Question about Canon imageRUNNER 5570 Copier
Change the job no every start button and remove the paper from the output tray
  • Lenin Hudiel
    Lenin Hudiel May 12, 2014
    Hi Pardeep Kaushik, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Is a finisher installed on the machine
  • 88 Answers
Foreign material or paper debris
around the purge drive system unit;
remove foreign material
Posted on May 12, 2014
  • 100 Answers
SOURCE: system error indicated paper in output tray to be removed
I would unplug the machine and start back up.
Besides that you can take a canned air can and blow around the area where the paper comes out. Esp around the back. This is either a dirty sensor or a sensor flag that is hanging up or out of position.
Posted on Jan 09, 2009
komguy
  • 2306 Answers
SOURCE: error, paper output slot
That means the sensor flag under the platen roller is broken, bent, or jammed in the up position. Hard to see and must be taken apart to repair.
Posted on Aug 07, 2009
SOURCE: The ip4500 will not print - says the paper output tray is open!
Just fixed this problem on mine. Need to remove the covers, watch these 2 vids to see how..
http://www.youtube.com/profile?user=martop49#p/u/1/iQdHDR6po80
Then on the right side where the on switch is, near the hinge is a little switch with 2 yellow wires, it's probably broke. Pull the 2 wires out and solder or twist them together, then put everything back together. It will now assume the door is always open. Jobs a good'n :)
Posted on Jan 07, 2010
  • 85 Answers
SOURCE: paper jam in output tray is displayed but i cannot solve
The way most printers know their output tray is full is by a little flag that passes by a sensor. Look for a little piece of plactic that should be hanging right by where the paper comes out. It is flag is not hanging then it must be **** and it is reading output full. Hope this helps.
Posted on Apr 29, 2010
curtiende
  • 341 Answers
SOURCE: Message says Remove paper from
open the printer and remove papers from the paper way. there could be pieces stuck in
Posted on Apr 11, 2011
I have a paper jam at the back of my printer, where do i open it
Hopefully this will help you. Good luck !
Causes of jams
NOTE If you are experiencing jams in the duplex paper path, make sure that the duplex-tray
lever is set to the correct media size for your country/region. Open the duplex-paper-path door
and look at the embossed arrow on the lever. Make sure that it points to the media size for your
country/region. If the size needs to be changed, push the lever all the way in for duplex printing
on letter- and legal-size media, or pull it all the way out for duplex printing on A4-size media.
A4
LTR,
LGL
A4
LTR,
LGL
Occasionally, paper or other print media can become jammed during a print job. Some causes include
the following events:
? The print media that is being used does not meet HP specifications.
? The media is damaged or has objects attached to it, such as staples or paper clips.
? The environment in which the print media was stored is too humid or too dry.
? The input trays are loaded incorrectly or overfilled, or the media guides are not set correctly.
? Too many sheets have accumulated in an output area, or sheets are blocking an output area.
? Media is added to or removed from an input tray during a print job or an input tray is removed from
the all-in-one during a print job.
? The cartridge door is opened during a print job.
ENWW
Mar 13, 2015 | HP LaserJet 3300 All-In-One Printer
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
What does e073 0003 error mean on canon 1180.
E, 0, 7
FINE Cartridge is not installed in the correct position
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
Techbelkin please rate me
Nov 03, 2010 | Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Summary
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Can't get paper jam out of computer
Here is the HP website for your Photosmart D5069 printer. Here is what they recommend:
IssuePaper is jammed in the product. SolutionFollow these steps to clear the paper jam from the product. Step one: Remove any loose paper Remove all loose paper from the input tray and output tray. CAUTION: Do not remove jammed paper at this stage. Step two: Clear the jam from the back of the printer
  1. Press the power button (c01628209.gif ) to turn off the product, and then unplug it.
  2. Remove the rear access door. Figure 1: Removing the rear access doorc00439062.gif
  3. Gently remove the jammed paper from the product.
  4. Replace the rear access door.
  5. Plug in the product, and then press the power button (c01628209.gif ) to turn it on.
  6. Try the print job again.
  • If the print job prints successfully, you do not need to continue troubleshooting.
  • If the issue persists, proceed to the next step.
Step three: Make sure that the carriage moves freely
  1. With the product turned on, open the cartridge access door. The carriage might try to move into the access area. Allow it to move to that position.
  2. Without turning off the product, disconnect the power cord from the back of the product. WARNING: In the following steps, you move the parts by hand. If the power plug is not unplugged, there is a risk of an electrical shock.
  3. Disconnect the power cord from the wall outlet.
  4. Look in through the cartridge access door or the output paper tray to make sure that the cartridges are secure in the carriage and have not come loose.
  5. Check for any obstructions under or around the carriage that prevent it from moving.
  6. Make sure that the carriage can move freely across the width of the product by firmly pushing the carriage to the left and then to the right. Clear any obstructions.
    NOTE: You might have to reach through the output paper tray to access the carriage.
  7. Close the cartridge access door.
  8. Reconnect the power cord to the back of the product.
  9. Reconnect the power cord to the wall outlet.
  10. Press the power button (c01628209.gif ) to turn on the product.
  11. Try the print job again.
  • If the issue is not resolved, proceed to the next step.
Step four: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Hope this helps.
Good Luck
Feb 22, 2010 | HP Photosmart D5069 InkJet Printer
I have a Xerox 7345. Instead of printing red it
In one of these diagnostic areas you will find an auto gradation adjustment, perform that. Here are the steps.
To enter the CE mode:
  1. Press and hold the 0 key for 5 seconds, then while still holding down the 0 key, press the Start button.
    The CE Access Number screen will appear.
  2. Enter 6789 and press Confirm.
  3. The top most area of the UI display will be reversed to let the user know that the mode has changed to the CE mode
  1. Enter the Diagnostic mode.
  2. From the Common Settings screen, select Image Quality Adjustment.
  3. Select Calibration.
  4. Select the button of the Screen Type to be calibrated, that is, Copy Job - Text, Copy Job - Photo, Print Job - Text, or Print Job - Photo.
  5. Press the Target button and then select the type of jobs to be calibrated, that is, Copy & Print Jobs, Copy Jobs Only, or Print Jobs Only.
  6. WC 72XX only: Load A4 paper in the Tray 5 (Bypass). Press Save.
    WC73XX only: Select a paper size and type using the paper supply button
  7. Press Start. The auto gradation routine will run and a message will display upon completion.
  8. Take the print from the output tray. Follow the instructions on the screen to complete the color correction.
Jan 15, 2010 | Xerox WorkCentre M-24 Color Copier
Is there a fix for error 6A80 for a Canon mx700 printer?
You can try a few things:
RESET the printer:
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Check for paper jammed in the paper output slot, the Rear Tray, or the Front Tray.
Remove the paper following the procedure below.
(1) Slowly pull the paper out, either from the paper source or from the paper output slot, whichever is easier.
(A) When printing from the Rear Tray
(B) When printing from the Front Tray
bullet_s.gif If the paper tears and a piece remains inside the machine, open the Scanning Unit (Printer Cover) and remove it.
After removing all paper, close the Scanning Unit (Printer Cover), turn the machine off, and turn it back on.
* Be careful not to touch the components inside the machine.
bullet_s.gif If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
(2) Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step 1, all print jobs in queue are canceled. Reprint if necessary.
i_note.gif Note
bullet_s.gif When reloading the paper in the machine, confirm that you are using the correct paper and are loading it into the machine correctly.
bullet_s.gif A5-sized paper are suited to print documents consisting mainly of text. We do not recommend using such paper to print documents with photos or graphics, since the printout may curl and cause paper exit jams.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, you should take the printer to a service shop since the printer will have to be disassembled to remove the torn paper.
Oct 16, 2009 | Canon MX700 Office All-In-One InkJet...
Using HP 1100d Office Inkjet printer. Can't get 'out of paper' light to turn off. I have added paper, pressed the reset button, but light stays on, and printer will not operate.
Please read over the following information and follow step by step.
Issue Either before or during a print job, the message ' Paper Jam ' appears on the product control panel display. The product does not output paper or complete the print job. Solution Follow these steps to resolve the issue. Step one: Remove any loose paper
  1. Remove any loose paper from the paper tray and output tray. CAUTION: Do not remove jammed paper at this stage.
  2. Press the Cancel/No button on the product control panel to clear the paper jam message.
  3. If the paper jam message cleared, try the print job again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , continue to the next step.
  1. Press the Power button (c01345237.gif ) to turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the rear access door: Turn the knob one-quarter turn to the left and pull the door away from the product. Figure 1: Remove the rear access door c01489996.gif
  4. Gently pull the paper out of the rollers. CAUTION: If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If any torn pieces of paper remain inside the device, then more paper jams are likely to occur.
Step three: Clean the rollers While the rear door is removed from the product and the power cord is disconnected, clean the paper rollers.
  1. Wipe the paper rollers with a lint-free cloth that is lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. Figure 2: Clean the paper rollers c00246512.jpg
  2. Allow the rollers to dry completely.
  3. Replace the rear access door. Gently push the door toward the product, and then lock it in place by turning the knob one-quarter turn to the right or locked position.
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button (c01345237.gif ) to turn on the product.
Step four: Reload paper and test the printer Load a stack of plain white paper in the paper tray and try the print job again.
  1. Press the Cancel/No button on the product control panel to clear the paper jam message.
  2. Lift the output tray.
  3. Pull out the front paper guide on the paper tray and slide the side paper guide as far to the left as it will go. Figure 3: Slide out paper guides c01489992.gif 1 - Front paper guide 2 - Side paper guide
  4. Load a stack of plain white paper, print-side down into the paper tray. Make sure the paper stack is no higher than the top of the front paper guide.
  5. Adjust the side and front paper guides to fit snugly against the paper stack. Figure 4: Adjust the side and front paper guides c01489993.gif
  6. Lower the output tray.
  7. Disengage the photo tray: On the output tray, pull the slider (visible through the output tray) away from the product until it stops. Figure 5: Disengage the photo tray c01489994.gif
  8. Try the print job again.
Step five: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product. Have a good day,
Jun 18, 2009 | HP Inkjet 1100d Printer
Mar 23, 2009 | Canon Pixma iP4500 InkJet Printer
System error indicated paper in output tray to be removed
Jan 08, 2009 | Canon Office Equipment & Supplies
Canon imageRUNNER 5570 Copier Logo
14 people viewed this question
old marine
old marine
