Question about Crunch Powerzone P2200 Car Audio Amplifier
How to fix Crunch amp in protect mode - Crunch Powerzone P2200 Car Audio Amplifier
2 Suggested Answers
jdvillanueva
  • 2098 Answers
SOURCE: crunch 1500 went into protect
Hi ,
"Protect"
is an error code for short and overload. Once the power applied to the unit and shorts sensed by the processor, the unit will automatically turned to "protect" to avoid further damaged to other parts. Most shorts is in the supply voltage (B+, Vcc) line and most common caused is the sound output IC (mounted in heat sink). This part is responsible for amplifying the audio from the pre-amplifier stage and will feed to your speakers.
If you have a knowledge in disoldering and soldering technique, I would advice you to pull-out this part and then try the unit. If the "Amp Grd" error code is gone then you must replaced this IC with a new one to back your unit in normal operation again.
Before that, try to isolate first the speakers, if you have a shorted one, same symptoms will be encounter. Disconnect all the speakers from the unit and turned it on naked. If the symptoms is gone, then check for shorted speakers.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Jun 15, 2011
What would cause my Marshall Mode 4 amp to not change channels?
That can be caused by a faulty switch contact. I presume channels can be selected manually.
Aug 05, 2014 | Marshall Amplification Marshall AR-AM4,...
P1100.2 no sound
have you checked your fuses. on the amp and your amp power wire also there is a power remote wire that tells the amp to turn on when you turn on your radio.
Mar 31, 2012 | Cars & Trucks
Crunch 1500 went into protect mode, what do i do?
Hi ,
"Protect"
Hope I helped you.
Have a nice day!
Jun 15, 2011 | Crunch Powerzone P2200 Car Audio Amplifier
I have a Crunch Powerzone Pzi2250 1000 Watt Amplifier. and the red light blinks. What does that mean
My crunch powerzone pzi2250 1000 watt 2ch amp is stuck in protect mode. How do I fix this at home
Jan 16, 2011 | Crunch Powerzone P4175 Car Audio Amplifier
Protection light comes on , was only coming on when i turned up the stereo , now it stays on , all the wires are good and i cracked the amp open and nothing looks burnt
check your gain on your amp. If it gets hot the shuts off into protection mode you are over working your amp. Check to see the way your subs are wired up and see if your amp can handel the load.
May 20, 2010 | Crunch Drive V-3004 Car Audio Amplifier
I have a DA 1200.5 5 channel amp. It stopped
diconnect all your speakers from the amp and see if the light turns green. if it does, reconnect one speaker at a time to find out what speaker is making the amp go into protect mode
Feb 24, 2010 | Crunch BlackMaxx BLX2000D Car Audio...
I have a V 150 SE crunch amp. i have a red light
This more than likely means that you have a blown fuse. Go to an electronic store and replace the fuses. Make sure you get the exact same sizes and types that you had before.
Oct 24, 2009 | Car Audio & Video
My amplifier is not in protection mode everything works fine but my subwoofers play a very small sound . and it is not my subs at fault i already tested my subs and they work fine. i know theres a problem...
THERES A PROBLEM WITH YOUR RCA'S,IF YOU JIGGLE THEM WHILE THERE HOOKED UP TO THE AMP AND THEY MAKE THINGS LOUDER OR POP THAN YOU NEED TO GET THE RCA TERMINALS FIXED.
May 07, 2009 | Crunch Maxxsonics PZi 3000.1D Car Amp
Crunch GP 3000 D Pro
It's very likely that the output transistors have failed in the amp. They will need to be replaced.
Jun 14, 2008 | Crunch Drive V-600 Car Audio Amplifier
Red LED "Protection Light is on" What is the problem
The red light means the amp is in protection mode. A few things can cause protection mode..... First disconnect the subs completely from the amp, and turn it on, if it powers up you have blown subs. Also try checking the main power wire at the battery...sometimes the current your meter is seeing is backfeeding from the remote wire, so your main power line could be blown at the fuse under the hood. hope this helps
Jul 17, 2007 | Crunch BlackMaxx BMX2250 2 Ch 1000W Amp...
Crunch Powerzone P2200 Car Audio Amplifier Logo
73 people viewed this question
Top Crunch Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Tygh Duval
Tygh Duval
Walter Dominguez
Level 1 Expert
Are you a Crunch Car Audio and Video Expert? Answer questions, earn points and help others
