List the fist 20 elements - Computers & Internet
Do you know where I can get a replacement bake element for my 20 inch Sunbeam electric range, model # SNS2EMLXAW
Searsparsdirect.com , appliancepartspros.com, I searched but the model number you listed did not show up, double check your number.
Feb 04, 2015 | Sunbeam Kitchen Ranges
Change heating element Samsung Dv5451aew Front Load Dryer
On most front load machines the first piece that must be removed to access anything is the top. There are a couple of screws/bolts at the top rear that secure it. It then opens, sometimes by sliding it slightly rearward fist to release the catches. Then you can start removing other panels.
Sep 16, 2014 | Samsung Dv5451aew Front Load Dryer
My calculator is TI-83 plus. I get Err: data type every time I want to use lists to calculate something. For example I enter 5,10,15,20,25 in list 1 and 5,5,5,5,5 in list 2. Then in list 3 I type L1/L2,...
You can't manipulate lists like that.
{5,10,15,20,25}[STO>]L1
{5,5,5,5,5}[STO>]L2
These will input your lists properly. I'm not sure what you're trying to do, but if you're just trying to divide every entry in L1 by 5 and store it in L3, you could accomplish that with:
L1/3[STO>]L3
Also, this page gives a lot of helpful tips on using lists on a TI-83.
http://pages.central.edu/emp/lintont/ti83/html/lists.pdf
Hope this helps!
Mar 30, 2011 | Texas Instruments TI-83 Plus Calculator
Will not dry cloths turns off before dry elements take approx 3 amps each thanks
HI, I would fist take off vent hose from back and blow line out,could be clogged with lint.If that does not work it could be bad high and low switches located byheating element.
Mar 06, 2011 | Dryers
Hello, i need to know how to change the lower element in my rheem 40 gal. water heater
Rheem uses a 4-bolt 4500 Watt element available at hardware store and some home centers:
To confirm wattage, see label on side of tank. Also note you label shows gallons, and show a serial number that has date of manufacture in fist 4 digits, for example 0605.. is June 2005.
The element is removed using a wrench. Remove 4 bolts. If bolts are stuck, then use WD40 and ratchet with extension. You can also drill out the bolt and re-tap holes with new thread. Don't drill through wall of tank which is about 1/4" thick.
For generic step by step for replacing water heater element and cleaning out tank:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Link shows how to drain tank, check if electricity is off, and general sequence of steps.
Rheem element that you buy comes in package with specific step by step for replacing that element. Be sure to clean opening of any debris before installing new element.
Dec 29, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Element mp3 will not play longer than 20 seconds of each song
Best Solution!!! I called tech support (866-823-1671 - very nice/helpful) because my daughter's was doing the same thing. I was told to let the song start to play, press the M button during the song, choose 'Repeat' which will bring up a list of options and then choose 'Normal'. It worked.
Dec 23, 2008 | Element Electronics Zr-Element Digital...
My dryer will run but won't heat
you either need a new heating element or limit switches
Nov 02, 2008 | Whirlpool LER8648P Electric Dryer
How do you protect a lawn mower from rain?
If you'll go to a hardware store, I sure you can find a cover for a law mower. I had the same problem. At fist I was afraid that it won't do but it works great. I got a cover from home depot for 20 bucks.
Good Luck :-)
Sep 01, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Error code f-20?
dmary, if this is an Oasis dryer, F-20 is the code for a shorted #1 element. They forgot to to list it on the tech sheet. For your techs general info. F-21 is a shorted #2 element. Catriver.
Sep 10, 2007 | Kenmore 67082 Electric Dryer
Computers & Internet Logo
10 people viewed this question
David Payne
David Payne
