Question about HP vs17c 17" LCD Monitor
I want know where can I purchase a power supply board the HP vs17 lcd monitor?
    Sergeant:
    Champion:
  • 233 Answers
You can purchase a power supply board for HP laptops from the below link:
http://www.partshere.com/online/detail.asp?partno=0950-2417
If we can know the part number of your HP computer, you can find the exact Power Supply board for your computer model.
You can find the part number of your computer from the below link:
http://partsurfer.hp.com/cgi-bin/spi/main?jumpid=reg_R1002_USEN
You can find it even from HP parts store.
Posted on Jun 23, 2009
The monitor requires it to be switched on & off many times before it will stay on
It sounds like your power supply on the monitor is starting to give out. Those are very difficult to replace if built into the monitor itself. You may not have much choice but to purchase a new monitor.
Oct 24, 2013 | HP Vs17 17" LCD Flat Panel Monitor
I have a HP vs17 Monitor, and it suddenly wouldn't turn On anymore. The screen is blank. I was able to check the line Fuse, and it is OK. I measure approximately 165 VDC across Capacitor C805, that's...
That is the primay side of the power supply so be careful, you should check the DC on the secondary side for 5vdc (logic) and 12~16vdc (backlights inverter).
No bad caps iwth domed tops at all?
Please look thrugh my albums and read my guides.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 18, 2011 | HP Vs17 17" LCD Flat Panel Monitor
My monitor is flashing different colors... it wont start up
chanel_luv_u, Could be possible internal SMPS/CCFL inverter power supply problem. If the PC is ok with different "known-good" monitor connected to PC, then vs17 monitor will need some work done on it. Do some reading here first for some clues!!! http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flatpanel-disolay-blackout-solution/ The first place I would look at on ANY ccfl back-lit lcd monitor that starts doing "very strange things" would be the units "switch-mode-power-supply/CCFL inverter circuit". Try YOUTUBE for video clips of DIY lcd monitor repair to see if unit can be fixed for less than $6 in parts. Keep this in mind though, Your vs17 isn't any different than any other ccfl back-lit lcd monitor in it's basic design and operation. Do some reading of fixya LCD monitor technicians profiles for more info. Let us know what plans you have after you do your research. Bye for now. 12fixlouie
Jun 09, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Works for awhile then brightens and goes black
I just fixed VS19 which more likely to be the same chassis as VS17, one of the lamps was bad, it had bad soldering works on it. You may want to look at the power supply first jsut to be sure it is not bad caps problem. Lamp repair is very complicated (LCD panel had to be disassembled). see eaxmple of what I just fixed yesterday: http://s807.photobucket.com/albums/yy352/budm/HP%20VS19D/
Post back what you see inside so we can guide you further.
Jan 31, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Hp vs17 monitor is glitching
Look for bad caps with bulging tops in the power supply section. See some examples of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 07, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Hewlett-Packard vs17 half fixed, what to do next?
I have also seen this type of problem. Have you checked the large caps on the inverter board, no just the power supply board? Many LCD monitors have 2 caps on the inverter and I have had to replace them from time to time. The next thing to check would be the driver transistors. I hope this helps.
Buddy
Jun 21, 2009 | HP vs17c 17" LCD Monitor
HP monitor vs17 goes black with power light flashing
I have repaired an HP 1702 monitor that had similar symptoms by replacing the capacitors on the power supply board but you have to have some electronic knowledge and do some soldering if you can buy the replacement capacitors($10+/-) from a supply store. They (at least 1) will be swollen up on the ends and may have a tar-like substance leaking from them. It is best to replace them all (may be 4 depending on the model).
Jan 08, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP vs17 monitor power button flashes blue but screen stays black.
Try put off Monitor uplug power cord and the VGA cord for 1min and reinsert and restart your PC.
Nov 25, 2008 | HP Vs17 17" LCD Flat Panel Monitor
LCD monitor dirty
please give me a power supply smd ic nomber please MODEL NO. HP VS17E
Jun 26, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Monitor is black, the blue lcd at the switch does not lite when switch is turned on. The internal fuse is ok. I tried to find a schmatic on I could check the power supply, no luck.
I have the same problem. Took it apart for troubleshooting. Found that if I disconnect the ribbon cable between the display driver circuit board and the LCD panel, I can turn on power and it will stay on. I can turn it on and off with the power switch. With the LCD panel cable connected, Power turns on (power light blinks) then apparently a fault with the LCD panel causes the power supply to shutdown. At this point the power switch does nothing. Now the big question is "Can you purchase a LCD panel?" If so, it probably costs more than a new monitor. Hope this was helpful.
Jan 02, 2008 | HP Vs17 17" LCD Flat Panel Monitor
HP vs17c 17" LCD Monitor Logo
278 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
