Question about Polaroid Tablets & eReaders
I have a polariod ptab8000 and it won't mount my new 8gb micro external card, whatdo i need to do
    Sergeant:
  • 258 Answers
Check the microsd card in another machine first - it may be the card that is snafu.
Or if you have another card try that and if it doesnt work either you know the sdcard slot is damaged - the pins are easily broken or the small spring inside sometimes pings loose.
Posted on May 13, 2014
2 Suggested Answers
willem52
  • 359 Answers
SOURCE: Hello, I have bought an adapter
Your Finepix F10 does not support SDHC (High Capacity) memory cards.
You can only use standard SD cards with a maximum capacity of 2GB.
New technics are not always backwards compatible, sorry for that.
Posted on Jul 21, 2011
How do I download apps onto this device?
The default on most tablets is to install apps to internal storage so the SD card does no good by itself. You can go into Settings>Applications and change the location for each app to the SD card. Likewise anything else you put on a tablet, particularly photos and videos get stored in internal storage. If you have taken a lot of photos and videos they can fill up your storage quickly. You can change this in the Camera app by tapping the settings icon and changing the storage option to SD card. You will still need to actually move existing photos and videos to the SD card manually or copy them to external storage and delete them. I would also change the image and video resolution in Camera settings to 640x480. This is plenty good enough for pictures you just want to look at on the device or share online.
Jan 04, 2016 | Trio Stealth G2 7 inch Tablet with 8GB...
Apps on external SD card?
In the Android settings menu find the application manager. Find the app that you would like to move
When you click on the app you will see a button that says move to SD card
Oct 10, 2015 | Visual Land Prestige Pro 7G Android 4.1...
I inerted a 32gb SD card and nothing happened so I popped it out anthem I could not get it to pop ck in tablet said new SD card???
When you insert an SD card in the slot the tablet will *mount* it automatically. This means it connects to it and formats it and adds some files and folders so it can utilize it.
Before you remove it you need to go to Settings>Storage>External SD and touch the *unmount* option.
If you don't do this there is a chance the card can be corrupted and can become unusable. If the tablet said new SD card then you might have to go into Settings>Storage>External SD and touch the *Mount* option.
If it's a new SD card chances are you didn't hurt it. But if it's a use one on which you had a lot of data stored and you didn't unmount it before removing it you could have damaged the file structure and your only option to get it back would be to put it into a card reader on a laptop or desktop and reformat it.
Apr 14, 2015 | Dragon Touch Touch R10 10.1 Google Android...
Where is a tutorial to learn how to load micro sd cards and flash drives for tablet use?
http://www.howtogeek.com/201980/how-to-mount-a-flash-drive-on-your-android-device/
Apr 01, 2015 | Coby Kyros MID8120-4G 8" 4 GB Tablet -...
Which 32G micro sd card is compatible with the nobis nb09?
Whatever brand of card fits your budget will work.
Feb 11, 2015 | Tablets & eReaders
How to fix error downloading insufficient space on device but I have a 8gb microsd card with lots of room and nothing will download please help this is my second next book tablet I just want to fix th
Amber,
I think your problem may be due to it downloading into the internal memory of the tablet. There may be a way of moving the apps into the external micro sd card rather than deleting them.
From http://www.tomsguide.com/forum/id-2055729/set-downloaded-games-google-play-directly-external-card-samsung-galaxy-tab.html
" Go into settings, then to storage, then to used space, then to applications. In applications manager go to sd card there will be a list of your applicationsicon1.png, touch/click on each one individually and within each one that can be moved, is a box "move to sd card" touch that box and wala it is moved! To move pictures I reset the cameras auto storage to the sd card then moved all my other pictures to the camera file which then stored them on the sd card. I then deleted the pictures from the system memory. Hope this helps! "
Jan 24, 2015 | Tablets & eReaders
How does ram vs internal storage work on tablet?
There are 2 storage in just about every smartphone or tablet. There is an internal storage, usually about 1gb. or 2gb. And there an internal SD storage, which is not same as the external micro sd card. RAM stands for Read Access Memory, it will not work as storage. Now, when you download an app it is usually save in the internal storage. If you move an app without an external micro sd card inserted, you are moving them to the internal SD storage. If possible got to setting>storage and check how is the storage divided, if you insert the external micro sd card it should display 3 separate bars. Also, another way to move apps and other things around is by using ES File Explorer. Check that out first and I hope you do resolve the problem, best of luck.
Jan 22, 2015 | Tablets & eReaders
How do i mount my 8gb external micro sd card on my polariod ptab8000
The Micro SD Card Slot is on the side of the tablet in between the Headphone Jack and the USB Port.
If the card slot has a symbol near it with the letters "TF" than this is OK.
"TF" stands for TransFlash which is a common name for SD.
May 11, 2014 | Tablets & eReaders
Tablets & eReaders Logo
41 people viewed this question
Top Polaroid Tablets & eReaders Experts
John mullen
WTF Chuck.....
WTF Chuck.....
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
