Question about Technics SL-DZ1200 CD Player
I have a Technics CD changer SL-PD867 it will not play re writable disc's any other disc ok
    Top Expert:
  • Technics Master
  • 6,702 Answers
Not all CD players can or will play CD's burned in a PC. Sometimes the CD player is to old, so not compatible with these CDs. Sometimes the player just does not play these CD's, because of rights protection.
A CD burned in a PC is less reflective than an normal music CD. Normal CD's do have a metal coating and are highly reflective. Burned CD's have a dye, and where the laser burned the dye, it only changed colour. Making it less reflective.
All modern CD playes should be capable of playing CD r's. But the player that is really compatible, is labelled CDr and CDrw compatible.
Posted on May 23, 2014
techman
  • 3130 Answers
SOURCE: Disc gets jammed mid-way between CD magazine slot and inside player
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
Posted on Oct 06, 2006
informatica
  • 1114 Answers
SOURCE: Random play
Hi - You can download the manual by clicking the link underlined in blue below:
SL-MC70
See page 17:
Note this feature requires the remote control!
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 05, 2008
  • 6 Answers
SOURCE: Technics 5 cd changer Model sl-pc11 will pick up
System will not play Mp3 or data format cds.
Audio cds only . Also Clean lenses with a cd lenses cleaner .
clean cd also straight away from center ,soft cloth
Check for scratches .
Posted on Mar 01, 2009
  • 3 Answers
SOURCE: I have a technics 5 changer CD player, model#
You ever get a solution to this, mate?
I have the same freaki'n issue with mine all of a sudden. Suspect the power supply's not delivering enough power to rotate the spindle-motor anymore, cause if I take this motor out and connect it to a 1.5V battery, it runs...
let me know if you've found the solution please on: tobie dot steyn at gmail dot com.
Posted on Mar 25, 2010
  • 141 Answers
SOURCE: Disc stuck in cd player
Easy, turn off the power, remove the lid by unsrewing all the screws on the side, back and top of the lid. When removed you should see the CD jammed somewhere at the rear of the disk carrier. be very carefull and slowly remove it. The disk may be already scratched but if you're carefull you can stop further damage. Also don't force any part of the tray they are only plastic. If you can't get the disk out things start to get awkward. Write backmor take the unit with the lid off to a repair shop it shouldn't take them long to get it out.
Posted on Apr 07, 2010
HOW TO PLAY COMPACT DISC WHEN COMPACT DISC PLAYER IS ON?
You press the play button......
If you have multiple disks, press the appropriate disk and it will play
How to Use Six CD Changer
6 Disc CD Changer Instructions eHow
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Feb 10, 2016 | Panasonic Technics 5 Disc Compact Disc...
Power it on and just get an off reading
Technics SL-MC4 61-Disc CD Changer Not reading ... - Fixya
www.fixya.com > ... > Technics > Technics SL-MC4 61-Disc CD Changer
Technics SL-MC4 61-Disc CD Changer, not reading cd related issues. Get free ... IHave A Tascam CC-222Mkll Will Not Read CD-R Or CD-RW But Will Read Store Bought CD's. I Have A ... I have just spent $69 for the software to convert it the way I wanted into mp3 format, being a format that I figured . ... Power the unit off.
Technics SL-MC4 61-Disc CD Changer Message center ...
Dec 29, 2015 | Technics SL-MC4 61-Disc CD Changer
I have a Technics CD changer SL-PD867 it will not play re writable disc's all other disc ok
You should realize that this player is about 20 years old.
It was not designed to read CD-R or CD-RW media.
The signal from these media types is different from audio CDs you buy.
May 11, 2014 | Technics SL-DZ1200 CD Player
Missing remote for Technicis Model SL-MC59 Cd changer
You will need to go online to Technics and contact customer support and the technical department to see if they can help.
Apr 05, 2012 | Technics SL-MC4 61-Disc CD Changer
I need manual for Technics SL-PD687 CD Changer
i need a manual for the technics SL-PD687 cd player
Oct 09, 2010 | Technics SL-PD687 5-Disc CD Changer
Disc will not play appears to be skipping
There is a product called a cd/dvd lens cleaning disc. Worth the investment to have around.
Be sure discs are free of dust and scratches.
Apr 27, 2010 | Technics SL-PD6 5-Disc CD Changer
I put 5 cd's in and they do not play. When I hit play, it will illuminate disc 1 and then it luminates disc two and so on. ''Technics sl-pd867 5disc cd changer''
have you tried removing the cover an using some canned air to blow dust and debris from the laser, try a cleaning disc..if all this fails..the you need to replace cd mech, I'm not sure if it is still available..i have replaced them before ..I can get part numbers and price if needed
Jul 04, 2009 | Audio Players & Recorders
Random play
SL-MC70
See page 17:
Informatica
Sep 05, 2008 | Technics SL-MC70 60-Disc CD Changer
Technics SL-DZ1200 CD Player Logo
168 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
