Question about Sony DAV-SC5 System
My sony MHC-G2R7D setup video out shows black and white pictures, how to overcome that
  • 119 Answers
SOURCE: Picture in Black & White
if you are using composite cables (yellow,red & white), make sure your yellow (video cable) is into the yellow output. if you plugged the wire into the green on the back of the dvd it will give you a black & white picute. But if it is in the yellow then you most likely have a problem with the dvd player that will need to be taken to a service center.
Posted on Nov 03, 2006
SOURCE: original DVD plays black and white
I thing Shivi comments r wrong. Sony and most of the dvd player supports ntsc colour system for DVS and pal for vcd. Set ur tv colour system to auto or ntsc
Posted on Nov 03, 2007
  • 653 Answers
SOURCE: Sony T3 cybershot screen black
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=7&NAVDISP=di
Posted on Mar 13, 2009
SOURCE: Sony DSC T77 How to Setup Black and white mode
Hi Allonsoma,
What the manual doesn't tell you is that you need to change the REC mode first to be able to fint the buttons in MENU.
Fist go into the REC mode (the one above menu when taking a photo). Change this to PGM and click OK. Now go into MENU, on the 3/4 page second button down should be a box with a + in the corner. This is the colour mode option. You can now change to vivid, sepia or black and white.
Hope this helps.
Posted on Oct 10, 2009
  • 347 Answers
SOURCE: Sony cassette recorder GV-A500: The video picture
looks like a color system difference, check GV-A500 is PAL or NTSC.
Posted on Feb 19, 2011
MHC-GN1300D Video
I need to unlock a Sony mhc 1300D mini hi fi component , make it to play all the region
Oct 24, 2012 | Sony Mhc-gn1300d 3 Dvd/vcd/cd Changer...
How do i open the cd tray on a sony mhc-rg70av shelf system that seems stuck
Most CD trays will open if you shut off equipment and pull gently but firmly to overcome the slight initial resistance. Don't use so much force that it seems likely that the tray mech will break. This calls for a serious bit of taking apart and is best left to the local repair shop.
Oct 31, 2009 | Sony MHC-RG70AV CD Shelf System
Hi Allonsoma,
Hope this helps.
Mar 26, 2009 | Sony Cybershot DSC-T77 Digital Camera
Playstaion Shows only in black white
Try manually resetting the video.
While the PS3 is off,
Press and HOLD down the POWER BUTTON
When you hear the second beep, QUICKLY release the power button.
Let me know what happens.
Mar 01, 2009 | Sony Playstation 3 (PS3) Console
Dvd in black and white should be color
Your probably had connected with a component video without changing the video setting!If you video setting is under composite/S-Video output but you end up connect the video source with component video cable,you need to go to the setup to change it.
It could be the other way around too!
solutiondoct
Nov 01, 2008 | Sony DVP-NS315 DVD Player
Black and White Screen
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option
Jan 07, 2008 | Sony Playstation 3 (PS3) Console
Sony dvp ns50p dvd player
If you are using the s-video jack to connect the DVD to the TV, the jack could be loose or the wire could be bad. The s-video cable has 2 signals, the black-and-white (luminance) and the color (chroma). If the chroma signal is not getting through, the picture will be in black and white.
Sep 01, 2007 | Sony DVP-NS50P DVD Player
Original DVD plays black and white
It seems that you have get the color system setting of your Tv wrong. Sony uses the Pal(it's a format for the transmission of signals) color system , so check into your TV's color system settings and change it to pal , if that doesnt work then change it to Ntsc.
Aug 18, 2007 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Camara won't take pictures, screen shots look black and white blurry
Hello, please try to reset the camera and check your settings according the user manual. If you need more info please advice. Arpi
Jun 14, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Sony DAV-SC5 System Logo
47 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
