Alba tv I brought my TV yesterday, I put of straight up and started watching it with my kids no problems, turned it all off properley, got up this morning and its not coming on, the standby light isnt even work, all my plugs are fine and work so how do I get my TV to work now? X
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
Check whether the power comes to the TV first. If it's Ok, the main power supply regulator section circuit have the problem. Being a new TV, it should be under warranty. Do not open it, as doing so, you'll loose the warranty. Contact the authorized service center for Alba, or the dealer from you have bought it from.
Gopakumar Gopalan Google
Posted on May 11, 2014
  • 308 Answers
SOURCE: Sony FD Trinition WEGA KV-32fs120 32" (no picture)
If the standby light is blinking 5 times then repeating, it is likely a problem in your picture tube or related circuitry. Other possibilities include the "Jungle" IC which takes care of the video, chroma and deflection processes and is a bear to replace. Either way, it could be an expensive repair.
Posted on Feb 11, 2007
  • 556 Answers
SOURCE: phillips 27 inch tv
did you check remote like battry, loose nothing is deposited near battry contact etc. if it is getting on from front board and not from remote then fault is due to remote. but if does not start from front also then problem is inside tv. like power supply or horizontal section failure. please do not forget to check plug & socket.
Posted on Oct 06, 2007
SOURCE: tv won't turn on no light in front
just purchase the new manuul for your Tv (universal cremote control the if it will not work write to us sothat I can assist you to find thr codes.
Posted on Mar 24, 2008
SOURCE: panasonic CT-32SL14 flat screen tv stopped working
I dont know if this will help anyone....but I opened the TV up and found a blown fuse right wherer the power cable connects. I replaced the fuse and while doing so noticed alot of dust and what seemed like part of a spider web. I got a can of compressed air and cleaned it up. Once I put in the new fuse the TV worked perfectly.
Posted on Aug 12, 2008
ginko
  • 19396 Answers
SOURCE: Standby Indicator flashing SONY KD-32NX100U
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
Alba lcd32880hdf has lost colour when watching Tv but works when using games console
It is almost for sure a bad connection at you wires. To show in black and white means your red and green are reversed or bad. I am guessing you have this hooked up with component.
Jan 27, 2014 | Televison & Video
Alba tv flashing blue light tv turned itself off
If it turns off after a while that's a transistor going hot.
You need a technician to test it for you. If you want to do it yourself
let me know. Good luck.
http://www.tvrepair.localdomain.me
Jan 08, 2014 | Alba Televison & Video
Alba 32inch hd lcd tv
The internal power supply may have failed.
Nov 14, 2013 | Televison & Video
Alba 42"lcd tv watching tv it just went off,
Alba is now a product of Argos, their low cost help line number is 08456040105
Nov 18, 2010 | Televison & Video
Subtitles keep coming on
Hiya, have bought an Alba 26" LCD TV myself today. If you go into the menu and then into subtitles change it from English to Dutch. This should solve the problem. :-)
Dec 13, 2009 | Televison & Video
Samsung 65 in Mod HCN653w Picture Distortion
Do you have this problem on all inputs to the TV (Tuner,Video, Component, S-Video, etc...)? or just one? And does it affect the TV menu when it's brought up on the screen or no?
C-Dog
Feb 10, 2008 | Samsung HCN653W 65" Rear Projection...
Tv code for Alba 14" tv
need code # for tv durabrand modle no.DWT2704
Dec 13, 2007 | Durabrand DWT2704 TV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
