Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
Have 1975 Merc 115 h.p. motor. won't turn over with key
Was runnig good when shut off by key, 12 hours later engine won't do anything. even the elect choke by key switch does not worknow. Checked battery connections &are ok. Checked starter by jumping direct from battery and it works, but would start even with key in start position. does the ignition switch on shifter case have a fuse somewhere? or maybe need new switch?
  • 77 Answers
It may be your neutral safety switch. Try it again but this time turn the key with one hand and wiggle the throttle/shifter lever at the same time. My 25 johnson does this, but usually I can wiggle the shifter and she'll turn over. Hope this helps.
Posted on Jun 23, 2009
1995 Isuzu Rodeo won't start all of a sudden.
Check connection battery,could be starter.
Jun 05, 2013 | Cars & Trucks
Had the car detailed and now won't start, nothing works
check to see if gear shift didn't get nudged out of park.
Feb 08, 2013 | 2008 Cadillac CTS 3.2
2002 silverado 1500 hd won't start
When you turn the key to start does the starter engage an spin the engine ? or nothing happens .
the lights and music come on but the motor will not start when I turn the key ??????? Will not start how ?
crank - no - start or no crank no start . ????????
Feb 26, 2018 | 2002 Chevrolet Silverado 1500HD
Went to the beach for the 4th. When I went to leave and start my car, the car would not turn over. All the electical would work, headlights stereo, windows. However the car would not even turn over. No...
sounds like the ignition switch do you have allot of keys on your key ring ?having allot of keys and other junk on your key ring will wear out a ignition swing and ruin it from the weight
Jul 05, 2011 | Volvo V40 Cars & Trucks
I have a Dayton 36'' chicken house fan with 115/230 there I found 6 wires, orange &black wire nutted together . white,yellow hooked to electic(White wire from electic). purple hooked to (black...
GRAINGER.COM THEY HAVE A TECH LINE, BUT ON THE MOTOR LABEL IT SHOULD HAVE THE WIRING DIAGRAM .. GOOD LUCK AND I'FN I WAS ANY HELP PRAISE IS APPRECIATED .. SO VOTE JAY MOTORWIZJ
May 27, 2010 | Dayton Permanent Split Capacitor Motor Fan
Yamaha 115 will not shut off with key or kill switch
not enough information on the motor. what year and model? but all yamaha outboards are shut down by the C.D.I. being grounded by the key switch or the emergency kill switch. the cheapest thing to test or replace is the key switch and the emergency kill. with more info on engine I can help you further.
Sep 23, 2009 | Light Outboard Motor Boat Bass Fishing...
1.5 hp waterway champion pool pump issue
Be sure you have connected the motor to the line leads correctly and that the motor is set for the proper line voltage.
A somewhat common problem is that most motors are dual voltage (can be ran on 115 or 230 volt) and come factory set for 230 volts. If you connect it to a 115 volt circuit it will run for a while and then overheat and shut off.
Jul 28, 2009 | Waterway Champion 1 1/2 Hp 230v Energy...
Engine won't start. Dash lights flash rapidly when key turned.
the battery says 12 volts but may be dropping to 4 or 5 under a load...i would suggest jumpstarting the car and see what happens.the battery should read in the high 12 volts and not less than 9.5 under cranking. the dash lights go out on your car when starting,and the alarm will go off ,and disable the ignition if the voltage is too low in cranking the car because the computer will shut it down and activate the anti theft.....check your battery posts are tight. best of luck
Jul 22, 2009 | 2006 Honda Accord
Need help replacing solonid on mercury outboard
You may have enough room for a wrench. I have an old ignition set of small wrenches and those are slim. There is also a fitting called a crowsfoot which is thick like a wrench but short and fits on a rachet extension. The 1/4" drive set of sockets are usually shorter than 3/8th. If you have a camera, take pictures and go to Sears with it and buy something to work.
Jun 24, 2009 | Light Outboard Motor Boat Bass Fishing...
Bad key switch on 1975 merc. 1150 outboard
Here's something to try. There are cans of plastic coat to dip stuff into to insulate them. Then you could also try to remove the terminals and use shrink tubes on the wires and then replace the terminals. If only for a short while you can see if that fixes the problem.
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
432 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Ian Summerfield
Ian Summerfield
Are you a Light Boating Expert? Answer questions, earn points and help others
