Junkers tr200 My controlor has problem-display doesn't work. After short power outage in my city ( 5 second) it doesnt't work any more. what shod I do?
    New Friend:
  • 23 Answers
Try powercycling it. Disconnect the power, check any fuse or fusable link, replace any battery/ies. Check the connectors by gently removing and replaing one at a time, check wires at the connector to see if there might be a bad connection. If it works, but no display, you have power to the unit. Look to see if there is a bad connection at the display.
Posted on May 11, 2014
Display window in my comfortstar indoor unit not showing all temp digits, happened after power outage.
Unplug unit from wall for 10 seconds. Plug back in. If no display you likely have a shorted control board.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 12, 2017 | Heating & Cooling
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
How to reset a samsung refrigerator model number rs261mdpn aftthea power outage
http://www.searspartsdirect.com/partsdirect/part-number/Samsung-Parts/Refrigerator-Parts/DA41-00669A/0046/401/Model-RS261MDPNXAA/1482/0165000
this is the control board you will need for your model if unplugging the unit for 5 minutes doesn't fix the problem. If they are LED lights, then I point my finger at this. This is a plug and play board with molex connectors. Very easy to install with unit unplugged. You can manually reset the display and check for error codes by holding the top left and top right button on your user interface for 5 seconds in unison FOR 5 or more seconds after all the lights flash.
Feb 01, 2015 | Samsung 26.0 cu. ft. French-Door Bottom...
Our microwave MH6150oxhq-1 has worked perfectly until yesterday when i went to press start the clock numbers started flashing and poof dead!! It seems like I have NO power to the unit, Is there a way to...
If it doesn't come back after you unplug it and plug it in again, you probably have a blown fuse or thermal protector. If it is a thermal protector, just replace it - they do sometimes break spontaneously. If it is a fuse, have the high-voltage capacitor checked to see if it shorted. Generally if the capacitor is shorted, it is a good idea to also replace the high-voltage diode since it carried the short-circuit current that blew the fuse.
I assume by "clock numbers ... flashing" you mean the normal timer countdown began. If there was abnormal behavior on the display you have a controller problem. This could be anything from a failed power supply capacitor (relatively cheap fix) to a bad controller chip (only available on a replacement control board that costs almost as much as the oven itself unless you get lucky enough to find one on a junker of the same model).
Sep 09, 2011 | Ovens
Fax machine Error 77 What do we do?
This is a Heater thermistor short circuit, to reset it...
  1. Unplug the power, press and hold the menu button, plug in the power
  2. (hold the menu button for 5 seconds after power is plugged in). Release
  3. the menu button, now press 91, if the display still shows the error,
  4. press 99.
Most people just ignore it, I suppose eventually if the thermoster is malfunctioning you could burn the printer out. But from a cost perspective I don't think it's worth replacing.
Jun 10, 2010 | Brother IntelliFax-4100e Fax
Refrigerator will not reset after a power outage
just unplug it wait 5 minutes and plug back in. If this doesn;t work, replace the mother board.
David
May 16, 2009 | Samsung RS2534 Side by Side Refrigerator
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
Power outage - recorder broken?
Hi;
One week ago we had the same problem. And I Send the machine To Technical Service. They Changed the harddrive and reprogrammed the mainboard. Now it plays&record very well. I think U must send it to Samsung Technical Service.
Best Regards.
Firat
Feb 12, 2008 | Samsung DVD-HR720 DVD Recorder
Heating & Cooling Logo
201 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
