Question about Uniden DECT 6.0 Cordless Phone ID
How to connect an HS 950 headset to Uniden DECT 9135
The instructions in the manual do not work, pressing "find Headset" for 5 seconds doesn't seem to work.
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 142 Answers
(I presume you have checked the headset is fully charged and powered on.)
Together with pressing "Find Headset" on the phone, you also have to press and hold "VOLUME +/-" for 5 seconds on the headset.
When the connection is made the headset LED will flash blue every 10 seconds.
I hope this helps.
Posted on May 11, 2014
Hs 950 headset won't charge up can it be reset as new out of box
then prehaps you need to spend more money and buy another . LI ION batteries do have low limits and they can be reset but not by conumers
Jul 10, 2015 | Uniden Lands Phones
When I try to couple the BH-218 to my Garmin i press the ]as in the manual but only get voive prompt on or off, the coupling mode does not seem to function.
My guess is you don't have the headset in pairing mode. The instructions below are from the instructions for the BH-218"
Before using the headset, you must pair and connect it to a compatible phone.
1. Make sure your headset is switched off and your compatible phone is on.
2. If you've never paired the headset with a device, or you've cleared the pairings,
switch the headset on.
If you've previously paired your headset with another device, press and hold the multifunction button
for 5 seconds.
Pairing mode is switched on, and a blue indicator light starts to flash quickly.
3. Within 3 minutes, switch Bluetooth on in your phone, then set it to search for
Bluetooth devices. For details, see the user guide of the phone.
4. On your phone, select the headset from the list of found devices.
5. If asked, type in the passcode 0000.
When the headset is connected to a phone, the Bluetooth indicator light flashes
slowly.
You can pair your headset with 8 phones, but you can only connect it to 2 phones at
the same time.
With some phones, you may need to make the connection separately after pairing.
Tip: Can't connect the headset to a compatible phone? Make sure that the headset
is charged, switched on, and paired with the phone.
Jul 15, 2013 | Nokia BH-218 Bluetooth Headset
Blue Parrott Road Warrior B250XT, will not stay connected to my phone, The phone is a Motorolai335, it will connect and disconnect just when ever some times every 3 to 5 minutes and will reconnect within...
These steps are for a headset that is already paired to you cell phone and is stored in the phones trusted device / history list.
Look at the lights on the Multi-Function Button of the headset (the top / largest button of the three buttons); the light will be blinking Red if not connected and blue if connected (paired and connected are two different things). Push the volume up (middle button) 2 times, you should hear a beep each time you press it. If you hear the beeps go to the next paragraph. If you hear no beeps at all you will need to call 1-800-742-8588 for an RA # (Return Authorization Number) for warranty and non warranty repairs.
Look at the lights on the Multi-Function Button on the headset (the top / largest button of the three buttons); the light should be blinking Red if not connected and Blue if connected (paired and connected are two different things). Plug the headset into the power adaptor with power applied. Make sure your cell phone is on and the Bluetooth power of the PHONE is turned on. After 5 seconds unplug the headset from the charger and do not press any buttons. You should get a slow Red blinking light at first. Allow the headset to connect automatically to the cell phone, this may take up to 10 seconds. Once the connection has occurred the Blue light on the Multi-Function Button will blink once every second.
If after 10 seconds the light is still blinking Red once every 5 seconds you will need to press either the Multi-Function Button of the headset once to connect to the cell phone, or, your phone may be set up requiring you press a designated button or sequence in the phone to connect to the headset (meaning your cell phone is not set with or does not support automatic connect).
*NOTE* Most newer model cell phones have an automatic connect feature. Some phones have the categories of "Headset", and "Hands Free" in their Bluetooth menu. Some companies use the term Auto-Connect under the "Hands Free" category in their Bluetooth menu to indicate the set up for use with the Bluetooth system in an AUTOMOBILE.
Automatic connection under the "Headset" category and Auto-connect under the "Hands Free" category are not the same thing. When dealing with the headset you want to work in the "Headset" menu and make sure the Auto-connect of the "Hands Free" menu is turned off.
If this doesn't correct the issue I'd recommend calling VXi at 800-742-8588 for additional clear and reset instructions and the possability of warranty repair options.
Aug 29, 2011 | VXI Corporation Blueparrott B250-XT...
Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Uniden BT-108 Bluetooth Headset
Cannot pair
if you can pair this device go to paring mode by pressing the answer/end key and the volume up( +) key at the same time over 5 seconds until the blue indicator light lights up.
after do this try to paring again.
Jul 20, 2009 | Nokia HS-36W Wireless Headset
Cant connect logitech bluetooth to phone,
the logitech head piece buttons must not be working, seems to charge ok but can't get to flash blue?
Aug 07, 2008 | Logitech Mobile Freedom Wireless Headset
Skywing bluetooth
PUT H700 HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset
boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator
light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The
indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Then on your phone, search for new bluetooth devices and connect. the defaault code for the HS is 0000
Jul 01, 2008 | Motorola Mobility H700 Wireless Headset
Headset not Supported
Nokia HS-3 is a stereo headset.
Your phone does not support stereo.
So Use mono Headsets like HS-5.
Nokia 9300 is a stereo supported phone and hence works with the headset fine.
Dec 01, 2007 | Nokia 7610
What is the default passcode for the Logitech F-0228A Mobile Freedom headset?
Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Pair Your Headset
Before using, you must pair your headset.
1. Turn phone on.
2. With Headset off, push Talk/Volume up button for 10 seconds. Blue LED will flash rapidly.
3. Follow pairing instructions in phone-setup or connect menu. Your phone should find “Logitech
HS04VXX”Headset and prompt you for a passkey pin.
4. Enter “0000”.
5. Press OK on phone.
6. From Headset device list press “Logitech HS04VXX” Headset.
7. Select connect.
When your Headset is successfully paired, the blue LED will flash slowly.
Nov 11, 2007 | Logitech Mobile Freedom Wireless Headset
Uniden DECT 6.0 Cordless Phone ID Logo
183 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
