Please try running the Microsoft Fix It from the link below. It should resolve the issue for you.
http://support.microsoft.com/gp/cd_dvd_drive_problems
Robert from Blitware
Jul 08, 2010 | Dell Inspiron 5100 System Board (...
Averatec 3200, cant find DVD Rom driver in "My Computer" or "Device Manager" When I put in a CD I can hear the disk spinning but it never loads. I deleated the upper and lower filters and restarted the...
Make sure the BIOS is 'seeing' the drive. Reboot your pc, press F2 as soon as it starts to boot (Or watch your screen and the POST will display which function key to press to enter setup.) If the BIOS is NOT seeing the drive, you may need to a) replace the drivers for the dvd or b) replace the dvd rom itself. (I recommend the drivers first.) Please repost your results and we will continue to monitor your progress.
Good Luck
C2Solutions
Sep 04, 2009 | Averatec 3200 Notebook
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Adaptec american megatrends AMIDiag 6.0 Full Version for PC  Logo
77 people viewed this question
Top Adaptec Computers & Internet Experts
Rommel Balcita
Robert Graf
Timothy Van Der...
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
