Question about Onkyo Audio Players & Recorders
How to exit ebugging mode in onkyo - Onkyo Audio Players & Recorders
Onkyo receiver will not respond to Onkyo remote
Hi Thomas, I am not aware of your model but try pressing the receiver button in the remote mode section or RCV on top depending on your receiver model. Thank you, Onkyo USA
Dec 25, 2016 | Onkyo Audio Players & Recorders
I have an Onkyo TX-SR501 reciever/home theater amp. The sound works fine in home theater mode, but no sound when FM mode selected, but fine in AM mode. Have checked Antenna.
Hi Anil, please make sure the the receiver is locked into the station. It should read FM Stereo when locked in. Thank you, Onkyo USA
Nov 23, 2016 | Onkyo TX-SR501 Receiver
Upon powering up my Onkyo TX-SR605 receiver, it enters Audyssey setup mode even though the microphone is not plugged in. Even if I plug in microphone and remove it, it still stays in Audyssey mode and I...
I have the same problem and it is not speaker wires, cables, or dumb remote codes (really, remote codes.) I'm taking mine in for repair, and not reliying on straw grasping, speculative solutions.
Jan 25, 2011 | Onkyo TX-SR605 Receiver
My onkyo tx8211 stay on a stand by mode. I can
If it's anything like my Onkyo surround receiver, pressing any input selection will turn on unit.
May 16, 2010 | Onkyo TX-8511 Receiver
Philips TV 42pfl9664 remote control interferes Onkyo
HI it is entirely possible that the function you are using on your tv has the same command that your Onkyo uses for selection of GAME-mode. You should be able to prove this by using the Game-mode button on your Onkyo remote and it should affect your TV.
If Not then try shielding the remote receiver on your stereo with something thick ( a piece of paper is transparemt to IR - use a book or pillow) and see if the problem clears.
If this test proves correct, then the only solution is to see if you can change the remote command ID on the stereo and remote (if it supports it). The philips will most probably not have this feature. otherwise the only solution is to upgrade 1 device for a different brand.
Mar 21, 2010 | Philips Televison & Video
No sound output
Known problem w/Onkyo. Resolder Q710 transistor on DSP board.
Onkyo is aware of this problem.
Apr 11, 2009 | Onkyo TX-DS575 Receiver
Onkyo av amp goes to protect mode
There's a fre service manual here, you need to join tte site (free)
Onkyo TX SV727 Manual AV Control Receiver HiFi Engine
Sep 06, 2017 | Onkyo TX-SV727 Receiver
Need Remote Codes
The manual on Page 10 says that with these modes (DVD,CD,MD,CDR,HDD) on the Remote you can control an Onkyo DVD player and CD/MD/CDR/HDD player/recorder.
For DVD, on page 12, it says to just push the DVD button (top right) and the following buttons will functions as stated.
ON/STANDBY button
This button sets the DVD player to On or Standby.
Number buttons
These buttons are used to enter title, chapter, and
track numbers and to enter times for locating specific
points in time.
DISC +/– button
This button selects discs on a DVD changer.
TOP MENU button
This button is used to select a DVD’s top menu.
Arrow [UP]/[DOWN]/[LEFT]/[RIGHT] & ENTER buttons
These buttons are used to navigate DVD menus and
the DVD player’s onscreen setup menus.
RETURN button
This button is used to exit the DVD player’s
onscreen setup menu and to restart menu playback.
Playback buttons
From left to right: Pause, Play, Stop, Fast Reverse,
Fast Forward, Previous, and Next.
SUBTITLE button
This button is used to select subtitles.
AUDIO button
This button selects foreign language soundtracks
and audio formats (e.g., Dolby Digital or DTS).
DISPLAY button
This button is used to display information about the
current disc, title, chapter, or track on the DVD
player’s display, including the elapsed time, remaining
time, total time, and so on.
CLR button
This button is used to cancel functions and to clear
entered numbers.
MENU button
This button is used to display a DVD’s menu.
SETUP button
This button is used to access the DVD player’s
RANDOM button
This button is used with the random playback function.
REPEAT button
This button is used to set the repeat playback functions.
PLAY MODE button
This button is used to select play modes on a component
with selectable play modes.
Feb 05, 2009 | Onkyo TX-SR304 Receiver
Just bought refirb. Onkyo 805, hooked up front l&r plus sub and getting no sound. I set up am and fm as per manual and connected a cd changer thru the cd in via rca cables. Radio shows a signal but no...
After few sec when you turn on your receiver did you hear a click noise ? if yes your receiver is OK not in protection mode if no click noise is output protection in that case you must return where did you buy for service and update firmware a lot of update
However you can reset your receiver and debug the DSP section ( digital signal processor ) as follow
To reset
1. Press and hold down VCR/DVR button, then press STANDBY/ON button when the unit is Power on.
2. After " Clear " is displayed, the preset memory and each mode stored in the memory are initialized and will
return to the factory settings, and turn to Standby mode.
Now turn back on and check if it work or not and make sure check input mode such as analog or coaxial or optical input if stil no sound then debug DSP as follow
To set in DSP debug mode
1. Press and hold down DISPLAY button, then press STANDBY/ON button while the unit is powered ON.
The version number of m icroprocessor is displayed only for 3 seconds.
Main:
8 1.05/07903A
2. Press TONE+ button within 3 seconds above, the version number of 1st DSP is displayed.
DSP 1st:
SR8051:07601A
3. Press DISPLAY button while the 1st DSP version is displayed. The status of DSP and DIR will be displayed.
E1A48K0N/0FFPo
FFFFFF0 0 000
To exit
Press STANDBY/ON button.
Then unplug the unit for 30 sec then plug in it should work now if not you need to return it to 1 of the service center Onkyo in your town to repair it
Good luck
Nov 30, 2008 | Onkyo Audio Players & Recorders
We cannot get a disc out of a DVD player Onkyo CP702?
What is the model number of your DVD player?
Nov 30, 2008 | Onkyo TX-SR605 Receiver
24 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
