Why is my speaker no playing, some sound but no bass?
    Problem Solver:
  • 11 Answers
Assuming that it is a large speaker with a large magnet on the back, and it has a large cone that was designed to play 'bass', if it has been dropped (or, for example was transported in a vehicle that went over a big bump - particularly with the speaker sitting perpendicular to the floor of the car/truck), the pole piece (magnet) in the very center shifts and pinches the coil between the outer magnet and the pole piece. This stops the coil from moving in and out through the magnetic field. Because high frequencies do not require much motion of the coil within the magnetic field, if the coil itself did not get broken in the process, higher frequencies (treble) will be reproduced (however poorly), but you'll get zero low frequencies (bass). This COULD be fixable, but a speaker repair specialist with a suitable demagnetizer would be needed to reposition the pole piece, and then, the whole cone would probably need to be replaced, as well. Depending upon whether it is an expensive (JBL/EV?) or a cheap speaker, it may be cheaper just to replace it.
Posted on Dec 07, 2014
Why is there no bass from my speakers when plugged into laptop?
Could be something wrong with the output from laptop.Try wiggling the jack in the connector while music is playing to see if there's any change.
May 21, 2012 | Logitech Speaker System Z623
My amp won't play bass everything is hooked up
I have a similar problem with my 2012 civic, I hooked up my 1800w kenwood mp to my 2 12" w6s and 1 song plays and sounds great, the rest of my songs have no bass from the subs, just the car speakers sound normal so I dont know what the hell thats all about. I thought it was a wiring issue but I can play the one song all day and it sounds perfect so any suggestions? thanks in advance
Jan 29, 2012 | Sony Car Audio & Video
I've got a 1999 ford expedition with the Mach radio system in it and it does not have any bass playing thru the front or back speakers and i've changed out the factory amp thats in the back where the sub...
does the new amp you have have a hpf setting if so check to see if thats on, turn off the x-over so it will play both lpf and hpf, bass and treble. are all the speakers wired to the amp aswell, this is the only thing that would stop bass other than the head units settings.
Jun 21, 2010 | 1998 Ford Expedition
They also try to play the bass
a crossover cuts the certain tones out of the sound.example: the high side cuts out low and mid tones,or the mid side cuts out high and low. The only problems this could be is that the crossover is not set right or not wired right. These speakers should be plugged into the high side of the crossover. If wired right and set right then your crossover is no good.
Mar 23, 2010 | Kicker KS13 Car Tweeter
Bass speaker moving in out more then normal
If you can't hear the difference maybe the bass frequency which is moving the speakers is below your hearing range.
I think you may have a "loudness" button on that amp -- if you do, turn off the loudness -- this is a bass booster.
But, in general, bass speakers are designed to move in & out a lot. They have to move a lot of air to produce the bass sound.
May 09, 2009 | B&W ASW1000 Speaker
Popping noise while computer is powering down. Any suggestions?
Lower your main sound volume. Double click the speaker icon in the bottom right hand corner of your windows.(was it maxed out?)
go into control panel /sounds and select a lower bass setting in your sound settings. You usually have a choice of rock & roll ( lots of bass) opera setting, classical etc.. choose one with less bass.
Make sure your LINE IN is DISABLED. It may be causing this static feedback.
You may have blown your speakers by playing sound way too loud. You may need to buy new speakers.
Thank you and Good luck. *s*
Oct 24, 2008 | EliteGroup P4M800PRO-M478 Motherboard
Noise from speakers when playing basses
hello, check and see if cabinet has loose screws or if back panel is tight,bass can vibrate screw loose.good luck! also look for anything caught in the woofer causing the noise.
Jul 28, 2008 | Audio Players & Recorders
Speakers stop playing when bass is turned up
may be there is problem with your woffer spk bcoz bass is contrlled by woofer see if you can see the spk cone is not tear or it is damage. bye
Sep 23, 2007 | JBL CREATURE II Computer Speakers
Fuzzy Speakers
Suggest that the speaker cone is damaged
Nov 15, 2006 | Dell A525 Computer Speakers
 Grubhead
Grubhead
