Question about Navman Tracker 5600 GPS Receiver
Navman 5600 wont find satellite
I took the head unit off for about a month and when i put it back on it turns on but wont find a satellite says its "aquiring" for hours. I have done a factory reset and left it turned on for the day with still no result.
SOURCE: navman F10
i'm having the sam problem this is my secound unit what is wrong with things pls help
Posted on May 01, 2008
SOURCE: Navman Tracker 5500 turns on but locks itself in the entry page
Apparently it is the internal battery that might be at fault or just be old. I'm going to replace mine as it costs a fortune to get Navman to do it. Can't find any info on how to do it, but should be simple. Only thing is that you lose all waypoints and other user input data (unless you have the PC Planner from C-Map).
Posted on May 15, 2008
SOURCE: navman s30 can not pick up gps
Took it To someone that knows about them, The GPS unit has failed its back for warranty claim NO WORRIES :)
Posted on Jan 21, 2009
SOURCE: how to get my navman reset to factory settings
how do i reset my navman icn 320
Posted on Feb 14, 2011
SOURCE: will not lock on satellites
First go into your menu and find GPS then go to restart gps and enter and see if it will reset. If not you will need to up date your unit as I am going to have to try once I recive the one and only card that the tech has to try this. Navman has been bought out by Norhtstar and you can call 1-800-628-4487 for support. They are eastern time and I did not get their open hours but I called at 6:50 AM PST and was able to talk to a live tech for help. The card that he sent will be here next week so I will be able to try fix on the Sat after as our boat is at its summer home. If my (or your) unit is too old then he said this too may not work but first try the restart GPS. Good luck, if it does not work for me then I buy a new and better unit as there is a flat rate charge from Northstar to repair of $350.00 !!!!
Posted on Jun 02, 2011
Have you got an user's manual fo a tracker 5600, I have bought a navman 5600 but it didn't have a manual with it.
That goes right to the pdf and should get you going.
http://www.navmanmarine.net/upload/Marine/Internet_Manuals/5x_series/MN000192C_TRACKER5600_Eng.pdf
Apr 01, 2010 | Navman Tracker 5600 GPS Receiver
F20 GPS
Remove memory and put it back, if it still does not work memory is probably faulty.
May 24, 2008 | Navman F20 GPS Receiver
Tracker 5600 cant see display worked fine last week
Last fishing trip was at night and due to the brilliance of the display my son turnred it down and unknown to me actually turned it off ( the backlight) and it was only after trying everything else found it was the simple solution of turning it (the backlight) back on. oops
Jan 05, 2010 | Navman Tracker 5600 GPS Receiver
I have navman tracker 5500 gps and the gps signal not working so there is no signel but all the charter is there
I HAVE THE SAME PROBLEM.U WILL FIND THE ANTENNA IS BUGGERED.THERE ARE NO SPARE PARTS AVAILABLE FOR THIS MODEL.LESSON; DON'T BUY NAVMAN OR NORTHSTAR.I HAVE ONE OF EACH. NEVER AGAIN!!!
Nov 17, 2009 | Navman Tracker 5500i GPS Receiver
Navman on start up will not complete boot up.
Mine was doing the same. Navman advised me to hook up to the computer and access the unit in my computer,
find my documents on the navman and delete the logs. Worked for me. However now I have another problem and Navman don't know who to fix it.
Apr 02, 2009 | Audio Players & Recorders
Pin 570 wont boot after hard reset
RECENTLY I DID PRETTY MUCH THE SAME THING
SO HERE IS WHAT I DID :
" I TURNED IT ON AND HIT THE HARD RESET AND THEN LEFT IT ON TILL ALL P[OWER WENT AWAY FROM UNIT
SECOND I HAD TO DOWNLOAN A NEW VERSION FOR MY UNIT ; MEANING MAP
THEN I TOOK THE BATTERY OUT AND AND PLUGED IN MY USB CORD AND IT TOOK IT
I PUT MY BATTERY IN AND CHARGED OVER NIGHT AND WELL IT SEEMS LIKE A LOT TO DO BUT FROM WHAT I UNDERSTAND MY DRIVER GOT BOOTED OFF THE UNIT AND ANOTHER DRIVER FOR A MODEL WAS ATTACHED
HOW I DONT KNOW BUT MY UNIT WORKS NOW FOR THE LAST 4 MONTHS NO PROBLEMS
HOPE THIS HELPS YOU OUT RICHARD FROM CHICAGO
Mar 30, 2008 | Navman PiN 570 GPS Receiver
Navman F10
Feb 10, 2008 | Navman F20 GPS Receiver
Navman tracker 5600
I have bought a boat with a Navman Tracker 5600 and I want to buy a C-Map card for it for my region, I have been told I need "the old black type" but no one can tell me what the card or type of card is called. I also need to find out where I can purchase onr from. Thanks to anyone that can help in anticipation, regards Trev T
Jan 22, 2008 | Navman Tracker 5600 GPS Receiver
"Searching for Satelite" - unable to find
10-15 minutes is normal.
Did you take it outside? GPS doesn't work indoors. Try in an open field, no trees. Should lock in a few minutes. I always do the following: i key in the destination address at home, then put it under 'favourites". When i start driving, i put the unit in my car and look up the recently added favourite. The unit then has enough time to lock on to the satellites.
Jan 07, 2008 | Navman F20 GPS Receiver
IPod and Sirius hook up
allpioneer products need power and ground to operate. check the fuse on the yellow wire. if ipod is not plugged in, it will not show as a source on the pioneer head unit
Oct 28, 2007 | Pioneer SIR-PNR2 SIRIUS Radio Receiver
Navman Tracker 5600 GPS Receiver Logo
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
