Question about BenQ Computers & Internet
My Benq monitor was working, then it suddenly went black and said Hdmi no signal. After a few hours, it started again fine, but when I tried to play a game, after a minute or so it went black and star
Since then, my computer seems to start up fine, complete with startup and shutdown audio through the speakers or headphones, but the screen still shows nothing. Is there any way to fix this? I've left it alone for over a day, just to see if that would fix it. It didn't.
    Top Expert:
  • BenQ Master
  • 75,283 Answers
Check the signal cable connected in between monitor and system for firmness. Re-seat at both end once and check. If it does not help you, contact any service technician. Gopakumar Gopalan Google
Posted on May 11, 2014
Sunil Panem
  • 80 Answers
SOURCE: HP Pavilion - the monitor flashes off and on
Pls uninstall the video card drivers and reinstall them.
Also pls look for any graphics driver updates from the manufacturer.
Also pls check if the cable from the power supply for the graphics is connected on the motherboard.
Pls check with another monitor if it is doing the same thing.
If the same happens with another monitor, then it is an issue with the video card..
Posted on Jan 30, 2008
SOURCE: Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Posted on Apr 02, 2008
skotkolr
  • 558 Answers
SOURCE: FP531 Monitor flashes 'Benq'
sounds like an internal issue with the power board service tech should look at it
Posted on May 10, 2008
SOURCE: BENQ FP737S Monitor shows "No Signal Detected" on startup
first problem could be the hdmi cable you are using is loose or broken.second, the display mode you selected was wrong, try to go to desktop and right click and choose nvdia control panel and choose the nview display mode to use,select the only use one display(single)and apply.
Posted on Jan 27, 2009
SOURCE: Monitor Randomly Turns Black
I have exactly the same problem with my Benq FP71E+ ..
What i found is a temp fix is this :
When monitor dims and goes black i turn it off , hit the bottom left side (near the BENQ logo) turn it on again and it works ..
This works every time for me . But after a while it switches off again , could be 5 minutes could be 5 hours . Its random
Posted on Apr 02, 2009
Suddenly dropped hdmi signal on all ports - sees device but gets
Switch off the TV, switch off power and remove plug and wait for 48 hours and retry.
Jul 28, 2012 | Samsung UN55C9000 55 in. 3D LCD TV
Sudden Shutdown of the unit, I Cannot use my FP72E BenQ LCD monitor Properly because at the middle of using it, it suddenly shutdown, open, shutdown again, open again. is this unit is capable for long...
For the monitor that is more than 2 years old, first place to look will be the power supply, look for bad caps with bulging top first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps; http://s807.photobucket.com/home/budm/allalbums
Feb 16, 2010 | BenQ FP72E 17" LCD Monitor
Setting audio to optical makes hdmi video not work
Here is the solution - in the audio settings you have to select optical out or it will still use HDMI. Regards, Joe
Feb 13, 2010 | Sony PlayStation 3 Slim Black Console
Onkyo605 stopped outputting Video after installing HDAV1.3 sound
If you didnt change any of the inputs going to the onkyo. I would check the input setup. I dont know what input you have your pc connected to on the onkyo, i'm guessing that your using a hdmi cable. make sure you have hdmi selected as your input type not component video or any other. That model doesnt upconvert anything to hdmi. Also some dvi-d to hdmi dont play well wih onkyo.
Aug 16, 2009 | Onkyo TX-SR605 Receiver
May 10, 2008 | BenQ FP531 15" LCD Monitor
May 02, 2008 | BenQ FP71E 17" LCD Monitor
BenQ FP241W 24" inch problem with HDMI connection
Sounds like the HDMI port on the monitor has been shorted out.
There are very small fuses on the video board that can be changed, but they are fiddly and you may end up doing more harm then good if you are not sure what your doing.
The fuses are actually soldered to the board...it's not a case of pop one out and pop one in like the glass type.
Hope it helps =)
Jan 15, 2008 | BenQ FP731 17" LCD Monitor
Benq FP71G+S NOt starting.
Hello
I have had this problem twice once at my school and once with my BenQ FP71G Monitor. At my school the monitor ( HP ) just stopped working and smelt like burnt popcorn.(though is think this is due to some kids chucking a soccer(football) ball at it! With my BenQ it has the same problem though i nownthink it is because of the monitor has been on for excessive hours ( 3-4 ) and just shut down because of overheating. I will see in a couple of hours if it works !
Copper_R
Dec 30, 2007 | BenQ FP71G 17" LCD Monitor
Benq FP737s - Not working suddenly - Black screen
Most like just burned out and needs repaired or replaced.
Nov 11, 2007 | BenQ FP737S-D 17" LCD Monitor
Computers & Internet Logo
134 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
