Question about Yard Machines Cultivator
IDC cultivator oil/gas mixture ratio
I need the oil / gas ratio for an IDC Cultivator Model 400 31 cc. Thank you, Erin
  • 97 Answers
SOURCE: the cultivator is getting gas, the plug looks new but no fire
Check Compression, if you dont have a gage put your finger in spark plug hole it should blow it out.
Next check for spark,It should be a blue spark at plug.
Next put a little fuel in carb and see if it will fire.
Hope this helps. Let me know.
Posted on Mar 25, 2009
  • 61 Answers
SOURCE: fuel line routing yard machine 31cc cultivator
unit with primer bulb,,,,,line from gas tank with filter, goes to bottom of carb, from top of tank to suction side of primer bulb, from output of primer to tank return
Posted on Apr 29, 2010
Testimonial: "Thanks for the info, tiller runs fine. Phil"
  • 52 Answers
SOURCE: Cultivator won't start.
After sitting for that long the carburetor will gum up and not let gas through. Buy a carburetor repair kit and replace the diaphram and gaskets. Be sure to make a sketch of where the fuel lines are routed to. It's easy to forget where they went and a headache to try to figure out. If it has a primer button I would replace that also.
Posted on May 02, 2010
2strokeguy
  • 183 Answers
SOURCE: 31cc yard machine garden cultivator.
Only 3 possibilities for no spark. First, are you using an inline spark tester to determine there is no spark? If so, here's your possibilities.
1. The on/off switch is shorted out.
2. There is a short in the wire(s) from the switch to the ignition module.
3. The module is faulty.
Dissassemble the engine cover far enough to access the module. There is a small wire that leads to a spade connector on the module. Disconnect this wire. Retest for spark. If you still have no spark, the module is faulty and must be replaced. If you now have spark, then the module is good, so back track the wires to the switch to determine if the wires are pinch or chaffed, or if the switch is stuck in the off position.
If you are not testing for spark with an inline tester, please, please go to Walmart or Pepboys or Autozone or NAPA or Sears and spend $7 to $10 on the tester....it will save you alot of trouble.
Good luck.
Posted on Sep 13, 2010
rycgl
  • 1545 Answers
SOURCE: I need a diagram for
Here is a parts breakdown for your machine (found under MTD) with parts listings, diagrams and prices.
http://www.partstree.com/parts/?lc=MTD&mn=21A-121R900
Posted on Nov 24, 2010
Bolens cultivator model BL425 engine will not start
I would make sure that you have the proper gas/oil ratio mixed first. If that is ok then I would have the filter changed. If that doesn't solve the problem then you should take it in to have the carburetor serviced.
Jul 04, 2014 | Bolens 25cc 2-Cycle Gas Cultivator BL425
I need parts for the IDC 400 31cc cultivator
ordertree.com has them for abt 50 dollar. part 753-04125, I believe its a mtd part. plus abt 10.00 shipping
Aug 25, 2012 | Yard Machines Cultivator
Fuel oil mixture ratio for ryobi 410r cultivator
I have a 410R still looks like new.
it has on it gas & oil = 40. to 1 for mixture.
mine never gets used so it is still new.
Jun 23, 2010 | Ryobi Cultivator
What oil and gas mixture should i use 50:1 30:1 or 40:1
if using sthil oil the mix is 50:1 other wise 40:1
Jun 16, 2010 | Ryobi Cultivator
I was wondering what the correct gas/oil mixture is for the MC 53 earthquake cultivator
I mix all my two cycles stuff at 32 to 1, it smokes alittle but runs forever.
Jun 04, 2009 | Ardisam Inc Earthquake Mini Cultivator
Gasoline/Oil Mixture
I would not run it any any less that  50/1 ratio.
May 09, 2009 | Ryobi Cultivator
Yard Machines Cultivator Logo
110 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
