Question about Panasonic KXTG7745S KX-TG7745S KX TG7745S DECT 6.0 Cord
How to change handset numbers
How to change handset number 5 to number 3
3 Suggested Answers
SOURCE: Restting the phone handset number
I would suspect that you need to de-register both 3 and 4 at the same time before re-registering them. This probably will not work if the base unit still thinks phone number 2 is out there somewhere. It would need to be de-registered as well for the others to move up a notch. I did read the process for de-registering somewhere on the web, don't remember where, just that it involves removing/installing the battery and punching some buttons.
Posted on Nov 11, 2008
ercupa190
  • 12223 Answers
SOURCE: I have a new handset, and want to make it the #1 unit on my phone. How can I do this? on a panasonic kxtga641What's your problem?
you must locate the main input in your phone line, in other words coming from the street, and proceed according with common sense.
God bless you
Posted on Jul 22, 2012
Panasonic phone has duplicate handset numbers
Panasonic is famous for one handset not working. They like you to use their free repair, because then they can get the encryption code your phone system is using.
Local law enforcement frequently requires access to a suspect's stored phone numbers and/or conversations. So this makes it a bit easier for them to get that information. They just get the code from Panasonic.
I recommend that people just forget about the defective handset and store it somewhere.
Jan 20, 2014 | Panasonic KX TGA641 Cordless Phone
How do i sync my panasonic phones cordless kx-tga810
335 is the magic code when you want to remove a previous handset or base station registration!
Handset:
1 " (middle soft key) i L i #
2 Enter "335".
3 "Cancel Handset" i #
LThe numbers of all handsets
registered to the base unit are
displayed.
4 Select the handset(s) you want to
cancel, by pressing the desired handset
number. i #
5 "Yes" i # i {ih}
Base Station:
A handset can be registered to a maximum
of 4 base units. A handset can cancel a base
unit that it is registered to. This allows the
handset to "forget" the base unit.
1 " (middle soft key) i N i #
2 "Registration" i #
3 Enter "335".
4 "Cancel Base" i #
5 Select the base unit(s) you want to
cancel, by pressing the desired base unit
number. i #
6 "Yes" i # i {ih}
Dec 23, 2013 | Panasonic KX TGA810 1Line Cordless...
God bless you
Jul 21, 2012 | Panasonic Lands Phones
Forgot password
remove my passward in my cell
Jun 02, 2011 | Samsung SCH-U470 Juke Cellular Phone
How do i program your 20200-1 hand set telephone. it has 13 number memory. that i wold like to program?
To program one of the three emergency buttons:
1) lift the handset and wait for dialtone
2) press the STORE button
3) dial the phone number
4) press the STORE button
5) press one of the three emergency buttons
6) replace the handset in the cradle
To use; lift handset and press an emergency button, the phone dials the number stored for that button
To program one of the ten memory locations:
5) dial a one digit number(0-9) to store the number in that location
To use: lift the handset, press the MEMORY button, dial the memory location digit(0-9), the phone dials the number stored in that memory location
Here is a link to download the manual.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Feb 11, 2011 | Lands Phones
Only bass set going extra hand set not working
This is because the extra handset might have not been registered with the base unit.The headset should be register to use the headset with that base unit.
To register the handset to base unit please follow the instruction:-
On registration the handset is allocated a handset number for use on the new base unit, the handset numbers are 1-5.
1. Press and hold
d65e3ff.jpgon the base unit until 608a95f.jpgstarts flashing. Registration mode will remain active for approximately 3 minutes.
2.Press and hold both
19efd34.jpg together until you hear a long beep.
3.Select the base unit you wish to register by pressing the corresponding number button 1-4.
4. When PIN is displayed, enter the units PIN number (0000 for this model).
5. If the registration is successful the handset will return to standby mode in a few seconds.
Thanx
Jul 22, 2010 | Doro DECT 540 Cordless Phone
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
the memory location.
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | GE 29267GE3 Corded Phone
I have a Cable and Wireless Handset and I need to link it to the
On handset:
1 - "Menu",
2 - "System" (scroll using up and down then press "OK" to choose),
3 - "Register" (scroll using up and down then press "OK" to choose),
4 - "1" (use number keypad),
5 - "0000" (use number keypad again - or handset PIN if pin has been changed)
Now on base unit:
1 - press and hold down "Page" until it beeps
Hope that helps
Apr 05, 2009 | Lands Phones
Programming
MEMORY
Store as many as 12 numbers in memory for easy dialing. Three can be stored in the Emergency Quick Dial locations, and nine additional numbers can be stored in the numbered keys (1-9).
STORING A NUMBER IN MEMORY
1. Press SPEAKER (or pick up the handset).
2. Press STORE.
3. Dial the number to be stored (up to 16 digits).
4. Press STORE button.
5. Press a Memory Location (1-9 on the keypad), or an EMERGENCY QUICK DIAL button.
6. Press SPEAKER (or hang up the handset).
7. Record the phone number on the memory directory (located under the plastic cover).
ADDING A PAUSE TO THE DIALING SEQUENCE
Use the REDIAL button to insert a delay in the dialing
sequence when storing a number, for example, when you need to dial 9 to get an outside line. Press REDIAL at the point in the dialing sequence in which a pause is required.
Change a stored number by replacing it with a different
number.
DIALING A NUMBER FROM MEMORY
You can dial numbers from memory when using the handset or speakerphone. When you get a dial tone, press the MEMORY DIAL button followed by the memory location (1-9) for the number you want to dial.
Apr 27, 2007 | GE 29318GE1 Corded Phone
Verge cordless phone system v581tad
I believe you have the expansion capacity of the phone all used up. The phone cannot register any more handsets until you delete the handset registered that is not in use. First check the handsets and see what handset numbers they carry. It should be #1,#2,#3,and #4 if it does not then you will have to delete the one that is missing or if it is then delete handset #5.To do this you will have to use one of the handsets registered to the base. First Press the MENU/ OK button then scroll down to ADV,SETTING then Press MENU/OK then scroll down to DEREGISTER then Press MENU/OK. Then ENTER HANDSET PIN would show, if you have not changed the pin enter 0000 if you have enter your pin member. From the next options select HANDSET and press MENU/OK from the next set of options select the handset number you want to DEREGISTER and press MENU/OK from the next option select YES then MENU/OK. Then try to reregister the new handset To do this Press the MENU/OK button then go to ADVANCE SETTING press MENU.OK scroll to REGISTER then press MENU/OK Select the base number displayed then press MENU/OK. PLEASE WAIT will appear. Then from the base press and hold the PAGE button until the handset prompts you to ENTER PIN # .Enter 0000 OR your pin number then you will see PLEASE WAIT. A tone will confirm the handset registration.
Apr 03, 2007 | Uniden Cordless Phone
Panasonic KXTG7745S KX-TG7745S KX TG7745S DECT 6.0 Cord Logo
23 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
