Question about RCA L26HD31 26 in. LCD HDTV
I can not connect my rca dlp HDTV to my hp laptop. I tried using VGA wire, laptop is fine but TV is showing unuseable signal
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 105 Answers
A lot of TVs only accept limite PC resolutions. Try 1028x768 60hz this normally works.
The Error message doesn't mean the TV or PC is not working, only that the signal is not compatible. try all resolutions until something works.
Posted on Jun 23, 2009
How to connect my dell inspiron 1501 laptop to my hdtv. am using a vga cable with rca out, to connect to the tv. i have tried everything but none works. if this can work please sent me step by step...
1 - the cable you are trying to use will not work - the RCA inputs in your tv can't accept the signal coming from the VGA. To connect the laptop to a tv the tv must have an VGA input, nothing else will work.
2 - When you start the laptop with an external device (such as an external monitor or tv) attached and turned on, the image may appear on either the laptop's display or the external device.
Press to switch the video image between the display only, the external device only, or the display and the external device simultaneously.
Apr 27, 2011 | Dell Inspiron 1501 Notebook
This RCA L26HD31 TV has always worked fine in other respects... but when I try to connect my pc's hdmi cable to it for use as a monitor, I just get "unusable signal". When this TV was made, hdmi...
Make sure you have set the laptop's display properties to as low a resolution as possible (also make sure the screen refresh rate is 60 hertz) and turned it off before connecting it to the television. Turn the television on first and set to the correct input either hdmi 1 or 2. Then turn on the laptop. When it has booted up hold down the function key and the dual monitor key (either F5 or F8) for 15 seconds for an image to appear on the screen. When you have an image you can play around with increasing the laptop's resolution.
Apr 27, 2011 | RCA L26HD31 26 in. LCD HDTV
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
How do I connect my laptop to my TV wiyh a VGA
do you have a VGA input on the TV?
If not, you need a PC to TV converter.
Link Here:
http://www.geeks.com/details.asp?invtid=ITV-900&cat=VCD
This ITV-900 is a one piece PC to TV Converter that lets you show computer presentations, play games and watch DVDs on TV. It converts your computer's VGA signal to your TV's S-Video and video output signal!
The PC to TV converter supports up to 1024 x 768 resolutions, NTSC/PAL television system, auto fine tuning and more! This ITV-900 is compact, portable and easy to use!
Nov 26, 2009 | HP Pavilion zd8000 Notebook
Trying to connect my laptop to Hdtv with vga wire?
Ok, 14-pin is for really OLD VGA. Your cable will simply NOT work. Find a S-VGA cable (15-pin) and you are on your way to fame. By the way, make some room trashing that old cable.
Apr 18, 2009 | HP Pavilion dv9700t Notebook PC
Connect Laptop to TV
It depends on what kind of TV you have. If you have a flat-panel LCD or plasma TV, it may have a VGA connection already installed. If that is the case, all you need is a standard VGA cable to connect from your notebook to your TV.
If you have a TV without a VGA connection you will need a scan converter to convert your signal from VGA to RCA or composite video signal. These can be purchased online or from electronics stores like Radio Shack. You plug your VGA connection from the computer to the scan converter, then RCA or composite video cables from the converter to the TV.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 16, 2009 | HP Compaq 8510p Notebook
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Unusable Signal
Hello Mike:
The issue that you are having is with your small signal board and it needs to be replaced, it sounds like the microprocessor on that board is getting locked up.
Aug 19, 2008 | RCA L42WD22 42 in. LCD Television
Problem with RCA HDLP50W151
Press power and channel down at the same time to do a soft reset
this should fix it if its a software glitch
thanks
scott
Jun 05, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
RCA L26HD31 26 in. LCD HDTV Logo
228 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
