Question about Phonic Audio Players & Recorders
One speaker has lost all bass it is definitely an amp problem because I have switched leads etc. is this an easy fix or will I need to buy a new one
    Top Expert:
  • Phonic Master
  • 3,107 Answers
If you have switched speakers to make sure it's not just a blown woofer, then I'd suggest just replaceing the amp. It's odd for an amp to output treble but not bass on an output channel, and the tech time to figure this out could be more expensive than a new Phonic amp
Posted on Feb 02, 2015
2 Suggested Answers
  • 275 Answers
SOURCE: Connecting speakers to amp
Your Amp will be having a pair of Phono / AUX input sockets at the rear. Connect the two Red and White cabbles from the Turntable to these sockets. I am unaware of what are Pilot Speakers. regular speakers have a dual colored pair of cables coming from them. they have to be connected to the speakers Connectors at the rear of the Amp. Play a Vinyl Record, select Phono on your AMP, and enjoy your music.
Posted on Sep 17, 2007
Is my 1ohm 1 channel monoblock 4500 watts quantum amplifier to strong for my 3000 watts quantum subwoofers
If you are experiencing chirping or bottoming out the problem is you probably have your bass boost turned all the way up, your frequency responses probably turned all the way up, the speakers may not be able to handle that low of a Hertz, basically anytime you turn everything up on your amp you're going to get more and more disturbance this is most likely what you are hearing if you turn your bass boost down and turn your gain all the way down and the problem stops then this will be your solution, and it is an easy fix all you have to do is keep turning up your gain until you start noticing the Distortion then dial it back 10% you should never use bass boost on an amp it destroys the amp and definitely destroys the speakers
Jun 25, 2016 | Quantum Car Audio & Video
Where can I buy a replacement speaker for the Crate B100 bass amp? Someone took a screwdriver to the paper part of the speaker before I bought it at a pawn shop
The most reasonable place for a new speaker is Seismic Audio https://www.seismicaudiospeakers.com. If you don't care for that, look for an Eminence Delta series. You'll need to check your amp for what ohm speaker you need.
Jan 31, 2015 | Bass Music
Bass went out
The 15 inch woofer is blown and you are hearing only the tweeter horn. I would definitely check that speaker on something else though, because the amps inside will also blow fairly easy, and you can't get parts for these. I would salvage what you can and move on. If both speakers work alone, check connections and amp. If you find that the 15 does work, then make an unpowered monitor. Behringer does not give any referencing of any parts. They have all special part numbers that you can't crossreference to find replacements. This is a marketing strategy to eliminate others from repairing, so you will buy another one. They think they would sell more but it just turns musicians away from their junk. The only piece of behringer equipment worth using is the FCB1010 controller and nothing else.
Mar 14, 2014 | Behringer Eurolive B115D Powered PA...
Edifier C2 amplifier repair
My Edifier HCS2330 Amplifier stopped working and now the system is useless. Any recommendations on where to get it fixed from? Or any place i can buy the amp separately? or maybe even any other brand amp i can buy for cheap price?
Jul 14, 2013 | Car Audio & Video
Speaker has become crackly, only when i play certain notes though. I tried a different cord and bass and its definitely the amp. I have never turned the volume over three quarters, Should I just switch out...
Before changing the speaker, check for debris or other things in the cabinet or grill that MIGHT be rattling..
Also, plug in an external speaker to the ext jack and see if it is clean.
Aug 18, 2010 | Fender Rumble 100 Bass Guitar Amplifier
Hi, I have lost the base in one of my bose 802 speakers, Tried all the obvious stuff, amp, eq, cables, etc with same results, can anybody help?
If you have switched speakers to confirm that that speaker is faulty and not your amp, it's a question of opening up the speaker and looking for obvious damage. If none then find the bass driver and remove one connection to it. Then with a 1.5 volt battery connect the + to the plus of the bass driver and the - to the other terminal. ONLY FOR A SPLIT SECONED! If the bass unit works it should pop and you should see the cone move. If it doesn't either the wire from the speaker has come away from the terminal point (bad soldering) or the coil is open circuit (new bass unit I'm afraid). If it does pop it's something on the crossover that's faulty. Check for bad soldering first.
Jun 25, 2010 | Audio Players & Recorders
Bass speaker start up noise
Hello anne845,
It sounds like the installer wired the amp remote turn-on terminal to an "accessory" lead in your vehicle. Many stock radios do not have a dedicated amp turn-or lead and the alternative is to connect the amp to a switched power source (ignition or accessory). This means the amp turns on whenever you turn on the vehicle ignition, often resulting in a thumping from the subs. It is a perfectly satisfactory alternative, and will not damage either the amp or the sub. But it's irritating.
If the thumping is objectionable, have your installer wire a SPST (Single Pole, Single Throw) toggle switch inline with the turn-on wire. The switch should be mounted so it is accessible by the driver, and whenever you turn on the radio, turn on the toggle switch.
Hope this helps.
May 11, 2009 | Alpine SPX-17MB 300 Watts MIDBASS Speaker...
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
Jeep cherokee infinity amplifier
yes, you have a few options. Chances are, its your amp.
1st I would test the speakers - find the amp under the back seat, then test which wires go to the front speakers and use a AA battery to check if the speaker pops with those two wires and the battery.  If it does pop, its your amp needing replaced.  You can switch out that infinity amp for an aftermarket one very easy. Just use a testlight, or voltmeter to test the wires, and switch them to a new 4-channel amp.
if you need the wiring diagram, let me know...and dont forget to rate me! or ask for more help!
Sep 04, 2008 | Car Audio & Video
67 people viewed this question
Top Phonic Audio Players & Recorders Experts
Greg Cann
Greg Cann
rhodesworks
Are you a Phonic Audio Player and Recorder Expert? Answer questions, earn points and help others
