TOSHIBA 21INCHES TUBE TV RED AND GREEN POWER FLASHING
    Top Expert:
  • Televison & ... Master
  • 74,482 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Search the site by brand name of your set.
Posted on May 11, 2014
2 Suggested Answers
  • 2318 Answers
SOURCE: Toshiba TV, no power, red light flashing
Unplug the TV for 2 minutes and plug it back on.
It should work.
Posted on Feb 09, 2008
Toshiba rear projection TV
if you are seeing just green and purple color then your red crt is not working could be just a loose connection on the red crt socket or a bad red crt . crt meaning red picture tube.
May 22, 2013 | Televison & Video
Can i fix my tv screen is red
Toshiba 36A10 36" TV is the model you have indicated---
If the screen is all red and or too bright (no green or blue can be seen) the problem is in one of two places: Either a shorted picture tube or the board that plugs onto the end of the tube.
That board sends red,green, and blue video and information to the picture tube via 3 pins on the tube (the K or cathode for each).
The set will have either 3 IC's on that board or 3 transistors, or a single larger IC for this.
to troubleshoot this:
I would locate the Red Cathode and unsolder that pin at the socket on that board--takes red out---if you have green and blue picture then---it is either the IC/transistor that feeds that on the board or the tube itself.
If it has 3 chips (usually will each have a metal plate attached for cooling) you can either remove and replace the red one OR what I do is swap it with the green or blue chip---if suddenly you now have a blue or green only screen you know that part is bad--simple as that.
If for any reason the picture tube turns out to be bad--you are finished and so is the set= way too expensive to replace it.
Let me know if you have questions or need advice.
Mar 28, 2012 | Toshiba 36A10 36" TV
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Turn on pic turns red with thin bright red horizontal lines
Sorry to say, but that's usually the sign of a bad picture tube. One of the elements inside the tube shorts and you see the picture you describe, and the set shuts down due to high voltages getting to places it shouldn't. There's no solution except picture tube replacement, and that is uneconomical. You're better off replacing the TV when the tube goes bad.
Mar 31, 2009 | Toshiba Televison & Video
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
5 flashing light code
Disconnect RED Tube CRT board if set plays without shuting off RED tube is bad or video IC on CRT is bad.
Feb 12, 2009 | Sony KP-51HW40 51" Rear Projection...
Toshiba 57H81 Flashing Red Power Light, Blown Fused F850+F852
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
  • Upon turning on set I got flashing red power light and nothing else.
  • Removing plug for one minute and plugging in results in:
    • Audible click, steady red power light for 2 seconds then slow flashing red light
    • Pushing power button results in steady red for about 2 seconds then slow flashing red light, no other set activity
  • Removing power cord for several hours and plugging back in made no change
    • Audible click, steady red for about 2 seconds then slow flashing red light
  • Possible related note: Over past several months occasionally the entire screen would flicker momentarily and at other times be problem free for weeks.
  • Fuses F850 and F852 found blown
Repairs Made:
  • PD0074 DEF/CON Power Board
    • There are two main power supply capacitors in this set. They are C-809 and C-810. One their negative lead on the printed circuit board re-soldered leads and nearby contacts. I’m told that because the factory left out a printed circuit board eyelet, the connection will come loose over time. When I called Toshiba customer service they said there was a known solder joint problem causing blinking red light.
    • Replaced blown fuses F850 and F852.
      • I actually installed a fuse panel on the inside of the cabinet and routed the fuse connections here instead of ordering the special fuses and replacing them on the circuit board.
      • Had to use a 5 Amp SLO-BLOW for F850. Fast blow does not survive power up. Get the red blinking light.
      • Used a fast blow 2 Amp for F852.
  • PD0073 SIGNAL Board
    • Re-soldered Q751 + Q752 STK392-110 Convergence Amps
    • Re-soldered adjacent pads that looks suspicious
Total Cost to Repair about $10
  • Twelve hours of my time over three days to research issue, disassemble set, make repairs, add fuse panel.
  • Already owned Service Manual and Circuit diagrams from a different 2004 repair.
  • Less than ten dollars at Radio Shack for fuses and fuse panel. Already had wires, etc.
  • Some solder. Already owned de-soldering tools, etc.
  • Visited both local authorized Toshiba factory service repair facilities. One said repair would have to include replacing Q751 + Q752 STK392-110 Convergence Amps with ST392-180, and realigning set for a total of $500+ and it would be more if they had to order a power board. NO THANK YOU! Other shop said $65 for site visit and $30 to make an estimate that could be applied to repair.
Jan 04, 2009 | Toshiba 57H81 57" Rear Projection...
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
