Question about HP Computers & Internet
600va upswhy no power out in the 220 output - HP Computers & Internet
  • 641 Answers
Kindly check this site Ramer, as I checked it is okay with 110 or 220. You might want to try other power strip or outlet.
Posted on May 11, 2014
Replacing lcd tv 110 volts power supply with 220 v0lts power supply
Hi Anonymous,
In most of the cases the power supply in lcd TVs can handle both 110 and 220 volts. Still if you want to replace it, please check the output voltages of the new supply you want to put. If they are the same you can replace it without any doubt. In case the order of the pins in the connector is not the same, you can cut it away and solder the wires on respective pins. In case you do not get the supply of the same brand, you can use a supply of some other brand with same voltage output.
Good luck.
Aug 08, 2016 | Samsung Televison & Video
No power output in the ups 600va
Replace the UPS or power supply
May 11, 2014 | Computers & Internet
I have APC RS 600, 360W battery which is not working that means O/P voltage 230V is nill there is no Output supply . I checked the ckt but when switch on the ups it will start alarm and even i check the...
Hi Datta,
It seems that you have the wrong battery in that UPS. The replacement battery for that unit should be an RBC2 -or- a 12v 7.5ah battery ($28 delivered). The UPS will not work without the correct battery in place.
If you could provide me with the exact model number I may be able assist you further.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
** If this helped - Give it a Thumbs Up :) **
Dec 13, 2013 | APC Back-UPS 600VA UPS System
WHAT IS THE PROBLEM BECAUSE, MY UPS IS NOT GIVING BACKUP POWER SUPPY, AND CONTINIOUSLY BIPPING WHEN POWER GOES OFF ?
The battery in the unit may need to be replaced. Usually it is a 12Volt 7Ah high discharge, Sealed Lead Acid Battery.
They life span is around 2-5 Years.
Take care!
damnor01
Apr 28, 2012 | Computers & Internet
I need to adjust the output voltage higher in the "power back up mode". Which pot do I adjust?
you need to open the unit and get a palstic screw driver and look for the output adjust variable resistor and turn the variable resistor. make sure you have a true rms voltmeter when your doin it. Good luck
Jul 09, 2009 | APC Back-UPS 600VA UPS System
Battery back up supply
it is possible that the fuse for the input of power is broken or bad
Feb 11, 2009 | Energizer ER-HM650 UPS System
Power supply
if you are in usa, you need 1-468-809-11 POWER UNIT input ac 110 volt and output 8.5volt dc
and if you are in uk, then
1-468-811-11 POWER UNIT input ac 220 volt and output 8.5 volt dc
bye.
Sep 08, 2008 | Sony ICF-CD855VSIL Clock Radio
Singer 7422 power output
The electrical specifications are as follows:
220 - 230 V
50/60Hz
Total 65W
Regards
Enjoy your machine
Dec 04, 2007 | Singer 7422
Computers & Internet Logo
19 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
