Question about Hilti Drills
Te 75 will drill but wont hammer ? - Hilti Drills
  • 2712 Answers
SOURCE: hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Posted on Aug 27, 2008
rowdy45176
  • 2176 Answers
SOURCE: Hilti TE-60 hammer drill
what I would do if you have a fax machine is call 1-800-879-8000 and request a schematic on this tool first. Some of their products are not that easy to disassemble. I never have worked on the TE-60 but have on some of their other products and they are all different. Hope this helps
Posted on Dec 19, 2008
rowdy45176
  • 2176 Answers
SOURCE: te-5 rotary hammer i need parts
Call Hilti direct at 1-800-879-8000 and speak to them. They can fax or ssend you a breakdown of the tool list. They will also sell you parts. I don't know of an outside source for Hilti parts. If I have helped you would you please rate my response accordingly and Thank you.
Posted on Aug 25, 2009
ftw1952
  • 10319 Answers
SOURCE: Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Posted on Mar 11, 2010
  • 123 Answers
SOURCE: HILTI TE 72
It could be that your connecting rod is broken. You can check by taking your shift lever off of the top of the gear housing and then removing the snap ring to remove the shift boss. That will allow you to look at the crankshaft and connecting rod. If it is broken I would check with Hilti to see if they still carry parts for the TE 72.
Posted on Mar 13, 2010
My Hilti TE 17 roto hammer rotates but wont hammer
This one should have a knob or lever on the side of it to switch between "drill" and "hammer plus drill" It can be used as either a regular drill or a hammer drill.
Nov 13, 2014 | Drills
What hilti hammer drills use TE-C bits? I want to buy one
TE2, TE4, TE6, TE7, TE30, TE40. The 30 and 40 are only corded, (not cordless).
TE-C bits come TE-C (standard head) and TE-C3X which is a high performance bit. SDS is the industry term for this connection.
Dec 09, 2012 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
TE 12 Wont Hammer
answered on another solution
Oct 26, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilty TE 12 Hammer Drill Wont Hammer, but will run
Parts are no longer available for the TE12. Be carefull if you try to take it apart yourself. Some of the older models had a lead based grease in them
My hilti te-75 drills but is not hammering or will not go into chisel mode whay coud be the problem with it
Have seen this problem with some 'none' HILTI bits which do not fit correctly into the SDS chuck.
Tends to be with larger drill bits which have a wider shank than the SDS connector, the wider shank hits the end of the drill nose which stops the end of the drill bit contacting with the internal hammer.
Solution is to purchase original bits from Hilti. If you have OEM bits and chisel it will be another problem. Hope this helps.
Feb 07, 2011 | Hilti TE 70 Hammer Drill Performance...
I have an old hilti, model: te 12 s. it wont drill. when i press the botten it only hammers. i have tryed to open the machine but i can not find the problem.
IT could be one of two problems. 1 The Rollers are missing out of the chuck so that it is not turning the bit. 2 the clutch is worn out causing the gears to slip. The problem is there are no longer parts available for the 12S. You would have to find them on Ebay or some place like that.
If the bit seems to lock into the chuck then it is not the rollers. It is more than likely the clutch.
Aug 08, 2010 | Hilti 375847 TE-CX 3/4" x 12" Masonry...
Te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Jul 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Mar 11, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Drills Logo
63 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
